* console/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* irq/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* motorola/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* openpic/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* pci/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* residual/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* vectors/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* bootloader/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* vme/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* Makefile.am: Reworked.
* Makefile.am: Misc cleanups and fixes.
* startup/linkcmds: Preparations for gcc-3.3.x.
* bootloader/Makefile.am: Misc cleanups and fixes.
* motorola/Makefile.am: Misc cleanups and fixes.
* startup/linkcmds: Preparations to gcc-3.3.x.
* startup/Makefile.am: Remove S_FILES (Unused).
* vectors/Makefile.am: Cosmetics.
* Makefile.am: Cosmetics.
* bootloader/Makefile.am: Cosmetics.
Don't preinstall bsp_specs.dl.
* dlentry/Makefile.am: Cosmetics.
* flashentry/Makefile.am: Cosmetics.
* PCI_bus/Makefile.am: Cosmetics.
* tod/Makefile.am: Cosmetics.
* shmsupp/Makefile.am: Cosmetics.
* network/Makefile.am: Cosmetics.
* nvram/Makefile.am: Cosmetics.
* pci/Makefile.am: Cosmetics.
* universe/Makefile.am: Cosmetics.
* irq/Makefile.am: Add preinstallation dirstamp support.
* vectors/Makefile.am: Add preinstallation dirstamp support.
* motorola/Makefile.am: Cosmetics.
* openpic/Makefile.am: Cosmetics.
* residual/Makefile.am: Cosmetics.
* start/Makefile.am: Cosmetics.
* vme/Makefile.am: Add preinstallation dirstamp support.
* ide/Makefile.am: Cosmetics.
* canbus/Makefile.am: Cosmetics.
* scv64/Makefile.am: Cosmetics.
* sonic/Makefile.am: Cosmetics.
* Makefile.am: Remove include_rtems_score_HEADERS.
Reformat for preinstallation dirstamp support.
* Makefile.am: Reformat for preinstallation dirstamp support.
* start/Makefile.am: Remove empty lines.
* bootloader/Makefile.am: Put all files into EXTRA_DIST.
* vme/Makefile.am: Ditto.
* console/Makefile.am: Move H_FILES to include_bsp_HEADERS.
* irq/Makefile.am: Ditto.
* motorola/Makefile.am: Ditto.
* openpic/Makefile.am: Ditto.
* pci/Makefile.am: Ditto.
* residual/Makefile.am: Ditto.
* vectors/Makefile.am: Ditto.
* Makefile.am: Remove empty lines.
* clock/Makefile.am: Ditto.
* include/Makefile.am: Ditto.
* startup/Makefile.am: Ditto.
* Makefile.am: Remove all-local: $(ARCH).
* PCI_bus/Makefile.am: Remove all-local: $(ARCH).
* tod/Makefile.am: Remove all-local: $(ARCH).
* shmsupp/Makefile.am: Remove all-local: $(ARCH).
* nvram/Makefile.am: Remove all-local: $(ARCH).
* pci/Makefile.am: Remove all-local: $(ARCH).
* universe/Makefile.am: Remove all-local: $(ARCH).
* irq/Makefile.am: Remove all-local: $(ARCH).
* motorola/Makefile.am: Remove all-local: $(ARCH).
* openpic/Makefile.am: Remove all-local: $(ARCH).
* residual/Makefile.am: Remove all-local: $(ARCH).
* vme/Makefile.am: Remove all-local: $(ARCH).
* ide/Makefile.am: Remove all-local: $(ARCH).
* dlentry/Makefile.am: Remove all-local: $(ARCH).
* flashentry/Makefile.am: Remove all-local: $(ARCH).
* canbus/Makefile.am: Remove all-local: $(ARCH).
* scv64/Makefile.am: Remove all-local: $(ARCH).
* sonic/Makefile.am: Remove all-local: $(ARCH).
PR 510/bsps
* irq/irq.h: Add extern C wrapper.
* configure.ac: Remove RTEMS_CANONICAL_HOST.
* configure.ac: Remove RTEMS_CHECK_CPU.
* acinclude.m4: Reflect changes to bootstrap.
* vectors/Makefile.am: Fix header installation.
PR 497/bsps
* bootloader/head.S: Disable code that returned to the firmware when
the loader starts.
