* | Remove. | Ralf Corsepius | 2005-02-12 | 1 | -2/+0 |
* | 2005-02-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-12 | 4 | -29/+19 |
| | | | | | | * Makefile.am: Merge-in wrapup/Makefile.am. * wrapup/Makefile.am: Remove. * configure.ac: Reflect changes above. | ||||
* | 2005-01-07 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-07 | 2 | -4/+8 |
| | | | | * Makefile.am: Eliminate CFLAGS_OPTIMIZE_V. | ||||
* | 2005-01-02 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-03 | 3 | -67/+24 |
| | | | | * Makefile.am, wrapup/Makefile.am: Remove build-variant support. | ||||
* | Remove environ common declaration -- it broke newlib. | Eric Norum | 2004-10-26 | 1 | -2/+0 |
* | 2004-10-20 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-10-20 | 5 | -19/+24 |
| | | | | | * console/console.c, include/bsp.h, startup/bspstart.c, startup/iss555.c: Use POSIX fixed size types. | ||||
* | Fix typo in previous change. | Ralf Corsepius | 2004-09-24 | 1 | -1/+1 |
* | 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-09-24 | 2 | -1/+5 |
| | | | | * configure.ac: Require automake > 1.9. | ||||
* | 2004-04-23 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-23 | 3 | -1/+12 |
| | | | | | | PR 610/bsps * Makefile.am: Add include/tm27.h, Cosmetics. * include/tm27.h: Final cosmetics. | ||||
* | 2004-04-22 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-23 | 3 | -36/+59 |
| | | | | | * include/bsp.h: Split out tmtest27 support. * include/tm27.h: New. | ||||
* | 2004-04-21 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2004-04-21 | 5 | -23/+62 |
| | | | | | | | PR 611/bsps * Makefile.am, include/bsp.h, wrapup/Makefile.am: Follow conventions for tm27 and do not add another macro definition. * startup/tm27supp.c: New file. | ||||
* | 2004-04-21 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-21 | 2 | -10/+5 |
| | | | | | PR 613/bsps * include/bsp.h: Remove MAX_LONG_TEST_DURATION. | ||||
* | 2004-04-21 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-21 | 2 | -1/+5 |
| | | | | | PR 614/bsps * include/bsp.h: Remove MAX_SHORT_TEST_DURATION (Unused). | ||||
* | Remove duplicate white lines. | Ralf Corsepius | 2004-04-21 | 3 | -12/+0 |
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-21 | 8 | -80/+80 |
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-15 | 1 | -1/+0 |
* | 2004-04-13 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-13 | 3 | -3/+7 |
| | | | | * include/bsp.h, startup/start.S: Reflect new locations of cpukit headers. | ||||
* | 2004-04-12 David Querbach <querbach@realtime.bc.ca> | Joel Sherrill | 2004-04-12 | 19 | -0/+2593 |
* .cvsignore, ChangeLog, Makefile.am, README, bsp_specs, configure.ac, times, clock/p_clock.c, console/console.c, include/.cvsignore, include/bsp.h, include/coverhd.h, irq/irq.h, startup/bspstart.c, startup/iss555.c, startup/linkcmds, startup/start.S, wrapup/.cvsignore, wrapup/Makefile.am: New files. |
