for details.
PR 1929/bsps
* irq/irq_init.c: Fixed warning.
PR 1917/bsps
* Makefile.am, console/consolelite.c: Modifications to add dynamic
tables for libchip serial drivers.
* Makefile.am: Remove references to non-existing files.
* configure.ac: Remove AC_CHECK_SIZEOF([void *]).
* configure.ac: Added AC_CHECK_SIZEOF macro.
* console/consolelite.c, network/xiltemac.c:
Reflect prototypes having changed (Warning removal).
* network/xiltemac.c, startup/bspstart.c: Remove warnings.
* make/custom/virtex.cfg: Remove RTEMS_BSP_FAMILY.
* startup/linkcmds: Add __sbss_start, __sbss_end etc.
* make/custom/virtex.cfg: New (relocated from /make/custom).
* configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
* configure.ac: Rename BSP_BOOTCARD_OPTIONS to
RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs
have the same options.
* Makefile.am: Eliminate unused routine.
* startup/setvec.c: Removed.
* dlentry/dlentry.S: Update for boot_card command line change.
* bsp_specs: Move -e start from *link to *startfile to avoid warning
for undefined entry symbol when linking relocatables with binutils
2.19.
* Makefile.am, preinstall.am: Use shared tm27.h stub.
* include/tm27.h: Removed.
* include/tm27.h: Do not use set_vector.
* Makefile.am: Eliminate bsp.am. Build startup files as side-effect
of building libbspstart.a, using automake-rules.
* Makefile.am: Eliminate *_SOURCES.
* Makefile.am: Move noinst_LIBRARIES = libbsp.a before its
components.
* Makefile.am: Cleanup ../../shared/include/bootcard.h handling.
PR 1322/bsps
* include/bspopts.h.in: Remove.
PR 1322/bsps
* configure.ac, include/bspopts.h.in: Make letting boot_card() handle
work area allocation mandatory. Rename
RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION to BSP_BOOTCARD_OPTIONS.
* Makefile.am, configure.ac, include/bspopts.h.in: Use standardized
bsp_cleanup() which can optionally print a message, poll for user to
press key, and call bsp_reset(). Using this eliminates the various
bsp_cleanup() implementations which had their own implementation and
variety of string constants.
* startup/bspclean.c: Removed.
* include/bsp.h: Remove unnecessary boilerplate comments.
* Makefile.am, startup/linkcmds: Use top level shared
bsp_get_work_area() implementation.
* startup/bspgetworkarea.c: Removed.
* Makefile.am, configure.ac, include/bsp.h, include/bspopts.h.in,
startup/bspstart.c, startup/linkcmds: Add use of bsp_get_work_area()
in its own file and rely on BSP Framework to perform more
initialization.
* startup/bspgetworkarea.c: New file.
* startup/bspstart.c: Convert to "bool".
* console/consolelite.c, opbintctrl/opbintctrl.c:
Add missing prototypes.
* irq/irq_init.c, include/bsp.h:
define BSP_PPC403_CLOCK_HOOK_EXCEPTION
so that we hook the timer exception rather than going
through the interrupt dispatcher.
* startup/bspstart.c: Removed MSR_CE from interrupt
mask - this was set for testing but should not be
in the mask by default.
* Makefile.am, preinstall.am, irq/irq_init.c:
Use low-level exception handling support from
new-exceptions/bspsupport.
* startup/bspstart.c: Removed SPRG0 warning - this BSP
is OK.
Use interrupt stack limits from linker script.
No need to reserve space beyond '_end'. linkcmds now
reserves space below '_end'.
* dlentry/dlentry.S: load R13 with _SDA_BASE_ so that
SVR4-ABI access of short data area works. No support
for R2/sdata2/eabi, so far but that would be easy
(atm R2 is loaded with got address IIRC).
* startup/linkcmds: fixed sdata/sbss areas -- these
must be contiguous for SVR4 complicant access via R13.
Use kludged layout so that sbss, bss, sbss2 are all
contiguous and zeroed by dlentry.S.
Provide _SDA_BASE_ and _SDA2_BASE_ for loading R13 (and
R2 if anyone wants to use EABI).
Make sure interrupt stack is never in heap area by
moving it below '_end'.
Provide symbols for start + end of interrupt stack.
* console/consolelite.c: use base address from RTEMS_XPARAMETERS_H
rather than hardcoded hex number.
