do
echo $b
# echo $g
-i $b
done
close #2211
Conflicts:
* include/irq-config.h: Removed file.
* Makefile.am, preinstall.am: Reflect change above.
* include/irq.h: Moved defines from 'include/irq-config.h'.
* include/bsp.h: Added missing include.
* Makefile.am, preinstall.am: Use shared tm27.h stub.
* include/tm27.h: Removed.
* include/bsp.h: Remove prototypes of routines in bootcard.h.
* include/bsp.h: Remove unnecessary boilerplate comments.
* include/bsp.h: Eliminate definitions of BSP_LIBIO_MAX_FDS since this
is NOT used anywhere.
added port init, added phy support
init mmu
* .cvsignore, include/.cvsignore: New files.
