path: root/c/src/lib/libbsp/powerpc/support/old_exception_processing/rtems/score (unfollow)
2005-02-15Remove (moved to libcpu).Ralf Corsepius1-156/+0
2005-02-102005-02-10 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius1-9/+3
* cpu.c, cpu_asm.S, irq_stub.S, rtems/score/ppc_offs.h: Remove PPC_ABI_POWEROPEN.
2005-02-092005-02-09 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius1-5/+1
* cpu.c, cpu_asm.S, irq_stub.S, rtems/score/ppc_offs.h: Remove PPC_ABI_GCC27.
2004-04-21Remove stray white spaces.Ralf Corsepius1-7/+7
2002-04-182002-04-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-1219/+0
* rtems/score/cpu.h: Removed. * Makefile.am: Reflect changes above.
2002-04-032001-04-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-1/+1
* Per PR94, all rtems/score/CPUtypes.h are named rtems/score/types.h. * rtems/score/cpu.h: Account for name change.
2001-11-282001-11-28 Joel Sherrill <joel@OARcorp.com>,Joel Sherrill2-4/+7
This was tracked as PR91. * rtems/score/cpu.h: Added CPU_PROVIDES_ISR_IS_IN_PROGRESS macro which is used to specify if the port uses the standard macro for this (FALSE). A TRUE setting indicates the port provides its own implementation. * rtems/score/c_isr.inl: Deleted and contents merged into cpu.c. * cpu.c: Received contents of c_isr.inl. * Makefile.am: Deleted reference to c_isr.inl.
2001-11-202001-11-20 Joel Sherrill <joel@OARcorp.com>Joel Sherrill3-0/+1382
* support/new_exception_processing/configure.ac, support/new_exception_processing/rtems/score/c_isr.inl, support/new_exception_processing/rtems/score/cpu.h, support/old_exception_processing/configure.ac, support/old_exception_processing/rtems/score/c_isr.inl, support/old_exception_processing/rtems/score/cpu.h, support/old_exception_processing/rtems/score/ppc_offs.h: New files missed in previous commit.
