* | bsps/powerpc: Add more BSP sections and sort them | Sebastian Huber | 2012-06-22 | 1 | -2/+4 |
* | bsps: Replace NIRVANA region | Sebastian Huber | 2012-06-12 | 24 | -43/+55 |
| | | | | | Replace the "NIRVANA" region with the more verbose "UNEXPECTED_SECTIONS" region. Move the region definition into the "linkcmds.base" files. | ||||
* | powerpc/mpc55xx: BSP variant changes for MPC5643L | Sebastian Huber | 2012-06-05 | 10 | -44/+60 |
* | bsp/t32mppc: Fix Trace32 configuration file | Sebastian Huber | 2012-06-04 | 1 | -3/+1 |
* | bsps/powerpc: Add load section for .nocache | Sebastian Huber | 2012-06-04 | 13 | -21/+48 |
* | bsp/qoriq: New BSP option | Sebastian Huber | 2012-06-04 | 2 | -0/+6 |
| | | | | New BSP option BSP_USE_DATA_CACHE_BLOCK_TOUCH. | ||||
* | Fix C files which had two semi-colons at EOL | Joel Sherrill | 2012-05-31 | 3 | -3/+3 |
* | Add bspopts.h.in. | Ralf Corsépius | 2012-05-24 | 21 | -0/+1290 |
* | powerpc/t32mppc: Typo | Sebastian Huber | 2012-05-22 | 1 | -1/+1 |
* | powerpc/t32mppc: New BSP | Sebastian Huber | 2012-05-22 | 17 | -0/+839 |
* | powerpc/qoriq: Fix due to console API changes | Sebastian Huber | 2012-05-21 | 1 | -2/+2 |
* | powerpc/mpc55xxevb: Fix cache define usage | Sebastian Huber | 2012-05-21 | 1 | -5/+9 |
* | pci.h cleanup - Consolidate common defines to cpukit pci.h | Joel Sherrill | 2012-05-16 | 5 | -18/+5 |
| | | | | | | | | | | | | | + libbsp/sparc/shared/include/pci.h was largely a copy of an older version of the cpukit pci.h. Removed much of the contents and included <rtems/pci.h>. + sparc/*/pci*.c - Move to <rtems/pci.h> required updating to use uint32_t for dword accesses. + Rename PCI_MULTI_FUNCTION to PCI_HEADER_TYPE_MULTI_FUNCTION + Define PCI_HEADER_TYPE_MULTI_FUNCTION in cpukit pci.h and remove PCI_MULTI_FUNCTION definitions in C files. + Move PCI_INVALID_VENDORDEVICEID definitions from various C files to cpukit pci.h | ||||
* | mvme5500 and cpukit pci.h - Eliminate mvme5500 specific pci.h | Joel Sherrill | 2012-05-16 | 5 | -63/+5 |
| | | | | | | | | All constants that should have been in cpukit pci.h were moved there. One naming style was corrected. This impacted if_wm.c. All other contents were the same as powerpc/shared/pci.h so BSP specific pci.h could be eliminated. | ||||
* | Remove CVS Id Strings (manual edits after script) | Joel Sherrill | 2012-05-11 | 4 | -9/+0 |
| | | | | | | These modifications were required by hand after running the script. In some cases, the file names did not match patterns. In others, the format of the file did not match any common patterns. | ||||
* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 397 | -866/+0 |
* | score603e - Eliminate any set_vector() remnants | Joel Sherrill | 2012-05-09 | 1 | -46/+0 |
* | virtex4 - Eliminate any set_vector() remnants | Joel Sherrill | 2012-05-09 | 1 | -6/+0 |
* | virtex - Eliminate any set_vector() remnants | Joel Sherrill | 2012-05-09 | 1 | -7/+0 |
* | mbx8xx - Eliminate any set_vector() remnants | Joel Sherrill | 2012-05-09 | 1 | -1/+0 |
* | haleakala - Eliminate commented out code | Joel Sherrill | 2012-05-09 | 1 | -8/+0 |
* | mpc8260ads - Eliminate commented out code | Joel Sherrill | 2012-05-09 | 1 | -6/+0 |
* | mpc8260ads - Eliminate any set_vector() remnants | Joel Sherrill | 2012-05-09 | 1 | -6/+0 |
* | Revert: Remove CVS Ids | Joel Sherrill | 2012-05-07 | 36 | -0/+111 |
| | | | | | See http://www.rtems.org/pipermail/rtems-devel/2012-May/001006.html for details. | ||||
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 36 | -111/+0 |
* | General - Remove extraneous blank line in license message | Joel Sherrill | 2012-05-03 | 1 | -1/+0 |
| | | | | | | | | | | | | | Many files had an extra blank line in the license text found in the file header. This patch removes that line. * The license and distribution terms for this file may be * found in the file LICENSE in this distribution or at * * http://www.rtems.com/license/LICENSE. The script that did this also turned off execute permission when it was turned on incorrectly. | ||||
