2019-11-14 | bsp/t32mppc: Rename linker command file | Sebastian Huber | 1 | -1/+0 | |
This BSP family uses only one linker command file. Use the standard name. Update #3818. | |||||
2019-05-16 | bsps: Always build generic interrupt support | Sebastian Huber | 8 | -4/+15 | |
This makes it possible to write tests for the generic interrupt controller support. Update #3269. | |||||
2018-12-14 | build: Remove ampolish3 | Sebastian Huber | 1 | -4/+0 | |
Update #3254. | |||||
2018-11-19 | bsps/powerpc: Use interrupt stack for init stack | Sebastian Huber | 5 | -16/+20 | |
Move start.o to separate file. Update #3459. | |||||
2018-10-15 | build: Remove specialized CPPFLAGS | Sebastian Huber | 1 | -1/+0 | |
Close #3375. | |||||
2018-10-10 | build: Remove local.am | Sebastian Huber | 21 | -21/+0 | |
2018-09-17 | bsp/tqm8xx: Remove unused files | Sebastian Huber | 1 | -1/+0 | |
Close #3513. | |||||
2018-09-17 | bsp/tqm8xx: Convert console to new Termios API | Sebastian Huber | 1 | -0/+1 | |
Update #3513. | |||||
2018-09-03 | bsps: BSP_INTERRUPT_STACK_AT_WORK_AREA_BEGIN | Sebastian Huber | 3 | -9/+0 | |
Remove the BSP_INTERRUPT_STACK_AT_WORK_AREA_BEGIN hack. The interrupt stacks are now allocated by the linker. Update #3459. | |||||
2018-05-18 | virtex5: Move -Dxxx to configure.ac | Joel Sherrill | 1 | -0/+2 | |
Updates #3425. | |||||
2018-05-18 | virtex4: Move -Dxxx to configure.ac | Joel Sherrill | 1 | -0/+2 | |
2018-05-18 | virtex: Move -Dxxx to configure.ac | Joel Sherrill | 1 | -0/+2 | |
2018-05-18 | tqm8xx: Move -Dxxx to configure.ac | Joel Sherrill | 1 | -0/+1 | |
2018-05-18 | t32mppc: Move -Dxxx to configure.ac | Joel Sherrill | 1 | -1/+1 | |
2018-05-18 | ss555: Move -Dxxx to configure.ac | Joel Sherrill | 1 | -0/+2 | |
2018-05-18 | qoriq: Move -Dxxx to configure.ac | Joel Sherrill | 1 | -1/+1 | |
2018-05-18 | qemuppc: Move -Dxxx to configure.ac | Joel Sherrill | 1 | -0/+1 | |
2018-05-18 | psim: Move -Dxxx to configure.ac | Joel Sherrill | 1 | -0/+2 | |
2018-05-18 | mvme5500: Move -Dxxx to configure.ac | Joel Sherrill | 1 | -0/+2 | |
2018-05-18 | mvme3100: Move -Dxxx to configure.ac | Joel Sherrill | 1 | -0/+2 | |
2018-05-18 | mpc8260ads: Move -Dxxx to configure.ac | Joel Sherrill | 1 | -0/+1 | |
2018-05-18 | mpc55xxevb: Move -Dxxx to configure.ac | Joel Sherrill | 1 | -0/+2 | |
2018-05-18 | motorola_powerpc: Move -Dxxx to configure.ac | Joel Sherrill | 1 | -0/+14 | |
2018-05-18 | haleakala: Move -Dxxx to configure.ac | Joel Sherrill | 1 | -0/+2 | |
2018-05-18 | beatnik: Move -Dxxx to configure.ac | Joel Sherrill | 1 | -0/+2 | |
2018-04-26 | bsps: Move documentation, etc. files to bsps | Sebastian Huber | 37 | -2816/+0 | |
This patch is a part of the BSP source reorganization. Update #3285. | |||||
2018-04-26 | bsps: Remove unmaintained times files | Sebastian Huber | 2 | -386/+0 | |
2018-04-26 | bsps/powerpc: Move bsp-start-zero.S to bsps | Sebastian Huber | 5 | -119/+4 | |
2018-04-26 | bsp/psim: Move align_h.S to bsps | Sebastian Huber | 2 | -440/+1 | |
2018-04-26 | bsp/haleakala: Move assembler files to bsps | Sebastian Huber | 3 | -322/+2 | |
2018-04-25 | bsp/qemuppc: Install linkcmds.base | Sebastian Huber | 1 | -0/+1 | |
Update #3339. Close #3411. | |||||
2018-04-25 | bsps: Remove unused u-boot-generic-board-info.h | Sebastian Huber | 1 | -132/+0 | |
2018-04-25 | bsp/gen5200: Move source files to bsps | Sebastian Huber | 7 | -3129/+4 | |
2018-04-25 | bsp/haleakala: Move mmu_405.c to bsps | Sebastian Huber | 2 | -294/+1 | |
2018-04-25 | bsp/beatnik: Move source files to bsps | Sebastian Huber | 8 | -2721/+4 | |
2018-04-25 | bsp/mvme3100: Move flashcfg.c to bsps | Sebastian Huber | 2 | -117/+1 | |
2018-04-25 | bsp/mvme5500: Move source files to bsps | Sebastian Huber | 4 | -545/+3 | |
2018-04-25 | bsp/virtex5: Move mmu.c to bsps | Sebastian Huber | 2 | -582/+1 | |
2018-04-25 | bsp/virtex4: Move mmu.c to bsps | Sebastian Huber | 2 | -568/+1 | |
2018-04-24 | bsps: Move spansionFlash.c to bsps | Sebastian Huber | 2 | -478/+1 | |
2018-04-24 | bsps: Move intelFlash.c to bsps | Sebastian Huber | 2 | -465/+1 | |
2018-04-24 | bsps: Move flash.c to bsps | Sebastian Huber | 3 | -911/+2 | |
2018-04-24 | bsps: Move vpd.c to bsps | Sebastian Huber | 3 | -324/+2 | |
2018-04-24 | bsps: Move motorola.c to bsps | Sebastian Huber | 2 | -433/+1 | |
2018-04-24 | bsps: Move residual.c to bsps | Sebastian Huber | 2 | -105/+1 | |
2018-04-24 | bsps: Move showbats.c to bsps | Sebastian Huber | 3 | -53/+2 | |
2018-04-24 | bsps: Move ppc-exc-handler-table.c to bsps | Sebastian Huber | 4 | -70/+3 | |
2018-04-24 | bsps: Move memcpy.c to bsps | Sebastian Huber | 5 | -130/+4 | |
2018-04-24 | bsps: Move tictac.c to bsps | Sebastian Huber | 5 | -36/+4 | |
2018-04-24 | bsps: Move uboot_dump_bdinfo.c to bsps | Sebastian Huber | 2 | -80/+1 | |
