* | 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-10-17 | 1 | -0/+9 |
| | | | | | | | | | * clock/clock.c, console/console.c, ide/pcmcia_ide.c, ide/pcmcia_ide.h, irq/irq.c, irq/irq.h, irq/irq_asm.S, irq/irq_init.c, nvram/m93cxx.h, nvram/nvram.c, nvram/nvram.h, slicetimer/slicetimer.c, start/start.S, startup/bspstart.c, startup/cpuinit.c, vectors/vectors.S, vectors/vectors_init.c: Convert to utf-8. | ||||
* | Convert to utf-8. | Ralf Corsepius | 2006-10-17 | 17 | -17/+17 |
* | 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-10-17 | 2 | -2/+4 |
| | | | | * bootloader/Makefile.am: Remove DEFAULT_INCLUDES. | ||||
* | 2006-09-11 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-09-11 | 3 | -4/+9 |
| | | | | | * include/mpc5200.h, network_5200/network.c: Convert C++ style comments to C style. | ||||
* | Remove extra CRLF. | Chris Johns | 2006-09-11 | 1 | -0/+4 |
* | Remove extra CRLF. | Chris Johns | 2006-09-11 | 1 | -189/+189 |
* | 2006-08-23 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-08-23 | 4 | -20/+10 |
| | | | | | * startup/bspstart.c: Revert patch adding new exception support code to an old exception BSP. | ||||
* | 2006-08-22 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-08-22 | 4 | -0/+28 |
| | | | | * startup/bspstart.c: Add basic _BSP_Fatal_error. | ||||
* | * shared/vme/vmeconfig.c: open outbound window | Till Straumann | 2006-08-22 | 2 | -1/+17 |
| | | | | to VME CSR space if the BSP defines _VME_CSR_ON_PCI | ||||
* | 2006-08-15 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-08-15 | 6 | -8/+138 |
| | | | | | | * Makefile.am, preinstall.am, startup/linkcmds, startup/linkcmds.brs5l, startup/linkcmds.pm520: Add support for missing .rela sections. Install linkcmds. | ||||
* | added vectors.h to bsp.h | Thomas Doerfler | 2006-08-13 | 3 | -23/+45 |
| | | | | fixed bug in mscan | ||||
* | * shared/irq/openpic_i8259_irq.c: fixed type of | Till Straumann | 2006-08-11 | 2 | -1/+7 |
| | | | | | 'frame' argument to C_dispatch_irq_handler(). It's really a BSP_Exception_frame*, not a CPU_Interrupt_frame*. | ||||
* | 2006-08-09 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-08-09 | 12 | -51/+282 |
| | | | | * startup/linkcmds: Clean up a bit after adding missing .rela sections. | ||||
* | added startup/linkcmds.brs5l | Thomas Doerfler | 2006-08-07 | 2 | -0/+308 |
* | added ChangeLog entries for PR1117/1118/1119/1120 | Thomas Doerfler | 2006-07-14 | 1 | -0/+42 |
* | * shared/startup/probeMemEnd.c: added paranoia to inline | Till Straumann | 2006-07-12 | 2 | -8/+18 |
| | | | | | | assembly code; added 'memory' clobbers and made sure any registers modified by the 'asm' appear in the output operands. | ||||
* | * shared/startup/panic.c: Fixed compiler warnings. | Till Straumann | 2006-07-12 | 2 | -1/+6 |
* | applied patches for PR1117/1118/1119/1120 | Thomas Doerfler | 2006-07-09 | 13 | -359/+985 |
* | Fix formatting. | Joel Sherrill | 2006-06-21 | 1 | -1/+1 |
* | Indicate that it's ok to use decoupled cycles to access | Till Straumann | 2006-06-19 | 2 | -2/+10 |
| | | | | on-board memory from VME. | ||||
* | Only set/access the _BSP_vme_bridge_irq variable on BSPs that | Till Straumann | 2006-06-19 | 2 | -0/+8 |
| | | | | define BSP_PCI_VME_DRIVER_DOES_EOI and BSP_PIC_DO_EOI. | ||||
* | filter exception vector for altivec and remap 0xf20 to | Till Straumann | 2006-06-19 | 2 | -2/+15 |
| | | | | assigned vector number alias. | ||||
* | fixed compiler warnings (bspIo.h inclusion, cast of number | Till Straumann | 2006-06-19 | 2 | -3/+10 |
| | | | | constants to pointers). Enable L1 cache on mvme2100. | ||||
* | Never allow the FPU to be switched on for integer-only tasks | Till Straumann | 2006-06-19 | 2 | -21/+5 |
