* | bsps: Simplify FreeBSD linker sets | Sebastian Huber | 2013-12-16 | 1 | -12/+4 |
* | bsps/powerpc: Use ALIGN_WITH_INPUT | Sebastian Huber | 2013-12-16 | 5 | -168/+101 |
| | | | | This requires at least Binutils 2.24. | ||||
* | doxygen: refactored doxygen in libbsp to illustrate new rule set | Daniel Ramirez | 2013-12-09 | 3 | -7/+22 |
* | virtex4: Move start.S to virtex4/start/start.S | Daniel Ramirez | 2013-12-06 | 2 | -1/+1 |
* | tqm8xx: Move start.S to tqm8xx/start/start.S | Daniel Ramirez | 2013-12-06 | 2 | -1/+1 |
* | virtex5: Move start.S to virtex5/start/start.S | Daniel Ramirez | 2013-12-06 | 2 | -1/+1 |
* | powerpc/ss555: move startup/start.S to start/start.S | Chirayu Desai | 2013-12-06 | 3 | -2/+2 |
* | powerpc: mbx8xx: move starup/start.S to start/start.S | Chirayu Desai | 2013-12-06 | 2 | -1/+1 |
* | bsp/qoriq: Use System V small-data area | Sebastian Huber | 2013-12-03 | 1 | -1/+1 |
* | powerpc: motorola: Move bspreset.c to startup/ | Chirayu Desai | 2013-12-02 | 2 | -3/+3 |
| | | | | * Move shared/console/bspreset.c to motorola_powerpc/startup/bspreset.c | ||||
* | powerpc/mpc55xxevb: Move bspworkarea.c to bspgetworkarea.c | Chirayu Desai | 2013-11-24 | 2 | -1/+1 |
| | | | | Fixes commit 571216aceef5d59bec8022f119a0cecf97544f6f | ||||
* | mpc55xxevb: Move start.S to mpc55xxevb/start/start.S | Daniel Ramirez | 2013-11-23 | 2 | -1/+1 |
* | beatnik: Move bsp_reset() to beatnik/startup/bspreset.c | Daniel Ramirez | 2013-11-23 | 2 | -1/+1 |
* | powerpc/mpc55xxevb: Move bspworkareainit.c to bspgetworkarea.c | Chirayu Desai | 2013-11-23 | 2 | -1/+1 |
| | | | | * Move bsp_work_area_initialize() | ||||
* | powerpc/mpc55xxevb: Move startup/reset.c to startup/bspreset.c | Chirayu Desai | 2013-11-23 | 2 | -1/+1 |
* | Use $(EXEEXT) [defaults to "exe"] to generate binaries | Nick Withers | 2013-08-09 | 17 | -25/+25 |
* | PR766: Delete __RTEMS_APPLICATION__ | Sebastian Huber | 2013-08-08 | 1 | -4/+0 |
| | | | | This define is no longer used. | ||||
* | smp: Add and use _Per_CPU_Get() | Sebastian Huber | 2013-07-30 | 1 | -2/+5 |
| | | | | | | Add and use _Per_CPU_Get_by_index() and _Per_CPU_Get_index(). Add _Per_CPU_Send_interrupt(). This avoids direct access of _Per_CPU_Information. | ||||
* | bsps: Include missing <rtems/score/heapimpl.h> | Sebastian Huber | 2013-07-26 | 1 | -0/+1 |
* | Include missing <rtems/score/threaddispatch.h> | Sebastian Huber | 2013-07-26 | 1 | -2/+2 |
* | score: Merge sysstate API into one file | Sebastian Huber | 2013-07-24 | 5 | -0/+5 |
* | bsp/gen83xx: Fix BSP options for MPC8348EAMDS | Ralf Kirchner | 2013-07-18 | 1 | -2/+1 |
* | smp: Add and use _CPU_SMP_Send_interrupt() | Sebastian Huber | 2013-07-17 | 1 | -2/+3 |
| | | | | Delete bsp_smp_interrupt_cpu(). | ||||
* | smp: Add and use _CPU_SMP_Get_current_processor() | Sebastian Huber | 2013-07-17 | 1 | -5/+0 |
| | | | | | | | | | | Add and use _SMP_Get_current_processor() and rtems_smp_get_current_processor(). Delete bsp_smp_interrupt_cpu(). Change type of current processor index from int to uint32_t to match _SMP_Processor_count type. | ||||
