* | libbsp powerpc: Add Doxygen file header to coverhd.h | Cynthia Rempel | 2014-01-14 | 1 | -1/+7 |
* | Add Virtex4 and Virtex5 BSPs | Ric Claus | 2012-03-30 | 1 | -0/+133 |
This commit covers at least PR2020, 2022, and 2023. This patch adds all of the code for both BSPs, modifications to libcpu/powerpc for the ppc440, and some updates to the BSPs from follow up review and testing. These BSPs should be good baselines for future development. The configurations used by Ric are custom and have a non-standard NIC. They also do not have a UART. Thus the current console driver just prints to a RAM buffer. The NIC and UART support are left for future work. When the UART support is added, moving the existing "to RAM" console driver to a shared location is likely desirable because boards with no debug UART port are commonly deployed. This would let printk() go to RAM. |