* | score603e - Remove bad $Id$ and clean up file header | Joel Sherrill | 2012-05-02 | 1 | -4/+6 |
* | bsp/mpc55xxevb: Enable stack allocator | Sebastian Huber | 2012-04-24 | 6 | -4/+10 |
* | bsps/powerpc: Add no cache section | Sebastian Huber | 2012-04-24 | 14 | -89/+78 |
* | bsp/mpc55xxevb: Change early MMU settings | Sebastian Huber | 2012-04-24 | 3 | -17/+28 |
| | | | | | | Add internal SRAM sections with cache enabled to early MMU settings. The internal SRAM initialization will use the early MMU settings. This allows applications to use cache inhibited areas in the internal SRAM. | ||||
* | bsps: Update due to API changes | Sebastian Huber | 2012-04-07 | 1 | -5/+5 |
* | bsp/mpc55xx: Add and use chip features | Sebastian Huber | 2012-04-03 | 1 | -5/+5 |
| | | | | Add defines MPC55XX_HAS_SIU and MPC55XX_HAS_SIU_LITE. | ||||
* | bsp/tqm8xx: Install header file <bsp/irq-info.h> | Sebastian Huber | 2012-04-02 | 2 | -0/+5 |
* | bsp/qemuppc: Install header file <bsp/irq-info.h> | Sebastian Huber | 2012-04-02 | 2 | -1/+6 |
* | bsps: Fix for clock driver | Sebastian Huber | 2012-04-02 | 1 | -27/+0 |
| | | | | | | Do not use the e300 core decrementer auto-reload feature. We have to use the normal decrementer handler since otherwise it is impossible to pass test sptests/spnsext01. | ||||
* | bsp/gen83xx: Fix console driver configuration | Sebastian Huber | 2012-04-02 | 1 | -1/+1 |
* | bsp/gen83xx: Removed file | Sebastian Huber | 2012-04-02 | 1 | -57/+0 |
* | bsp/gen83xx: Regenerate | Sebastian Huber | 2012-04-02 | 1 | -36/+40 |
* | bsps: More accurate PowerPC clock driver | Sebastian Huber | 2012-04-02 | 7 | -20/+47 |
| | | | | | | The clock driver used previously the bsp_clicks_per_usec value. For a 33333333Hz time base frequency this leads to a relative error of one per cent for example due to integer truncation. | ||||
* | bsp/gen83xx: Support cache BSP options | Sebastian Huber | 2012-04-02 | 2 | -3/+6 |
* | bsp/gen83xx: Support for MPC830X | Sebastian Huber | 2012-04-02 | 1 | -1/+5 |
* | bsp/gen83xx: Add sections for BSD support | Sebastian Huber | 2012-04-02 | 1 | -0/+10 |
* | bsp/gen83xx: Install new header file | Sebastian Huber | 2012-04-02 | 1 | -10/+12 |
* | bsp/virtex5: Regenerate | Sebastian Huber | 2012-04-02 | 1 | -0/+4 |
* | Add Virtex4 and Virtex5 BSPs | Ric Claus | 2012-03-30 | 31 | -0/+4201 |
| | | | | | | | | | | | | | | | | | This commit covers at least PR2020, 2022, and 2023. This patch adds all of the code for both BSPs, modifications to libcpu/powerpc for the ppc440, and some updates to the BSPs from follow up review and testing. These BSPs should be good baselines for future development. The configurations used by Ric are custom and have a non-standard NIC. They also do not have a UART. Thus the current console driver just prints to a RAM buffer. The NIC and UART support are left for future work. When the UART support is added, moving the existing "to RAM" console driver to a shared location is likely desirable because boards with no debug UART port are commonly deployed. This would let printk() go to RAM. | ||||
* | Resolve link problems with psim irq-server | Jennifer Averett | 2012-03-30 | 4 | -2/+41 |
|\ | | | | | | | Add IRQ support components needed by new BSD code. | ||||
| * | Resolve link problems with psim irq-server | Jennifer Averett | 2012-03-30 | 4 | -2/+43 |
* | | Address Conflicts: | Jennifer Averett | 2012-03-29 | 2 | -2/+7 |
|\ \ | |/ |/| | | | c/src/lib/libbsp/powerpc/psim/startup/linkcmds | ||||
| * | Added irq server and link commands for new libbsd support. | Jennifer Averett | 2012-03-16 | 3 | -11/+24 |
* | | bsps: Add shared default IRQ handler | Sebastian Huber | 2012-03-24 | 13 | -65/+49 |
