2005-02-12 | 2005-02-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -19/+0 | |
* Makefile.am, configure.ac: Remove (Unused). | |||||
2004-09-24 | Fix typo in previous change. | Ralf Corsepius | 1 | -1/+1 | |
2004-09-24 | 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 1 | -1/+1 | |
* configure.ac: Require automake > 1.9. | |||||
2004-01-30 | 2004-01-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+1 | |
* configure.ac: Add RTEMS_PROG_CCAS. * Makefile.am: Use automake compilation rules. | |||||
2003-12-12 | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -2/+2 | |
* configure.ac: Require automake >= 1.8, autoconf >= 2.59. | |||||
2003-10-22 | 2003-10-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -1/+0 | |
* configure.ac: Remove RTEMS_CANONICAL_HOST. | |||||
2003-10-21 | 2003-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -1/+0 | |
* configure.ac: Remove RTEMS_CHECK_CPU. | |||||
2003-08-11 | 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -1/+1 | |
* configure.ac: Use rtems-bugs@rtems.com as bug report email address. | |||||
2003-03-11 | Merger from rtems-4-6-branch. | Ralf Corsepius | 1 | -1/+0 | |
2003-02-11 | 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -1/+1 | |
* configure.ac: AM_INIT_AUTOMAKE([1.7.2]). | |||||
* configure.ac: AC_PREREQ(2.57). | |||||
2002-12-17 | 2002-12-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -2/+0 | |
* Makefile.am: Don't include @RTEMS_BSP@.cfg. * configure.ac: Remove RTEMS_CHECK_CUSTOM_BSP. | |||||
2002-03-28 | 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -2/+2 | |
* configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * Makefile.am: Remove AUTOMAKE_OPTIONS. | |||||
2001-11-20 | 2001-11-20 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+23 | |
* support/new_exception_processing/configure.ac, support/new_exception_processing/rtems/score/c_isr.inl, support/new_exception_processing/rtems/score/cpu.h, support/old_exception_processing/configure.ac, support/old_exception_processing/rtems/score/c_isr.inl, support/old_exception_processing/rtems/score/cpu.h, support/old_exception_processing/rtems/score/ppc_offs.h: New files missed in previous commit. |
