* shared/startup/pretaskinghook.c: removed declaration
of BSP_vme_config() (which is already declared in
<bsp/VME.h>. Removed test for NULL-ness of BSP_vme_config;
gcc doesn't seem to understand that the linker may
define this to be NULL... Silences a compiler warning
(and users can always provide an empty routine).
* shared/startup/linkcmds, shared/startup/zerobss.c:
introduced '__bss_end'; assuming that __rtems_end
coincides with the end of .bss for the purpose of
zeroing .bss is very dangerous.
* shared/console/console.c: Fix typo.
* shared/console/console.c: Remove explicit switch and call
termios_baud_to_number().
* console/console.c: Remove explicit switch and call
* console/mc68360_scc.c: Remove explicit switch and call
* console/console.c: Properly inform termios of our initial baud rate.
If it is not the default, this causes problems when an application
changes any termios attributes since termios thinks our baud rate is
one thing when in fact, it is another.
* Makefile.am: Remove stray line.
* startup/bspstart.c: Add capability for bootcard.c BSP Initialization
Framework to ask the BSP where it has memory for the RTEMS Workspace
and C Program Heap. These collectively are referred to as work area.
If the BSP supports this, then it does not have to include code to
split the available memory between the two areas. This reduces the
amount of code in the BSP specific bspstart.c file. Additionally, the
shared framework can initialize the C Library, call
rtems_debug_enable(), and dirty the work area memory. Until most/all
BSPs support this new capability, if the BSP supports this, it should
call RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION from its configure.ac.
When the transition is complete, this autoconf macro can be removed.
* shared/startup/pretaskinghook.c: Add capability for bootcard.c BSP
Initialization Framework to ask the BSP where it has memory for the
RTEMS Workspace and C Program Heap. These collectively are referred
to as work area. If the BSP supports this, then it does not have to
include code to split the available memory between the two areas.
This reduces the amount of code in the BSP specific bspstart.c file.
Additionally, the shared framework can initialize the C Library, call
* Makefile.am, configure.ac, startup/bspstart.c: Add capability for
bootcard.c BSP Initialization Framework to ask the BSP where it has
memory for the RTEMS Workspace and C Program Heap. These collectively
are referred to as work area. If the BSP supports this, then it does
not have to include code to split the available memory between the
two areas. This reduces the amount of code in the BSP specific
bspstart.c file. Additionally, the shared framework can initialize
the C Library, call rtems_debug_enable(), and dirty the work area
memory. Until most/all BSPs support this new capability, if the BSP
supports this, it should call
RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION from its configure.ac. When
* startup/bspstart.c, startup/bspstart.c.nocache: Add capability for
* Makefile.am: Rework to avoid .rel files.
* startup/bspstart.c: Refactored and renamed initialization routines to
rtems_initialize_data_structures, rtems_initialize_before_drivers,
rtems_initialize_device_drivers, and
rtems_initialize_start_multitasking. This opened the sequence up so
that bootcard() could provide a more robust and flexible framework
which is easier to explain and understand. This also lays the
groundwork for sharing the division of available memory between the
RTEMS workspace and heap and the C library initialization across all
BSPs.
* shared/startup/bspstart.c: Refactored and renamed initialization
routines to rtems_initialize_data_structures,
rtems_initialize_before_drivers, rtems_initialize_device_drivers, and
BSPs.
* Makefile.am, startup/bspstart.c: Refactored and renamed
initialization routines to rtems_initialize_data_structures,
BSPs.
* startup/bspstart.c, startup/bspstart.c.nocache: Refactored and
renamed initialization routines to rtems_initialize_data_structures,
BSPs.
* network/tsec.c: removed memory input/output operands
which caused problems with gcc-4.3.0 (see
http://gcc.gnu.org/ml/gcc/2008-03/msg00976.html)
* console/console-io.c: Typo.
* console/config.c: Fix typo.
* Makefile.am: Remove all references to console_reserve_resources and
termios_reserve_resources.
* console/consolereserveresources.c: Removed.
* startup/bspstart.c: Remove all references to
console_reserve_resources and termios_reserve_resources.
* startup/bspstart.c, startup/bspstart.c.nocache: Remove all references
to console_reserve_resources and termios_reserve_resources.
* Makefile.am: Do not use intermediate .rel files unless from libcpu or
a network driver. This simplifies the Makefile.am and avoids pulling
in unneeded code.
* include/bsp.h: declare BSP_commandline_string.
* shared/console/uart.c: In IRQ driven mode also
keep reading chars while they are available (fifo
could be enabled).
* ChangeLog: fixed dates; we're 2008 :-)
* include/bsp.h, startup/bspstart.c: confdefs.h now wants
us to use BSP_INTERRUPT_STACK_SIZE instead of
CONFIGURE_INTERRUPT_STACK_MEMORY. Removed reference to
CONFIGURE_INTERRUPT_STACK_MEMORY from bspstart.c
* shared/startup/pretaskinghook.c: install pointer
to rtems_malloc_sbrk_helpers_table. This (and derived)
BSPs rely on sbrk delivering even the first/initial
chunk of memory.
* shared/console/console.c, shared/console/uart.c,
shared/console/uart.h: added support for task-driven
console.
chunk of memory.
* runtest: Skip all fatal error tests.
* start/start.S, startup/bspstart.c: disable memory-select
errors early (in start.S) to avoid hangs due to speculative
memory access (motload maps absent memory in TLBs).
Remove TLB mappings for which no physical memory is installed
(bspstart). Enable HID1[RFXE] so that 'core_fault_in' errors
result in a machine-check rather than stalling the machine.
Re-enable memory-select errors at this point.
* Makefile.am: add e500/mmu.rel to libbsp_a_LIBADD.
* startup/linkcmds: Add wildcard to gcc_except_table section so
programs compiled with gcc 4.3.x can link.
* shared/startup/linkcmds: Add wildcard to gcc_except_table section so
* startup/linkcmds, startup/linkcmds.hsc_cm01,
startup/linkcmds.mpc8349eamds: Add wildcard to gcc_except_table
section so programs compiled with gcc 4.3.x can link.
* startup/linkcmds, startup/linkcmds.brs5l, startup/linkcmds.icecube,
startup/linkcmds.pm520: Add wildcard to gcc_except_table section so
* gen405: Remove (Abandoned).
* helas403: Remove (Abandoned).
* acinclude: Regenerate.
* startup/bspstart.c: Fixes a lockup which occurs when a speculative
load occurs from a particular range of memory.
* Makefile.am: Remove duplicate cases of mmu.rel and timer.rel in list
of objects.
* startup/bspstart.c: Add semicolon.
* startup/bspstart.c: Add bsp_timer_least_valid and
bsp_timer_average_overhead so tmtests link.
* configure.ac, irq/irq.c, startup/bspclean.c, startup/bspstart.c: Add
ALLOW_IRQ_NESTING option. The MPC5200 has a settle time after
acknowledging the IRQs and currently the BSP does not account for
that. After acknowledging an interrupt, it currently gets a second
spurious IRQ a significant percentage of the time. Rename to
BENCHMARK_IRQ_PROCESSING and get it working again. Under one test
load, not nesting interrupts resulted in a 50% reduction in the
number of IRQs and an ~30% reduction in time spent in IRQs.
* include/bsp.h: Include <bsp/vectors.h>.
* bsp_specs: added crtend.o back to the endfiles. Otherwise,
C++ static constructors are not executed because the
call to __do_global_ctors_aux() is emitted into the .init
section by this endfile (yes, the endfile contributes to .init).
