* | bsp/qoriq: Add T2080RDB and T4240RDB variants | Sebastian Huber | 2015-01-13 | 23 | -316/+709 |
* | powerpc: Use alternate time base for CPU counter | Sebastian Huber | 2015-01-09 | 1 | -1/+1 |
* | bsp/qoriq: Fix nanoseconds extension | Sebastian Huber | 2015-01-09 | 1 | -4/+17 |
* | bsp/qoriq: Increase MAS0[ESEL] width | Sebastian Huber | 2015-01-09 | 1 | -3/+3 |
* | bsp/qoriq: Add MAS7 support for MMU | Sebastian Huber | 2015-01-09 | 7 | -21/+50 |
| | | | | | This enables usage of the full real address space which is 40-bit on the T2080 for example. | ||||
* | bsps/powerpc: Support for 64 byte cache lines | Sebastian Huber | 2015-01-09 | 1 | -6/+23 |
* | bsps/u-boot: Update due to API changes | Sebastian Huber | 2015-01-09 | 2 | -3/+140 |
* | Use fixed-width C99 types for PowerPC in_be16() and co. | Nick Withers | 2014-12-23 | 22 | -148/+157 |
| | | | | | | Also use the const qualifier on the address pointer's target in in_*() Closes #2128 | ||||
* | bsp/mpc55xxevb: Fix warnings | Sebastian Huber | 2014-12-15 | 2 | -2/+10 |
* | bsp/t32mppc: Fix warnings | Sebastian Huber | 2014-12-15 | 2 | -5/+8 |
* | bsps/powerpc: Disable SPE for soft-float variants | Sebastian Huber | 2014-12-15 | 2 | -2/+2 |
* | bsp/mpc8xx: Fix warnings | Sebastian Huber | 2014-12-12 | 7 | -116/+45 |
| | | | | close #2211 | ||||
* | bsp/mpc8xx: Fix warnings | Sebastian Huber | 2014-12-12 | 4 | -15/+28 |
| | | | | close #2211 | ||||
* | Update bug report URL | Sebastian Huber | 2014-12-05 | 22 | -22/+22 |
* | Move the flash size probe into bankValidate() | Nick Withers | 2014-12-03 | 1 | -4/+5 |
| | | | | Previously, bankValidate() could be called (e.g., BSP_flashWrite() -> regionCheckAndErase() -> argcheck() -> bankValidate()) without the probe having happened. When it then invoked BSP_flashCheckId(), unmapped memory could be read, possibly causing a fatal exception. | ||||
* | bsp/qoriq: Delete empty header file | Sebastian Huber | 2014-11-27 | 3 | -5/+0 |
| | | | | close #2062 | ||||
* | powerpc/haleakala: Fix warnings | Joel Sherrill | 2014-11-21 | 2 | -1110/+1119 |
* | powerpc/haleakala: Add network driver | Nigel Spon | 2014-11-21 | 7 | -2/+1702 |
| | | | | close 1405 | ||||
* | Delete or rename MIN/MAX macros and defines | Sebastian Huber | 2014-11-21 | 2 | -5/+1 |
| | | | | Include <sys/param.h> if necessary to get the MIN()/MAX() macros. | ||||
* | bsp/mpc55xxevb: Fix flash settings for MPC5510 | Sebastian Huber | 2014-10-31 | 1 | -22/+43 |
* | bsps: Move extern "C" to not cover includes | Sebastian Huber | 2014-10-23 | 11 | -57/+55 |
| | | | | Some includes may use C++ and this conflicts if surrounded extern "C". | ||||
* | powerpc/qoriq/include/bsp.h: Add prototypes to fix warnings | Joel Sherrill | 2014-10-20 | 1 | -0/+10 |
