* | virtex5/startup/dummy_console.c: Use <rtems/bspIo.h> and <rtems/console.h> ↵ | Joel Sherrill | 2017-04-26 | 1 | -20/+2 |
| | | | | for many of the prototypes | ||||
* | virtex4/startup/dummy_console.c: Use <rtems/bspIo.h> and <rtems/console.h> ↵ | Joel Sherrill | 2017-04-26 | 1 | -17/+2 |
* | virtex5/startup/dummy_console.c: Fix no prototype warning | Joel Sherrill | 2017-04-24 | 1 | -0/+1 |
* | virtex4/startup/dummy_console.c: Fix no prototype warning | Joel Sherrill | 2017-04-24 | 1 | -0/+1 |
* | shared/startup/panic.c: Fix printf() format warnings | Joel Sherrill | 2017-04-24 | 1 | -2/+5 |
* | shared/pci/detect_raven_bridge.c: Fix printf() format warnings | Joel Sherrill | 2017-04-24 | 1 | -1/+1 |
* | shared/bootloader/mm.c: Fix printf() format warnings | Joel Sherrill | 2017-04-24 | 1 | -2/+4 |
* | shared/bootloader/misc.c: Fix printf() format warnings | Joel Sherrill | 2017-04-24 | 1 | -2/+3 |
* | beatnik/pci/gt_pci_init.c: Fix printf() format warnings | Joel Sherrill | 2017-04-24 | 1 | -1/+1 |
* | beatnik/startup/bspstart.c: Fix printf() format warnings | Joel Sherrill | 2017-04-24 | 1 | -1/+1 |
* | beatnik/marvell/discovery.c: Fix printf() format warnings | Joel Sherrill | 2017-04-24 | 1 | -2/+2 |
* | powerpc/haleakala/./mmu_405.c: Use inttypes.h constants removes 11 warnings. | Cillian O'Donnell | 2017-04-14 | 1 | -6/+14 |
* | powerpc/mvme550/./pci.c: Use inttypes.h constant to fix 1 warning. | Cillian O'Donnell | 2017-04-14 | 1 | -1/+2 |
* | virtex4/startup/bspstart.c: Use %p to fix 11 warnings. | Cillian O'Donnell | 2017-04-14 | 1 | -13/+14 |
* | virtex5/startup/bspstart.c: Use %p to fix 11 warnings. | Cillian O'Donnell | 2017-04-14 | 1 | -13/+14 |
* | libbsp/powerpc/./pci/detect_raven_bridge.c: Use inttypes.h to fix 1 warning. | Cillian O'Donnell | 2017-04-14 | 1 | -1/+2 |
* | bootstrap: regenerate files after sort order fix | Gedare Bloom | 2017-04-13 | 1 | -2/+2 |
| | | | | Updates #2965. | ||||
* | bsp/qoriq: Comment out post-link hook | Sebastian Huber | 2017-04-05 | 1 | -6/+6 |
| | | | | | | The U-Boot mkimage is not available in general. Close #2969. | ||||
* | mpc55xxevb/.../*-testsuite.tcfg: Add linpack | Joel Sherrill | 2017-04-04 | 11 | -0/+17 |
* | bsp/qoriq: Fix L1 cache flush | Sebastian Huber | 2017-04-03 | 1 | -6/+13 |
* | bsp/qoriq: Adjust MMU config only once | Sebastian Huber | 2017-04-03 | 3 | -5/+10 |
* | bsp/qoriq: Add post-link hook | Sebastian Huber | 2017-04-03 | 1 | -0/+7 |
* | bsps: Fix baud settings | Sebastian Huber | 2017-04-03 | 2 | -2/+2 |
| | | | | Update #2897. | ||||
* | bsp/qoriq: Regenerate preinstall.am | Sebastian Huber | 2017-03-27 | 1 | -4/+0 |
* | termios: Synchronize with latest FreeBSD headers | Kevin Kirspel | 2017-03-22 | 4 | -5/+5 |
| | | | | | | | | | | | Adding modified FreeBSD headers to synchronize RTEMS termios with FreeBSD. Modify termios to support dedicated input and output baud for termios structure. Updated BSPs to use dedicated input and output baud in termios structure. Updated tools to use dedicated input and output baud in termios structure. Updated termios testsuites to use dedicated input and output baud in termios structure. Close #2897. | ||||
* | bsp/qoriq: Fix memory configuration | Sebastian Huber | 2017-03-08 | 1 | -1/+6 |
| | | | | Take nocache section into account which may reside after the workspace. | ||||
* | bsps: Provide <bsp/fdt.h> for every BSP | Sebastian Huber | 2017-03-08 | 3 | -3/+9 |
| | | | | Add bsp_fdt_map_intr() intended for the libbsd FDT support. | ||||
* | bsp/beatnik: More verbose fatal extension | Sebastian Huber | 2017-03-06 | 1 | -0/+6 |
