process was captured as PR50.
* include/bsp.h: Increase the interrupt stack size to 16K.
* ChangeLog, Makefile.am, README, bsp_specs, bsp_specs.dl, configure.ac,
times, dlentry/.cvsignore, dlentry/Makefile.am, dlentry/dlentry.S,
include/bspopts.h.in, include/coverhd.h, startup/.cvsignore,
startup/Makefile.am, startup/bspclean.c, startup/bspstart.c,
startup/linkcmds, startup/linkcmds.dl, startup/setvec.c,
wrapup/.cvsignore, wrapup/Makefile.am: New files that are
part of the new gen405 BSP.
This modification is a submission of the modifications necessary to
* acinclude.m4: Added gen405 BSP.
* ChangeLog: Removed bogus comment on edit of generated file.
* aclocal.m4: Added gen405 BSP.
* include/bsp.h: Modify Install_tm27_vector() so this BSP will link tm27.
* startup/linkcmds: Fix definition of .init and .fini sections so this
BSP will properly link with new __USE_INIT_FINI__ support.
* .cvsignore: Add more entries.
* aclocal.m4: Removed. Should not have been in CVS.
* startup/linkcmds: Added _init and _fini.
* aclocal.m4: Regenerated.
* configure.ac, include/Makefile.am, irq/Makefile.am,
vectors/Makefile.am: Updated to autoconf 2.52.
* include/.cvsignore: Added newly generated files.
* include/bsp.h: Added include of bspopts.h.
* vectors/Makefile.am: Remove bogus VPATH.
* .cvsignore, configure.ac, configure.in, console/.cvsignore,
include/.cvsignore, network/.cvsignore, start/.cvsignore,
startup/.cvsignore, wrapup/.cvsignore: Added .cvsignore
files and other files missed in previous commit.
* mpc8260ads added as new BSP. tm27 reported not to run
at this time.
* ChangeLog, Makefile.am, README, aclocal.m4, bsp_specs,
clock/.cvsignore, clock/Makefile.am, clock/p_clock.c, configure.in,
console/Makefile.am, console/console.c, include/Makefile.am,
include/bsp.h, include/coverhd.h, irq/.cvsignore, irq/Makefile.am,
irq/irq.c, irq/irq.h, irq/irq_asm.S, irq/irq_init.c,
network/Makefile.am, network/README, network/if_hdlcsubr.c,
network/if_hdlcsubr.h, network/network.c, start/Makefile.am,
start/start.S, startup/Makefile.am, startup/bspstart.c,
startup/cpuinit.c, startup/linkcmds, startup/setvec.c, times,
vectors/.cvsignore, vectors/Makefile.am, vectors/vectors.S,
vectors/vectors.h, vectors/vectors_init.c, wrapup/Makefile.am:
New files.
* acinclude.m4: Added mpc8260ads subdirectory.
* Makefile.am, README, configure.ac, new_exception_processing/cpu.h,
shared/include/cpu.h, shared/include/cpuIdent.c, shared/src/cache.c:
Added mpc8260 support.
* clock/p_clock.c, startup/bspstart.c: Fixed typo.
* clock/clock.c, console/debugio.c, include/dmv170.h, startup/setvec.c,
startup/vmeintr.c: Fixed typo.
* clock/p_clock.c: Fixed typo.
* clock/p_clock.c, include/bsp.h, include/coverhd.h,
startup/bspstart.c, startup/bspstart.c.nocache, startup/setvec.c,
startup/start.S: Fixed typo.
* shmsupp/lock.c, shmsupp/mpisr.c: Fixed typo.
* clock/clock.c, console/console.c, console/debugio.c,
console/ns16550cfg.c, console/ns16550cfg.h, console/z85c30cfg.c,
console/z85c30cfg.h, include/bsp.h, startup/bspstart.c,
startup/genpvec.c, startup/rtems-ctor.cc, startup/setvec.c,
timer/timer.c: Fixed typo.
* PCI_bus/PCI.h, clock/clock.c, console/85c30.c, console/console.c,
console/consolebsp.h, console/consolereserveresources.c,
console/tbl85c30.c, include/bsp.h, include/coverhd.h, include/gen1.h,
include/gen2.h, startup/82378zb.c, startup/FPGA.c,
startup/bspstart.c, startup/genpvec.c, startup/setvec.c,
startup/vmeintr.c, timer/timer.c: Fixed typo.
