Termios notifies now the driver about an inactive transmit with the
length argument set to zero.
Many files had an extra blank line in the license text
found in the file header. This patch removes that line.
* The license and distribution terms for this file may be
* found in the file LICENSE in this distribution or at
* http://www.rtems.com/license/LICENSE.
The script that did this also turned off execute permission
when it was turned on incorrectly.
* console/console.c: Add BSP_poll_char.
* console/console.c: Disable call to rtems_interrupt_catch until it is
fixed.
added port init, added phy support
init mmu
