Update #3339.
Use only one timer driver variant based on the standard PowerPC time
base.
Update #3285.
The only consumer of this variable was the ppc403 clock driver used by
the
* haleakala,
* virtex, and
* virtex4
BSPs which set bsp_timer_internal_clock unconditionally to true.
Update #3285.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Avoid name conflicts with shared linkcmds.base.
Update #3254.
Simplify bsp_specs
These BSPs all use shared/startup/linkcmds.base and thus needed to be
modified at the same time. Variations in the arguments were reflected
into the BSP specific portions of the linkcmds.
Updates #3520.
BSPs can use the bsp_fatal_extension() to provide BSP-specific fatal
error handling. There is no need for a _BSP_Fatal_error().
Close #3246.
Due to a new rtems_panic() implementation, it is possible to replace the
PowerPC-specific BSP_panic() with rtems_panic(). Remove BSP_panic()
implementations.
Close #3245.
Fix broken RTEMS linker set description introduced by
b618d8cfc54f84d4ed03dc7b7fa510c872e6128a.
Update #2408.
close #2211
The TLS section symbols had wrong values in case of an empty TLS data
section and a nonempty TLS BSS section.
Instead of SPRG0 (= special purpose register 272) use the new global
symbol _PPC_INTERRUPT_DISABLE_MASK to store the interrupt disable mask.
The benefit is that it is now possible to disable interrupts without
further run-time initialization in boot_card().
At least on Freescale e500 cores this leads also to a faster execution
since the mfmsr and mfspr instruction require four cycles to complete.
The instructions to load the mask value can execute while the mfmsr is
in progress.
The work areas (RTEMS work space and C program heap) will be initialized
now in a separate step and are no longer part of
rtems_initialize_data_structures(). Initialization is performed with
tables of Heap_Area entries. This allows usage of scattered memory
areas present on various small scale micro-controllers.
The sbrk() support API changes also. The bsp_sbrk_init() must now deal
with a minimum size for the first memory chunk to take the configured
work space size into account.
Replace the "NIRVANA" region with the more verbose "UNEXPECTED_SECTIONS"
region. Move the region definition into the "linkcmds.base" files.
The clock driver used previously the bsp_clicks_per_usec value. For a
33333333Hz time base frequency this leads to a relative error of one per
cent for example due to integer truncation.
* configure.ac, startup/bspstart.c: Use standard cache BSP options.
PR 1435/bsps
* Makefile.am: Use shared implementation of bsp_idle_thread().
* startup/bspidle.c: Removed.
* Makefile.am, startup/bspstart.c: Rename BSP specific idle thread to
bsp_idle_thread and split into its own file.
* startup/bspidle.c: New file.
* startup/bspgetworkarea.c: Switch from ssize_t to uintptr_t for
bsp_get_work_area() since the work area is larger than a single
allocatable object.
* startup/start.S: Update for boot_card command line change.
* startup/bspstart.c: Change prototype of IDLE thread to consistently
return void * and take a uintptr_t argument.
* startup/bspgetworkarea.c: Change size_t to ssize_t on
bsp_get_work_area(). On 16-bit architectures, size_t can be 16-bits
which would limit the work area to 64K.
* Makefile.am, startup/bspstart.c: Split out bsp_get_work_area() into
its own file and use BSP Framework to perform more initialization.
* startup/bspgetworkarea.c: New file.
added port init, added phy support
init mmu