* | bsp/mpc55xx: Add MPC5668G support | Sebastian Huber | 2013-07-15 | 10 | -7/+66 |
* | bsp/virtex: Use #if instead of #ifdef | Sebastian Huber | 2013-07-10 | 1 | -9/+9 |
| | | | | | This allows VIRTEX_CONSOLE_USE_INTERRUPTS=0 on the configure command line to disable the interrupt mode. | ||||
* | bsp/virtex: Add VIRTEX_CONSOLE_USE_INTERRUPTS | Sebastian Huber | 2013-07-09 | 2 | -37/+107 |
| | | | | Add interrupt support for console driver. | ||||
* | bsp/virtex: Use ppc_count_leading_zeros() | Sebastian Huber | 2013-07-09 | 1 | -11/+10 |
| | | | | Use ppc_count_leading_zeros() to optimize interrupt processing. | ||||
* | bsp/virtex: Fix interrupt handling | Sebastian Huber | 2013-07-09 | 1 | -9/+5 |
| | | | | | | Some modules like the XPS UART Lite use event triggered interrupts. If we acknowledge the interrupts after the interrupt service we may loose these events. | ||||
* | bsp/mpc55xx: Update due to API changes | Sebastian Huber | 2013-07-05 | 2 | -16/+12 |
| | | | | | Termios notifies now the driver about an inactive transmit with the length argument set to zero. | ||||
* | bsp/mpc55xx: Avoid integer overflow | Sebastian Huber | 2013-07-05 | 1 | -2/+2 |
* | bsp/mpc55xx: Round PLL divider up | Sebastian Huber | 2013-07-05 | 1 | -1/+2 |
* | bsp/psim: Use EABI and System V small-data area | Ralf Kirchner | 2013-07-05 | 1 | -1/+1 |
* | bsps/powerpc: Avoid placement in small-data area | Ralf Kirchner | 2013-07-05 | 1 | -2/+2 |
* | bsp/psim: Fix declaration | Ralf Kirchner | 2013-07-05 | 1 | -2/+2 |
| | | | | It declares a symbol defined in the linker command file. | ||||
* | bsp/psim: Use plain symbol for PSIM | Sebastian Huber | 2013-06-28 | 3 | -27/+2 |
| | | | | This avoids a linker assertion failure in the GCC test suite. | ||||
* | bsps/powerpc: Update debug sections | Sebastian Huber | 2013-06-28 | 1 | -18/+18 |
* | termios: Update due to API changes | Sebastian Huber | 2013-06-25 | 4 | -60/+64 |
* | bsp/virtex: Use shared clock driver | Sebastian Huber | 2013-06-24 | 3 | -12/+5 |
* | bsp/virtex: Add console devices only if present | Sebastian Huber | 2013-06-24 | 1 | -10/+11 |
* | bsp/virtex: Fix warnings | Sebastian Huber | 2013-06-24 | 1 | -11/+11 |
* | bsp/virtex: Use XPAR_INTC_SINGLE_BASEADDR | Sebastian Huber | 2013-06-24 | 1 | -1/+1 |
| | | | | This define is also present in newer "xparameters.h". | ||||
* | bsp/virtex: Remove unused configure macros | Sebastian Huber | 2013-06-24 | 1 | -17/+0 |
* | bsp/virtex: Delete BSP_ask_for_reset and BSP_panic | Sebastian Huber | 2013-06-24 | 1 | -13/+7 |
* | bsp/virtex: Use generic interrupt support | Sebastian Huber | 2013-06-24 | 8 | -427/+135 |
* | bsp/virtex: Fix header includes | Sebastian Huber | 2013-06-24 | 1 | -6/+3 |
* | bsp/virtex: Move timer config to new file | Sebastian Huber | 2013-06-24 | 3 | -9/+68 |
* | bsp/virtex: Do not use PPC403 TTY driver | Sebastian Huber | 2013-06-24 | 2 | -12/+1 |
* | bsp/virtex: Fix warnings | Sebastian Huber | 2013-06-24 | 1 | -2/+2 |
* | bsp/virtex: Delete bsp_XAssertHandler() | Sebastian Huber | 2013-06-24 | 1 | -12/+0 |
