* | tqm8xx: Move start.S to tqm8xx/start/start.S | Daniel Ramirez | 2013-12-06 | 1 | -1/+1 |
* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 1 | -4/+0 |
* | Revert: Remove CVS Ids | Joel Sherrill | 2012-05-07 | 1 | -0/+4 |
| | | | | | See http://www.rtems.org/pipermail/rtems-devel/2012-May/001006.html for details. | ||||
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 1 | -4/+0 |
* | bsp/tqm8xx: Install header file <bsp/irq-info.h> | Sebastian Huber | 2012-04-02 | 1 | -0/+1 |
* | bsps: Add shared default IRQ handler | Sebastian Huber | 2012-03-24 | 1 | -3/+7 |
* | 2011-06-18 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-06-18 | 1 | -1/+1 |
| | | | | * Makefile.am: Remove references to non-existing files. | ||||
* | 2010-04-30 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2010-04-30 | 1 | -3/+2 |
| | | | | | | * include/irq-config.h: Removed file. * Makefile.am, preinstall.am: Reflect change above. * include/irq.h: Moved defines from 'include/irq-config.h'. | ||||
* | 2009-11-06 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-11-06 | 1 | -2/+3 |
| | | | | | | * configure.ac: Add RTEMS_BSP_LINKCMDS. * Makefile.am: Rework linkcmds handling. * make/custom/tqm8xx.inc: Remove RTEMS_LINKCMDS, LDFLAGS. | ||||
* | Update for exception support changes. | Thomas Doerfler | 2009-10-23 | 1 | -5/+2 |
* | interrupt handler type change | Thomas Doerfler | 2009-10-21 | 1 | -0/+3 |
* | 2009-09-09 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-09-10 | 1 | -3/+4 |
| | | | | | | PR 1435/bsps * Makefile.am: Use shared implementation of bsp_idle_thread(). * startup/bspidle.c: Removed. | ||||
* | 2009-08-26 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-08-26 | 1 | -1/+1 |
| | | | | | | * Makefile.am, startup/bspstart.c: Rename BSP specific idle thread to bsp_idle_thread and split into its own file. * startup/bspidle.c: New file. | ||||
* | 2008-10-02 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-10-02 | 1 | -1/+1 |
| | | | | | * Makefile.am, preinstall.am: Use shared tm27.h stub. * include/tm27.h: Removed. | ||||
* | 2008-09-29 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-29 | 1 | -8/+4 |
| | | | | | * Makefile.am: Eliminate bsp.am. Build startup files as side-effect of building libbspstart.a, using automake-rules. | ||||
* | 2008-09-29 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-29 | 1 | -10/+12 |
| | | | | * Makefile.am: Eliminate *_SOURCES. | ||||
* | 2008-09-29 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-29 | 1 | -3/+4 |
| | | | | | * Makefile.am: Move noinst_LIBRARIES = libbsp.a before its components. | ||||
* | 2008-09-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-26 | 1 | -2/+3 |
| | | | | * Makefile.am: Cleanup ../../shared/include/bootcard.h handling. | ||||
* | 2008-09-24 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-24 | 1 | -14/+12 |
| | | | | * Makefile.am: Eliminates libcpudir. | ||||
* | 2008-09-24 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-24 | 1 | -1/+0 |
| | | | | * Makefile.am: Cosmetics. | ||||
* | 2008-09-16 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-09-16 | 1 | -3/+3 |
| | | | | | | * Makefile.am, startup/bspstart.c: Split out bsp_get_work_area() into its own file and use BSP Framework to perform more initialization. * startup/bspgetworkarea.c: New file. | ||||
* | added new BSP for TQM8xx boards | Thomas Doerfler | 2008-09-08 | 1 | -0/+93 |
