by Till Straumann <strauman@SLAC.Stanford.EDU>. With this
patch, the motorola_shared BSP should also support the MVME2303.
cpuopts.h.
exec/configure.in, only.
quoting bugs in autoconf).
formating changes :)
were needed to move exception processing to score/cpu.
from score/cpu to libcpu because the determination of which to use is
based on RTEMS_CPU_MODEL. Thus it can not be determined based solely on
multilib information.
<elkolli@crf.canon.fr> to add support for the mbx860_005b.
_Interrupt_Manager_initialization.
<corsepiu@faw.uni-ulm.de> so these BSPs pick up the
components they need from libcpu.
routine naming to follow RTEMS package/object.method rule.
This patch also eliminated calls to the obsolete routine
m68k_enable_caching.
file to Makefile.am.
responsibility to explicitly pick up the components they
require. This makes it easier to override default implmentations.
significant things:
and PowerPC
same code base.
John reports this works on the 821 and 860.
significant things:
and PowerPC
same code base.
that contains:
* Removes MKLIB
handling)
converted to automake.
Kulpinski <jskulpin@eng01.gdds.com>, the bsp_specs now defines
USE_ENHANCED_INTR_API and powerpc/shared/include/bsp.h uses that
to enable its tm27 support.
interrupt code works on "old buggy MCP750 boards". The symptom was
that there was no ethernet PCI IRQ at all.
the mvme2307 and mcp750 BSPs. In addition, it can support many
Motorola PowerPC based VME and PCI boards.
<valette@crf.canon.fr> and Jay Kulpinski <jskulpin@eng01.gdds.com>.