* | bsp/beatnik: Update due to API changes | Sebastian Huber | 2017-03-06 | 2 | -2/+1 |
| | | | | | The device_t typedef is already provided by <sys/types.h> if _KERNEL is defined. | ||||
* | bsp/qoriq: Use at most 2GiB of RAM | Sebastian Huber | 2017-03-02 | 1 | -1/+1 |
* | bsp/qoriq: Adjust workspace according to FDT | Sebastian Huber | 2017-03-02 | 2 | -5/+70 |
* | bsp/qoriq: Use -O2 | Sebastian Huber | 2017-03-02 | 1 | -1/+1 |
* | bsp/qoriq: Enable linker garbage collection | Sebastian Huber | 2017-03-02 | 1 | -0/+3 |
* | bsp/qoriq: Do not overwrite configured baud | Sebastian Huber | 2017-03-02 | 1 | -1/+0 |
* | bsps/powerpc: Fix warnings | Sebastian Huber | 2017-03-01 | 4 | -13/+17 |
* | bsps/powerpc: Fix warnings | Sebastian Huber | 2017-02-15 | 3 | -44/+46 |
* | bsps/powerpc: Fix warnings | Sebastian Huber | 2017-02-15 | 3 | -3/+4 |
* | bsps/powerpc: Fix warnings | Sebastian Huber | 2017-02-15 | 2 | -10/+11 |
* | bsp/beatnik: Remove superfluous check | Sebastian Huber | 2017-01-20 | 1 | -1/+1 |
| | | | | Close #2874. | ||||
* | powerpc/mpc55xxevb/*.tcfg: Add fsjffs2gc01 to excluded tests | Joel Sherrill | 2017-01-17 | 6 | -0/+6 |
* | powerpc/shared/linkcmds.base: Add .rela.rtemsroset and .rela.rtemsrwset | Joel Sherrill | 2017-01-16 | 1 | -0/+2 |
* | Rename is_internal to always_set_to_false | Sebastian Huber | 2016-12-12 | 4 | -4/+4 |
| | | | | Update #2825. | ||||
* | score: Remove fatal is internal indicator | Sebastian Huber | 2016-12-09 | 1 | -2/+0 |
| | | | | | | | | | The fatal is internal indicator is redundant since the fatal source and error code uniquely identify a fatal error. Keep the fatal user extension is internal parameter for backward compatibility and set it to false always. Update #2825. | ||||
* | testsuite: Add test states to the testsuit configuration files. | Chris Johns | 2016-12-07 | 17 | -69/+69 |
| | | | | | | | | | | | | | | | | Change the testsuite configuration files to hold state information about a test. The states are: exclude - Do not build the test expected-fail - The test is expected to fail indeterminate - The test may pass or may fail A message is printed just after the test's BEGIN message to indicate there is a special state for the test. No state message means the test is expected to pass. This support requires tests are correctly written to the use standard support to begin and end a test. | ||||
* | powerpc: Add up to date CPU_Interrupt_frame | Sebastian Huber | 2016-11-18 | 3 | -9/+9 |
| | | | | | | | Rename ppc_exc_min_frame to CPU_Interrupt_frame. Move it and the corresponding defines to <rtems/score/cpuimpl.h>. Update #2809. | ||||
* | powerpc: Move legacy CPU_Interrupt_frame | Sebastian Huber | 2016-11-18 | 1 | -1/+0 |
| | | | | | | | The only remaining user of CPU_Interrupt_frame on PowerPC is the mpc5xx support. Move it to here. Update #2809. | ||||
* | powerpc: Add _CPU_Get_current_per_CPU_control() | Sebastian Huber | 2016-11-10 | 1 | -0/+4 |
| | | | | | | | | Add _CPU_Get_current_per_CPU_control() on SMP configurations. Use SPRG0 for the current per-CPU control. This reduces the code size by three instructions and is slightly faster. Update #2805. | ||||
* | bsp/qoriq: Remove duplicate qoriq_gpio definition | Sebastian Huber | 2016-11-07 | 1 | -4/+0 |
| | | | | Close #2800. | ||||
* | virtex4, virtex5 bsp.h: Use BSP_INTERRUPT_STACK_SIZE not user space ↵ | Tim Cussins | 2016-11-03 | 2 | -2/+2 |
| | | | | | | CONFIGURE_INTERRUPT_STACK_SIZE closes #2801. | ||||
* | bsp/qoriq: Add GPIO register map | Sebastian Huber | 2016-10-11 | 1 | -1/+14 |