* | powerpc/qemuppc/startup/cmain.c: Fix warnings | Joel Sherrill | 2014-10-20 | 1 | -0/+7 |
* | powerpc/shared/startup/bspstart.c: Fix warning for mvme2100 | Joel Sherrill | 2014-10-20 | 1 | -1/+1 |
* | ss555/startup/bspstart.c: BSP does not use SPRG0 | Joel Sherrill | 2014-10-20 | 1 | -2/+0 |
* | ep1a/startup/bspstart.c: BSP does not use SPRG0 | Joel Sherrill | 2014-10-20 | 1 | -2/+0 |
* | powerpc/shared/irq/irq_init.c: Fix warnings | Joel Sherrill | 2014-10-19 | 1 | -1/+1 |
* | powerpc/shared/bootloader: Fix warnings | Joel Sherrill | 2014-10-19 | 3 | -1/+11 |
* | powerpc/motorola_powerpc/include/bsp.h: Fix warnings | Joel Sherrill | 2014-10-19 | 1 | -0/+5 |
* | powerpc/psim: Fix warnings | Joel Sherrill | 2014-10-19 | 1 | -8/+13 |
* | powerpc/qemuppc: Fix warnings | Joel Sherrill | 2014-10-19 | 3 | -16/+24 |
* | powerpc/gen83xx: Fix warnings | Joel Sherrill | 2014-10-19 | 4 | -464/+491 |
* | libbsp/powerpc/shared and motorola_powerpc: Fix warnings | Joel Sherrill | 2014-10-19 | 6 | -99/+107 |
* | gen68302/console: Fix warnings | Joel Sherrill | 2014-10-19 | 1 | -299/+0 |
* | powerpc/mvme5500: Fix warnings | Joel Sherrill | 2014-10-19 | 7 | -274/+295 |
* | powerpc/beatnik: Fix warnings | Joel Sherrill | 2014-10-19 | 6 | -431/+467 |
* | powerpc/mvme3100: Fix warnings | Joel Sherrill | 2014-10-19 | 4 | -25/+41 |
* | powerpc/shared/startup/probeMemEnd.c: Fix warning | Joel Sherrill | 2014-10-19 | 1 | -6/+5 |
* | powerpc/tqm8xx/startup/bspstart.c: Fix set but not used warning | Joel Sherrill | 2014-10-19 | 1 | -0/+1 |
* | powerpc/t32mppc/startup/bspstart.c: Fix set but not used warning | Joel Sherrill | 2014-10-19 | 1 | -0/+1 |
* | powerpc/shared/startup/panic.c: Fix set but not used warning | Joel Sherrill | 2014-10-19 | 1 | -0/+2 |
* | powerpc/mvme5500/pci/pcifinddevice.c: Remove unused variable | Joel Sherrill | 2014-10-19 | 1 | -9/+6 |
* | powerpc/gen83xx/startup/bsprestart.c: Fix set but not used warning | Joel Sherrill | 2014-10-19 | 1 | -0/+1 |
* | score603e/cscope.out: Remove file accidentally added. | Joel Sherrill | 2014-10-16 | 1 | -11129/+0 |
| | | | | | Also added cscope.out to .gitignore_global and recommend everyone else do the same. | ||||
* | powerpc/virtex5/include/bsp.h: Fix warnings | Joel Sherrill | 2014-10-16 | 1 | -0/+5 |
* | powerpc/virtex4/include/bsp.h: Fix warnings | Joel Sherrill | 2014-10-16 | 1 | -4/+10 |
* | libbsp/powerpc/shared/uboot_getenv.c: Fix warnings | Joel Sherrill | 2014-10-16 | 1 | -2/+9 |
* | libbsp/powerpc/shared/startup/zerobss.c: Fix warnings | Joel Sherrill | 2014-10-16 | 1 | -5/+20 |
* | powerpc/score603e: Fix warnings | Joel Sherrill | 2014-10-16 | 7 | -110/+11197 |
* | mpc8260 libcpu and mpc6260ads BSP: Fix warnings | Joel Sherrill | 2014-10-16 | 5 | -66/+49 |
