* cpu.c, cpu_asm.S, irq_stub.S: #include <rtems/powerpc/powerpc.h>.
* Makefile.am, configure.ac: Remove (Unused).
* Makefile.am: Eliminate CFLAGS_OPTIMIZE_V.
* Makefile.am: Remove build-variant support.
* cpu_asm.S: Include <rtems/asm.h> instead of <asm.h>.
* cpu.c: Convert to using c99 fixed size types.
* configure.ac: Add RTEMS_PROG_CCAS.
* Makefile.am: Use automake compilation rules.
* Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* Makefile.am: Remove include_rtems_score_HEADERS.
Reformat for preinstallation dirstamp support.
* Makefile.am: Remove all-local: $(ARCH).
* configure.ac: Remove RTEMS_CANONICAL_HOST.
* configure.ac: Remove RTEMS_CHECK_CPU.
* cpu.c, cpu_asm.S: URL for license changed.
PR 356/bsps
* cpu.c: This patch makes RTEMS/PowerPC eabi compliant.
* Makefile.am: Don't include @RTEMS_BSP@.cfg.
* configure.ac: Remove RTEMS_CHECK_CUSTOM_BSP.
* cpu.c: Currently only the mpc8260 BSP supports interrupt nesting.
NOTE: These needs to be generalized as the patch is applied to other
BSPs.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* Makefile.am: Use .$(OBJEXT) instead of .o.
* cpu.c: Per PR211 fix
saving/restoring floating point context. The fpsave and fprestore
routines are only used in a executing context which _is_ fp and hence
has the FPU enabled. The current behavior required the FPU always to
be on which is very dangerous if lazy context switching is used.
[Joel Note: Some ports explicitly enabled the FPU in the FP save and
restore routines to avoid this.]
The patch also makes sure (on powerpc only) that the FPU is disabled
for integer tasks. Note that this is crucial if deferred fp context
switching is used. Otherwise, fp context corruption may go undetected!
Also note that even tasks which merely push/pop FP registers to/from
the stack without modifying them still MUST be FP tasks - otherwise
(if lazy FP context switching is used), FP register corruption (of
other, FP, tasks may occur)!
Furthermore, (on PPC) by default, lazy FP context save/restore
is _disabled_.
* rtems/score/cpu.h: Removed.
* rtems/score/cpu.h: Account for name change.
This was tracked as PR91.
* rtems/score/c_isr.inl: Deleted and contents merged into cpu.c.
* cpu.c: Received contents of c_isr.inl.
* Makefile.am: Deleted reference to c_isr.inl.
* .cvsignore: Add aclocal.m4, autom4te.*, config.*, configure.
* Makefile.am: Preinstall c_isr.inl (HACK).
* ChangeLog: New file.
