* rtems/score/cpu.h: Removed.
* bootloader/exception.S: Reflect changes to <rtems/score/cpu.h>.
* bootloader/head.S: Ditto.
* bootloader/misc.c: Ditto.
* console/polled_io.c: Ditto.
* irq/irq.c: Ditto.
* irq/irq_asm.S: Ditto.
* irq/irq_init.c: Include <rtems/bspIo.h>.
* start/start.S: Reflect changes to <rtems/score/cpu.h>.
* vectors/vectors.S: Ditto.
* vectors/vectors.S: Include <asm.h>.
* startup/bspstart.c: Include <rtems/bspIo.h>.
* vectors/align_h.S: Use <> instead of "" for include files.
* irq/irq.c: Reflect changes to <rtems/score/cpu.h>.
* network/network.c: Include <rtems/bspIo.h>.
* start/start.S: Include <asm.h> instead of "asm.h".
* vectors/vectors.S: Reflect changes to <rtems/score/cpu.h>.
Fix loopCounter.
* irq/irq_asm.S: Reflect changes to <rtems/score/cpu.h>.
* vectors/vectors_init.c: Include <rtems/bspIo.h>.
* irq/irq.c: Reflect changed to <rtems/score/cpu.h>.
* irq/irq.c: Define loopCounter iff DISPATCH_HANDLER_STAT is set.
* startup/bspstart.c: include <bsp/irq.h>, <libcpu/cpuIdent.h>,
<rtems/bspIo.h>
* startup/bspstart.c: Include <libcpu/cpuIdent.h>, <rtems/bspIo.h>.
* startup/bspstart.c: Include <libcpu/cpuIdent.h>.
<rtems/bspIo.h>
* configure.ac: Add BSPOPTS_*(DISPATCH_HANDLER_STAT).
Remove RTEMS_ENABLE_LIBCDIR.
* startup/linkcmds, startup/linkcmds.dl : Per PR170, PR171, and PR172
add .eh_frame.
* startup/linkcmds: Per PR170, PR171, and PR172 add .eh_frame
* residual/residual.c: Include <string.h>.
* vectors/vectors_init.c: Include <rtems/bspIo.h> for printk.
* bootloader/mm.c: Ditto.
* bootloader/pci.c: Ditto.
* console/console.c: Ditto.
* openpic/openpic.c: Ditto.
* bootloader/Makefile.am: Use automake-1.6 AS compilation rules.
* rtems/score/cpu.h: Account for name change.
* bootloader/Makefile.am: Use AM_CCASFLAGS instead of AM_ASFLAGS.
* bootloader/Makefile.am: Remove AUTOMAKE_OPTIONS.
* motorola/Makefile.am: Remove AUTOMAKE_OPTIONS.
* openpic/Makefile.am: Remove AUTOMAKE_OPTIONS.
* pci/Makefile.am: Remove AUTOMAKE_OPTIONS.
* residual/Makefile.am: Remove AUTOMAKE_OPTIONS.
* vectors/Makefile.am: Remove AUTOMAKE_OPTIONS.
* PCI_bus/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tod/Makefile.am: Remove AUTOMAKE_OPTIONS.
* nvram/Makefile.am: Remove AUTOMAKE_OPTIONS.
* universe/Makefile.am: Remove AUTOMAKE_OPTIONS.
* dlentry/Makefile.am: Remove AUTOMAKE_OPTIONS.
* flashentry/Makefile.am: Remove AUTOMAKE_OPTIONS.
* canbus/Makefile.am: Remove AUTOMAKE_OPTIONS.
* scv64/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sonic/Makefile.am: Remove AUTOMAKE_OPTIONS.
* vector/vector.S, irq/irq_asm.S: Make sure vectors work properly
in RAM and Flash based code. The code executed for the Flash
version runs in both cases (code in Flash/code in RAM) but as it
is less efficient than the one optimized for RAM, it put it inside
ifdef. A compilation error is generated if code is linked in Flash
with the correct ifdef set...
* irq/irq.c: Correct minor bug in mbx8xx interrupt handling.
Quoting Eric, "In theory it should be applied in each mpc8xx
related BSP but as I cannot test it plase maintainer/users
submit patch accordingly."
* configure.ac: Add RTEMS_CHECK_NETWORKING.
* console/console-io.c: Include rtems/bspIo.h instead of bspIo.h.
* clock/p_clock.c: Include rtems/bspIo.h instead of bspIo.h.
* console/console.c: Include rtems/bspIo.h instead of bspIo.h.
* irq/irq_init.c: Include rtems/bspIo.h instead of bspIo.h.
* configure.ac: Remove RTEMS_ENABLE_NETWORKING.
* include/Makefile.am: Use _HEADER instead of H_FILES.
* irq/Makefile.am: Ditto.
* openpic/Makefile.am: Ditto.
* include/bsp.h: Include <bspopts.h>.
* Makefile.am: Add DIST_SUBDIRS.
This was tracked as PR87.
* README, configure.ac, include/Makefile.am, include/bsp.h,
start/start.S, startup/FPGA.c, startup/Makefile.am, tod/Makefile.am:
Eliminated conditional code for generation 1 boards as these are
no longer available.
* include/gen1.h, startup/82378zb.c, tod/tod_g1.c: Deleted.
This was tracked as PR91.
* rtems/score/c_isr.inl: Deleted and contents merged into cpu.c.
* cpu.c: Received contents of c_isr.inl.
* Makefile.am: Deleted reference to c_isr.inl.
* configure.ac: Add RTEMS_BSPOPTS_*(DATA_CACHE_ENABLE),
RTEMS_BSPOPTS_*(INSTRUCTION_CACHE_ENABLE).
* Makefile.am: Remove . from SUBDIRS, remove duplicate bsp_specs
rules, add @exceptions@ to SUBDIRS.
* configure.ac: Add RTEMS_BSPOPTS_*(PPC_USE_SPRG),
RTEMS_BSPOPTS_*(PPC_VECTOR_FILE_BASE),
RTEMS_PPC_EXCEPTIONS([old]), autoupdate to autoconf 2.52.
* include/Makefile.am: Convert PREINSTALL_FILES to
TMPINSTALL_FILES, include force-preinstall.am.
* wrapup/Makefile.am: Apply @exceptions@.
* Makefile.am: Remove . from SUBDIRS, add @exceptions@ to
SUBDIRS.
RTEMS_PPC_EXCEPTIONS([old]).
* .cvsignore: Add aclocal.m4, autom4te.*, config.*, configure.