| | | | | (new gcc may use FP regs implicitely). | ||||
* | Formatting. | Joel Sherrill | 2006-06-01 | 1 | -0/+6 |
* | Fix formatting. | Joel Sherrill | 2006-04-05 | 1 | -2/+2 |
* | Remove eof include file | Ralf Corsepius | 2006-03-17 | 17 | -17/+0 |
* | 2006-03-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-03-08 | 12 | -6/+31 |
| | | | | * startup/linkcmds: Add .gnu.linkonce.b.* section. | ||||
* | 2006-03-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-03-08 | 2 | -1/+5 |
| | | | | * shared/startup/linkcmds: Add .gnu.linkonce.b.* section. | ||||
* | 2006-03-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-03-08 | 6 | -4/+16 |
| | | | | * startup/linkcmds, startup/linkcmds.dl: Add .gnu.linkonce.b.* section. | ||||
* | 2006-03-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-03-08 | 3 | -2/+9 |
| | | | | | * startup/linkcmds, startup/linkcmds.pm520: Add .gnu.linkonce.b.* section. | ||||
* | 2006-02-13 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 2006-02-14 | 3 | -0/+309 |
| | | | | | | * shared/startup/panic.c, shared/startup/probeMemEnd.c: added code for BSPs to use: panic using printk() to display reason. probeMemEnd() to determine memory size by probing. | ||||
* | 2006-02-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-02-08 | 12 | -30/+50 |
| | | | | * startup/linkcmds: Add sections required by newer gcc versions. | ||||
* | 2006-02-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-02-08 | 2 | -4/+8 |
| | | | | * shared/startup/linkcmds: Add sections required by newer gcc versions. | ||||
* | 2006-02-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-02-08 | 3 | -6/+11 |
| | | | | | * startup/linkcmds, startup/linkcmds.dl: Add sections required by newer gcc versions. | ||||
* | 2006-02-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-02-08 | 3 | -11/+13 |
| | | | | | * startup/linkcmds, startup/linkcmds.pm520: Add sections required by newer gcc versions. | ||||
* | 2006-02-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-02-08 | 2 | -3/+7 |
| | | | | * startup/linkcmds.dl: Add sections required by newer gcc versions. | ||||
* | 2006-02-07 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-02-07 | 2 | -3/+7 |
| | | | | * startup/linkcmds: Add sections to fix C++ linking errors. | ||||
* | 2006-01-23 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-01-23 | 2 | -0/+7 |
| | | | | * runtest: Add pvr setting. | ||||
* | 2006-01-20 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-01-20 | 2 | -2/+94 |
| | | | | | | * psim: Enhance to add limit on how long a single test is allowed to execute. This can be used to significantly enhance the reliability of long batch test runs. | ||||
* | Regenerate. | Ralf Corsepius | 2006-01-14 | 11 | -11/+11 |
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 11 | -0/+36 |
* | Remove all-local:. | Ralf Corsepius | 2006-01-12 | 11 | -22/+0 |
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 11 | -11/+11 |
* | Cleanup. | Ralf Corsepius | 2006-01-12 | 11 | -28/+0 |
* | 2006-01-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-11 | 22 | -44/+55 |
| | | | | | * configure.ac: Remove explicit ampolish3 support (now in RTEMS_BSP_CONFIGURE). | ||||
* | 2006-01-10 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-10 | 33 | -900/+139 |
| | | | | | * configure.ac: Add ampolish3 support. * Makefile.am: Add preinstall.am. | ||||
* | New. | Ralf Corsepius | 2006-01-10 | 11 | -0/+968 |
* | Regenerate. | Ralf Corsepius | 2006-01-10 | 1 | -5/+6 |
* | 2006-01-09 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-01-09 | 3 | -1/+14 |
| | | | | | | PR 858/bsps * Makefile.am: Added vme_am_defs.h; * vme/vmeconfig.c: Added appropriate include files. |