* mpc6xx/clock/c_clock.c, mpc6xx/clock/c_clock.h, mpc8xx/clock/clock.c,
mpc8xx/timer/timer.c, new_exception_processing/cpu.c,
new_exception_processing/cpu.h, new_exception_processing/cpu_asm.S,
old_exception_processing/cpu.c, old_exception_processing/cpu.h,
old_exception_processing/cpu_asm.S, old_exception_processing/rtems.S:
Fixed typo.
* configure.in: Remove.
* console/85c30.c, startup/bspstart.c: Fix references to delay() and
delay_in_bus_cycles() to add rtems_bsp_ prefix.
* acinclude.m4: New file.
* old_exception_processing/cpu.h: Renamed delay() to rtems_bsp_delay().
Renamed delay_in_bus_cycles() to rtems_bsp_delay_in_bus_cycles().
* shared/include/cpu.h: Renamed delay() to rtems_bsp_delay().
* new_exception_processing/Makefile.am: Use 'PREINSTALL_FILES ='.
* old_exception_processing/Makefile.am: Use 'PREINSTALL_FILES ='.
* mpc6xx/mmu/Makefile.am: Use 'PREINSTALL_FILES ='.
* mpc6xx/clock/Makefile.am: Use 'PREINSTALL_FILES ='.
* mpc6xx/exceptions/Makefile.am: Use 'PREINSTALL_FILES ='.
* mpc8xx/include/Makefile.am: Use 'PREINSTALL_FILES ='.
* mpc8xx/exceptions/Makefile.am: Use 'PREINSTALL_FILES ='.
* shared/include/Makefile.am: Use 'PREINSTALL_FILES ='.
* shared/src/Makefile.am: Use 'PREINSTALL_FILES ='.
* shared/src/Makefile.am: Use 'CLEANFILES ='.
* console/Makefile.am: Use 'PREINSTALL_FILES ='.
* residual/Makefile.am: Use 'PREINSTALL_FILES ='.
* irq/Makefile.am: Use 'PREINSTALL_FILES ='.
* motorola/Makefile.am: Use 'PREINSTALL_FILES ='.
* vectors/Makefile.am: Use 'PREINSTALL_FILES ='.
* pci/Makefile.am: Use 'PREINSTALL_FILES ='.
* openpic/Makefile.am: Use 'PREINSTALL_FILES ='.
* bootloader/Makefile.am: Use 'CLEANFILES ='.
* wrapup/Makefile: Use GENERIC_FILES = to make automake-1.5 happy.
* network/network.c: Fix to account for return value when
installing interrupts handler.
* startup/linkcmds: Modified to work better with gcc 2.8.1 and
gnat 3.13p.
* clock/clock.c: Ensure that clock ticks are long enough to
make forward progress. This was modified to improve results
on the RTEMS tests and the ACATS.
gnat 3.13p.
gnat 3.13p.
* include/Makefile.am: Fixed typo.
* configure.in: Remove CONSOLE_USE_POLLED, HAS_RTC.
* console/console.c, include/commproc.h, startup/start.S:
The printk/printf did not work when loaded by EPPCBUG. They did
work when loaded with the BDM debugger. I suspected EPPBUG
made some nasty things like patching Communication processor
microcode... Anyway, the attached patch:
1) Enables to have printk nearly immediately after boot,
2) Make printf work automagically (I do not know why except I make a
different initialization for printk that should be overwritten by
console init later ?)
I let the default to be using EPPCBUG embedded firmware to boot and
using this printk early enabler code (LOADED_BY_EPPCBUG and
EARLY_CONSOLE) are on.
* start/start.S: Increased BAT0 mapping of RAM from 64 meg to
256 meg to allow operation on boards with larger RAM sizes.
* vectors/vectors_init.c: Modified to call 'generic' powerpc
vector function (mpc60x_vector_is_valid) instead of MPC750
specific function to allow operation on boards with CPUs other
than the MPC750.
* configure.in: Add bspopts.h, AC_DEFINE CONSOLE_USE_INTERRUPTS,
* include/.cvsignore: Add bspopts.h*, stamp-h*, coverhd.h, tod.h.
* include/Makefile.am: Use *_HEADERS instead of *H_FILES, New
treatment of tod.h, coverhd.h.
* include/bsp.h: Add include bspopts.h.
