2018-04-26 | bsps: Move documentation, etc. files to bsps | Sebastian Huber | 1 | -282/+0 | |
This patch is a part of the BSP source reorganization. Update #3285. | |||||
2018-03-19 | bsp/ss555: Move libcpu content to bsps | Sebastian Huber | 1 | -0/+24 | |
2012-05-11 | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 1 | -4/+0 | |
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed. | |||||
2004-04-12 | 2004-04-12 David Querbach <querbach@realtime.bc.ca> | Joel Sherrill | 1 | -0/+262 | |
* .cvsignore, ChangeLog, Makefile.am, README, bsp_specs, configure.ac, times, clock/p_clock.c, console/console.c, include/.cvsignore, include/bsp.h, include/coverhd.h, irq/irq.h, startup/bspstart.c, startup/iss555.c, startup/linkcmds, startup/start.S, wrapup/.cvsignore, wrapup/Makefile.am: New files. |
