* wrapup/Makefile.am: Eliminate $(LIB).
Use noinst_DATA to trigger building libbsp.a.
* tod/Makefile.am: Cosmetics.
* console/Makefile.am: Eliminate *.rel.
Use $(top_srcdir)/../../shared instead of ../../../shared.
* start/Makefile.am: Add BUILD-VARIANTS.
* vectors/Makefile.am: Fix typos.
* vme/Makefile.am: Fix typos.
* PCI_bus/Makefile.am: Eliminate VPATH.
* clock/Makefile.am: Eliminate VPATH.
* console/Makefile.am: Eliminate VPATH.
* start/Makefile.am: Eliminate VPATH.
* startup/Makefile.am: Eliminate VPATH.
* timer/Makefile.am: Eliminate VPATH.
* tod/Makefile.am: Eliminate VPATH.
* vectors/Makefile.am: Eliminate VPATH.
* shmsupp/Makefile.am: Eliminate VPATH.
* network/Makefile.am: Eliminate VPATH.
* nvram/Makefile.am: Eliminate VPATH.
* pci/Makefile.am: Eliminate VPATH.
* universe/Makefile.am: Eliminate VPATH.
* irq/Makefile.am: Eliminate VPATH.
* bootloader/Makefile.am: Eliminate VPATH.
* motorola/Makefile.am: Eliminate VPATH.
* openpic/Makefile.am: Eliminate VPATH.
* residual/Makefile.am: Eliminate VPATH.
* vme/Makefile.am: Eliminate VPATH.
* ide/Makefile.am: Eliminate VPATH.
* dlentry/Makefile.am: Eliminate VPATH.
* flashentry/Makefile.am: Eliminate VPATH.
* canbus/Makefile.am: Eliminate VPATH.
* scv64/Makefile.am: Eliminate VPATH.
* sonic/Makefile.am: Eliminate VPATH.
PR 545/bsps
* startup/setvec.c: Removed.
PR 545/bsps
PR 545/bsps
* wrapup/Makefile.am: Remove GENERIC_FILES.
PR 333/bsps
* startup/linkcmds: Remove SEARCH_DIR.
* startup/linkcmds.dl: Remove SEARCH_DIR.
* bootloader/Makefile.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g.
* Makefile.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g.
* Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* console/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* irq/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* motorola/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* openpic/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* pci/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* residual/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* vectors/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* bootloader/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* vme/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* Makefile.am: Reworked.
* Makefile.am: Misc cleanups and fixes.
* startup/linkcmds: Preparations for gcc-3.3.x.
* bootloader/Makefile.am: Misc cleanups and fixes.
* motorola/Makefile.am: Misc cleanups and fixes.
* startup/linkcmds: Preparations to gcc-3.3.x.
* startup/Makefile.am: Remove S_FILES (Unused).
* vectors/Makefile.am: Cosmetics.
* Makefile.am: Cosmetics.
* bootloader/Makefile.am: Cosmetics.
Don't preinstall bsp_specs.dl.
* dlentry/Makefile.am: Cosmetics.
* flashentry/Makefile.am: Cosmetics.
