* | Regenerate all preinstall.am files. | Chris Johns | 2014-08-29 | 1 | -6/+6 |
| | | | | | With this patch the preinstall.am files are in a set order and not dependent on now perl implements a hash. | ||||
* | bsp/tqm8xx: Install header file <bsp/irq-info.h> | Sebastian Huber | 2012-04-02 | 1 | -0/+4 |
* | 2010-04-30 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2010-04-30 | 1 | -4/+0 |
| | | | | | | * include/irq-config.h: Removed file. * Makefile.am, preinstall.am: Reflect change above. * include/irq.h: Moved defines from 'include/irq-config.h'. | ||||
* | Regenerate. | Ralf Corsepius | 2009-11-07 | 1 | -4/+4 |
* | Update for exception support changes. | Thomas Doerfler | 2009-10-23 | 1 | -8/+0 |
* | interrupt handler type change | Thomas Doerfler | 2009-10-21 | 1 | -0/+4 |
* | 2008-10-02 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-10-02 | 1 | -1/+1 |
| | | | | | * Makefile.am, preinstall.am: Use shared tm27.h stub. * include/tm27.h: Removed. | ||||
* | 2008-09-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-26 | 1 | -4/+8 |
| | | | | * Makefile.am: Cleanup ../../shared/include/bootcard.h handling. | ||||
* | 2008-09-25 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-09-25 | 1 | -7/+2 |
| | | | | * preinstall.am: Regenerated. | ||||
* | added new BSP for TQM8xx boards | Thomas Doerfler | 2008-09-08 | 1 | -0/+104 |
