do
echo $b
# echo $g
-i $b
done
warning and clean up
not updated.
The TLS section symbols had wrong values in case of an empty TLS data
section and a nonempty TLS BSS section.
This is necessary to add tests that use the cache manager. For example
to get better estimates of worst-case timings.
Conflicts:
for details.
* startup/iss555.c: Update due to API changes.
* beatnik/include/bsp.h, beatnik/irq/irq.h, beatnik/pci/gt_pci_init.c,
ep1a/console/polled_io.c, ep1a/irq/openpic_xxx_irq.c,
gen5200/include/irq.h, gen5200/irq/irq.c, gen5200/startup/bspstart.c,
haleakala/irq/irq.c, mbx8xx/irq/irq.c, mbx8xx/irq/irq.h,
motorola_powerpc/include/bsp.h, mpc8260ads/irq/irq.c,
mpc8260ads/irq/irq.h, mvme3100/include/bsp.h, mvme3100/irq/irq.h,
mvme3100/start/start.S, mvme5500/include/bsp.h, mvme5500/irq/irq.h,
psim/include/bsp.h, psim/include/coverhd.h, psim/irq/irq.h,
psim/shmsupp/addrconv.c, psim/shmsupp/getcfg.c,
psim/startup/linkcmds, psim/tools/psim-gdb-top.in,
psim/tools/psim-top.in, psim/tools/runtest-top.in, qemuppc/irq/irq.h,
score603e/irq/irq.c, shared/bootloader/bootldr.h,
shared/bootloader/em86.c, shared/bootloader/em86real.S,
shared/bootloader/exception.S, shared/bootloader/head.S,
shared/bootloader/lib.c, shared/bootloader/misc.c,
shared/bootloader/mm.c, shared/bootloader/pci.c,
shared/console/console.c, shared/console/consoleIo.h,
shared/console/inch.c, shared/console/keyboard.h,
shared/console/polled_io.c, shared/irq/i8259.c, shared/irq/irq.h,
shared/irq/openpic_i8259_irq.c, shared/motorola/motorola.c,
shared/motorola/motorola.h, shared/openpic/openpic.c,
shared/openpic/openpic.h, shared/pci/pci.c,
shared/residual/residual.c, shared/start/start.S, ss555/irq/irq.h:
Fix typo where license said found in found in.
* console/console.c: Add BSP_poll_char.
* configure.ac: Remove AC_CHECK_SIZEOF([void *]).
* configure.ac: Added AC_CHECK_SIZEOF macro.
* include/bsp.h: Add prototypes for BSP_disconnect_clock_handler,
BSP_connect_clock_handler.
* irq/irq.h, startup/iss555.c, startup/tm27supp.c: Remove warnings.
* make/custom/ss555.cfg: Remove RTEMS_BSP_FAMILY.
* startup/linkcmds: Add sbss section handling.
Misc. sync with binutils's ld-scripts.
* make/custom/ss555.cfg: Remove -D$(RTEMS_BSP_FAMILY) (unused).
* make/custom/ss555.cfg: New (relocated from /make/custom).
* configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
* ep1a/startup/linkcmds, mbx8xx/startup/linkcmds,
score603e/startup/linkcmds, shared/startup/linkcmds,
ss555/startup/linkcmds: Fix typos in .eh_frame sections.
* configure.ac: Rename BSP_BOOTCARD_OPTIONS to
RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs
have the same options.
