For the SPE support we must store the upper half of r3 as well.
Update #3085.
Update #3239.
Fix link-time error.
Update #3085.
The BSP_output_char should output a char and not mingle with high level
processing, e.g. '\n' to '\r\n' translation. Move this translation to
rtems_putc(). Remove it from all the BSP_output_char implementations.
Close #3122.
Update #3082.
Use a specific define for the interrupt exception frame size.
Update #3082.
Rename ppc_exc_wrap_async_normal to ppc_exc_interrupt to avoid a bit of
obfuscation.
Update #3082.
Change bsp_interrupt_vector_enable() and bsp_interrupt_vector_disable()
to not return a status code. Add bsp_interrupt_assert() and use it to
validate the vector number in the vector enable/disable implementations.
Rename ppc_exc_min_frame to CPU_Interrupt_frame. Move it and the
corresponding defines to <rtems/score/cpuimpl.h>.
Update #2809.
This makes the new Termios devices independent of device major/minor
numbers. It enables BSP independent Termios device drivers which may
reside in the cpukit domain. These drivers require an IMFS and do not
work with the device file system. However, the device file system
should go away in the future.
warnings
Update #2408.
The size of the sample executables without this option were:
131246 2224 134084236 134217706 7ffffea base_sp.exe
145442 2108 134070140 134217690 7ffffda hello.exe
87857 1816 134128016 134217689 7ffffd9 minimum.exe
658358 6206 133553148 134217712 7fffff0 fileio.exe
155574 2320 134059800 134217694 7ffffde nsecs.exe
220670 2600 133994432 134217702 7ffffe6 paranoia.exe
135534 2232 134079948 134217714 7fffff2 ticker.exe
133626 2240 134081828 134217694 7ffffde unlimited.exe
943592 148090 133126008 134217690 7ffffda cxx_iostream.exe
250066 9528 133958096 134217690 7ffffda cdtest.exe
246978 2728 133968004 134217710 7ffffee capture.exe
The size of the sample executables with this option enabled were:
116650 2216 134098828 134217694 7ffffde base_sp.exe
128558 2068 134087092 134217718 7fffff6 hello.exe
47222 1560 134168916 134217698 7ffffe2 minimum.exe
632422 6194 133579072 134217688 7ffffd8 fileio.exe
141782 2312 134073624 134217718 7fffff6 nsecs.exe
206018 2592 134009108 134217718 7fffff6 paranoia.exe
121258 2224 134094220 134217702 7ffffe6 ticker.exe
117378 2216 134098108 134217702 7ffffe6 unlimited.exe
602026 51306 133564344 134217676 7ffffcc cxx_iostream.exe
236658 8188 133972848 134217694 7ffffde cdtest.exe
230070 2688 133984932 134217690 7ffffda capture.exe
Update #2408.
Fix build error introduced in f535fe5311978af53635c2da8e5cb10ef9d78802.
not updated.
The 32-bit ABIs for thread-local storage (TLS) and EABI read-only
small-data area have a conflicting register (r2) usage. Use the System
V small-data instead (here r2 is system reserved).
Instead of SPRG0 (= special purpose register 272) use the new global
symbol _PPC_INTERRUPT_DISABLE_MASK to store the interrupt disable mask.
The benefit is that it is now possible to disable interrupts without
further run-time initialization in boot_card().
At least on Freescale e500 cores this leads also to a faster execution
since the mfmsr and mfspr instruction require four cycles to complete.
The instructions to load the mask value can execute while the mfmsr is
in progress.
This requires at least Binutils 2.24.
Delete ppc_exc_vector_base. Add and use
ppc_exc_initialize_with_vector_base().
In case the VMA and LMA regions differ, the LMA start address is now no
longer aligned with the alignment of the input sections:
http://sourceware.org/bugzilla/show_bug.cgi?id=15222
Conflicts:
Replace the "NIRVANA" region with the more verbose "UNEXPECTED_SECTIONS"
region. Move the region definition into the "linkcmds.base" files.
