* | build: Remove local.am | Sebastian Huber | 2018-10-10 | 21 | -21/+0 |
* | bsp/tqm8xx: Remove unused files | Sebastian Huber | 2018-09-17 | 1 | -1/+0 |
| | | | | Close #3513. | ||||
* | bsp/tqm8xx: Convert console to new Termios API | Sebastian Huber | 2018-09-17 | 1 | -0/+1 |
| | | | | Update #3513. | ||||
* | bsps: BSP_INTERRUPT_STACK_AT_WORK_AREA_BEGIN | Sebastian Huber | 2018-09-03 | 3 | -9/+0 |
| | | | | | | | Remove the BSP_INTERRUPT_STACK_AT_WORK_AREA_BEGIN hack. The interrupt stacks are now allocated by the linker. Update #3459. | ||||
* | virtex5: Move -Dxxx to configure.ac | Joel Sherrill | 2018-05-18 | 1 | -0/+2 |
| | | | | Updates #3425. | ||||
* | virtex4: Move -Dxxx to configure.ac | Joel Sherrill | 2018-05-18 | 1 | -0/+2 |
* | virtex: Move -Dxxx to configure.ac | Joel Sherrill | 2018-05-18 | 1 | -0/+2 |
* | tqm8xx: Move -Dxxx to configure.ac | Joel Sherrill | 2018-05-18 | 1 | -0/+1 |
* | t32mppc: Move -Dxxx to configure.ac | Joel Sherrill | 2018-05-18 | 1 | -1/+1 |
* | ss555: Move -Dxxx to configure.ac | Joel Sherrill | 2018-05-18 | 1 | -0/+2 |
* | qoriq: Move -Dxxx to configure.ac | Joel Sherrill | 2018-05-18 | 1 | -1/+1 |
* | qemuppc: Move -Dxxx to configure.ac | Joel Sherrill | 2018-05-18 | 1 | -0/+1 |
* | psim: Move -Dxxx to configure.ac | Joel Sherrill | 2018-05-18 | 1 | -0/+2 |
* | mvme5500: Move -Dxxx to configure.ac | Joel Sherrill | 2018-05-18 | 1 | -0/+2 |
* | mvme3100: Move -Dxxx to configure.ac | Joel Sherrill | 2018-05-18 | 1 | -0/+2 |
* | mpc8260ads: Move -Dxxx to configure.ac | Joel Sherrill | 2018-05-18 | 1 | -0/+1 |
* | mpc55xxevb: Move -Dxxx to configure.ac | Joel Sherrill | 2018-05-18 | 1 | -0/+2 |
* | motorola_powerpc: Move -Dxxx to configure.ac | Joel Sherrill | 2018-05-18 | 1 | -0/+14 |
* | haleakala: Move -Dxxx to configure.ac | Joel Sherrill | 2018-05-18 | 1 | -0/+2 |
* | beatnik: Move -Dxxx to configure.ac | Joel Sherrill | 2018-05-18 | 1 | -0/+2 |
* | bsps: Move documentation, etc. files to bsps | Sebastian Huber | 2018-04-26 | 37 | -2816/+0 |
| | | | | | | This patch is a part of the BSP source reorganization. Update #3285. | ||||
* | bsps: Remove unmaintained times files | Sebastian Huber | 2018-04-26 | 2 | -386/+0 |
* | bsps/powerpc: Move bsp-start-zero.S to bsps | Sebastian Huber | 2018-04-26 | 5 | -119/+4 |
* | bsp/psim: Move align_h.S to bsps | Sebastian Huber | 2018-04-26 | 2 | -440/+1 |
* | bsp/haleakala: Move assembler files to bsps | Sebastian Huber | 2018-04-26 | 3 | -322/+2 |
* | bsp/qemuppc: Install linkcmds.base | Sebastian Huber | 2018-04-25 | 1 | -0/+1 |
| | | | | | Update #3339. Close #3411. | ||||
* | bsps: Remove unused u-boot-generic-board-info.h | Sebastian Huber | 2018-04-25 | 1 | -132/+0 |
* | bsp/gen5200: Move source files to bsps | Sebastian Huber | 2018-04-25 | 7 | -3129/+4 |
* | bsp/haleakala: Move mmu_405.c to bsps | Sebastian Huber | 2018-04-25 | 2 | -294/+1 |
* | bsp/beatnik: Move source files to bsps | Sebastian Huber | 2018-04-25 | 8 | -2721/+4 |
* | bsp/mvme3100: Move flashcfg.c to bsps | Sebastian Huber | 2018-04-25 | 2 | -117/+1 |
* | bsp/mvme5500: Move source files to bsps | Sebastian Huber | 2018-04-25 | 4 | -545/+3 |
* | bsp/virtex5: Move mmu.c to bsps | Sebastian Huber | 2018-04-25 | 2 | -582/+1 |
* | bsp/virtex4: Move mmu.c to bsps | Sebastian Huber | 2018-04-25 | 2 | -568/+1 |
* | bsps: Move spansionFlash.c to bsps | Sebastian Huber | 2018-04-24 | 2 | -478/+1 |
* | bsps: Move intelFlash.c to bsps | Sebastian Huber | 2018-04-24 | 2 | -465/+1 |
* | bsps: Move flash.c to bsps | Sebastian Huber | 2018-04-24 | 3 | -911/+2 |
* | bsps: Move vpd.c to bsps | Sebastian Huber | 2018-04-24 | 3 | -324/+2 |
* | bsps: Move motorola.c to bsps | Sebastian Huber | 2018-04-24 | 2 | -433/+1 |
* | bsps: Move residual.c to bsps | Sebastian Huber | 2018-04-24 | 2 | -105/+1 |
* | bsps: Move showbats.c to bsps | Sebastian Huber | 2018-04-24 | 3 | -53/+2 |
* | bsps: Move ppc-exc-handler-table.c to bsps | Sebastian Huber | 2018-04-24 | 4 | -70/+3 |
* | bsps: Move memcpy.c to bsps | Sebastian Huber | 2018-04-24 | 5 | -130/+4 |
* | bsps: Move tictac.c to bsps | Sebastian Huber | 2018-04-24 | 5 | -36/+4 |
* | bsps: Move uboot_dump_bdinfo.c to bsps | Sebastian Huber | 2018-04-24 | 2 | -80/+1 |
* | bsps: Move uboot_getenv.c to bsps | Sebastian Huber | 2018-04-24 | 3 | -76/+2 |
* | bsps/powerpc: Move bootloader to bsps | Sebastian Huber | 2018-04-24 | 19 | -12539/+16 |
| | | | | | | | | This bootloader is only used by the motorola_powerpc BSP. This patch is a part of the BSP source reorganization. Update #3285. | ||||
* | bsps: Remove unmaintained times files | Sebastian Huber | 2018-04-24 | 2 | -376/+0 |
* | bsps: Move ATA drivers to bsps | Sebastian Huber | 2018-04-23 | 6 | -1114/+4 |
* | bsps: Move PCI drivers to bsps | Sebastian Huber | 2018-04-23 | 16 | -2552/+16 |
