CONFIGURE_INTERRUPT_STACK_SIZE
closes #2801.
do
echo $b
# echo $g
-i $b
done
Switched to using the PPC403 clock driver. Added support for the MMU but
didn't enable it by default. Made some functions static to avoid compiler
warnings. Added a README.
Conflicts:
This commit covers at least PR2020, 2022, and 2023. This
patch adds all of the code for both BSPs, modifications
to libcpu/powerpc for the ppc440, and some updates to the
BSPs from follow up review and testing.
These BSPs should be good baselines for future development.
The configurations used by Ric are custom and have a non-standard
NIC. They also do not have a UART. Thus the current console
driver just prints to a RAM buffer.
The NIC and UART support are left for future work. When the UART
support is added, moving the existing "to RAM" console driver to
a shared location is likely desirable because boards with no debug
UART port are commonly deployed. This would let printk() go to RAM.
