PR 349/bsps
* vme/.cvsignore, vme/Makefile.am, vme/VME.h, vme/VMEConfig.h,
vme/vmeconfig.c: Add glue to the powerpc/shared BSP to use
the vmeUniverse VME-PCI bridge driver.
PR 349/bsps
* console/console.c, console/uart.c, console/uart.h: implement
IOCTLs for the serial (UART) console to install/retrieve a BREAK-IRQ
callback. The callback routine (if installed) is invoked from the
UART ISR when a BREAK interrupt is detected. This can be used
e.g. to enforce a "hotkey" reboot a la vxWorks Ctrl-X (although we
use the serial line break condition) NOTE: The callback runs in
ISR context.
* startup/linkcmds*: Add FreeBSD sysctl() sections.
* bootloader/head.S: Added support for optional debug via PPCbug.
Also turn off mmu/caches for the bootstrap phase, which seems to
cause trouble with the 603. The cpu init functions in the bsp
get all that stuff going properly.
* console/console.c: Removed __assert() which conflicts with newlib.
* irq/irq_init.c, motorola/motorola.c: Support for MTX603e.
* bootloader/em86.c, console/inch.c, console/polled_io.c, irq/irq.c,
motorola/motorola.c, pci/detect_raven_bridge.c,
vectors/vectors_init.c: Removed warnings.
* bootloader/em86real.S: Fix syntax error in comment near line 1185.
Per PR216, "libbsp/powerpc/shared" BSP has been modified considerably
with the goal to make it more flexible and reusable by other
BSPs. The main strategies were:
- eliminate hardcoded base addresses; devices use offsets
and a BSP defined base address.
- separate functionality into different files (e.g. reboot from
inch.c to reboot.c) which can be overridden by a 'derived' BSP.
- separate initialization code into separate files (e.g. PCI
bridge detection/initialization was separated from the more
generic PCI access routines), also to make it easier for
'derived' BSPs to substitute their own initialization code.
There are also a couple of enhancements and fixes:
- IRQ handling code now has a hook for attaching a VME bridge.
- OpenPIC is now explicitely initialized (polarities, senses).
Eliminated the implicit assumption on the presence of an ISA PIC.
- UART and console driver now supports more than 1 port. The current
maximum of 2 can easily be extended by enlarging a table (it
would even be easier if the ISR API was not broken by design).
- fixed polled_io.c so it correctly supports console on COM2
- fixed TLB invalidation code (start.S).
- exception handler prints a stack backtrace.
- added BSP_pciFindDevice() to scan the pci bus for a particular
vendor/device/instance.
* bootloader/misc.c, console/Makefile.am, console/console.c,
console/consoleIo.h, console/inch.c, console/polled_io.c,
console/uart.c, console/uart.h, include/bsp.h, irq/Makefile.am,
irq/irq.c, irq/irq.h, irq/irq_init.c, openpic/openpic.c,
openpic/openpic.h, pci/Makefile.am, pci/pci.c, pci/pci.h,
residual/Makefile.am, start/start.S, startup/bspstart.c,
vectors/vectors.S, vectors/vectors.h, vectors/vectors_init.c:
* startup/linkcmds: In support of gcc 3.1, added one of more
of the sections .jcr, .rodata*, .data.*, .gnu.linkonce.s2.*,
.gnu.linkonce.sb2.*, and .gnu.linkonce.s.*. Spacing corrections
and direction of segments to memory regions may also have been
addressed. This was a sweep across all BSPs.
* bootloader/exception.S: Reflect changes to <rtems/score/cpu.h>.
* bootloader/head.S: Ditto.
* bootloader/misc.c: Ditto.
* console/polled_io.c: Ditto.
* irq/irq.c: Ditto.
* irq/irq_asm.S: Ditto.
* irq/irq_init.c: Include <rtems/bspIo.h>.
* start/start.S: Reflect changes to <rtems/score/cpu.h>.
* vectors/vectors.S: Ditto.
* startup/bspstart.c: Include <libcpu/cpuIdent.h>.
* startup/linkcmds: Per PR170, PR171, and PR172 add .eh_frame
* residual/residual.c: Include <string.h>.
* vectors/vectors_init.c: Include <rtems/bspIo.h> for printk.
* bootloader/mm.c: Ditto.
* bootloader/pci.c: Ditto.
* console/console.c: Ditto.
* openpic/openpic.c: Ditto.
* bootloader/Makefile.am: Remove AUTOMAKE_OPTIONS.
* motorola/Makefile.am: Remove AUTOMAKE_OPTIONS.
* openpic/Makefile.am: Remove AUTOMAKE_OPTIONS.
* pci/Makefile.am: Remove AUTOMAKE_OPTIONS.
* residual/Makefile.am: Remove AUTOMAKE_OPTIONS.
* vectors/Makefile.am: Remove AUTOMAKE_OPTIONS.
* include/Makefile.am: Use _HEADER instead of H_FILES.
* irq/Makefile.am: Ditto.
* openpic/Makefile.am: Ditto.
* include/bsp.h: Include <bspopts.h>.
* startup/linkcmds: Added _init and _fini.
* clock/p_clock.c, startup/bspstart.c: Fixed typo.
* console/Makefile.am: Use 'PREINSTALL_FILES ='.
* residual/Makefile.am: Use 'PREINSTALL_FILES ='.
* irq/Makefile.am: Use 'PREINSTALL_FILES ='.
* motorola/Makefile.am: Use 'PREINSTALL_FILES ='.
* vectors/Makefile.am: Use 'PREINSTALL_FILES ='.
* pci/Makefile.am: Use 'PREINSTALL_FILES ='.
* openpic/Makefile.am: Use 'PREINSTALL_FILES ='.
* start/start.S: Increased BAT0 mapping of RAM from 64 meg to
256 meg to allow operation on boards with larger RAM sizes.
* vectors/vectors_init.c: Modified to call 'generic' powerpc
vector function (mpc60x_vector_is_valid) instead of MPC750
specific function to allow operation on boards with CPUs other
than the MPC750.
* Makefile.am, console/consoleIo.h, include/bsp.h:
These modifications are part of the conversion of the
mpc8xx CPU to the "new exception processing model."
* startup/linkcmds: Added lines so DWARF debug information
would be available. Otherwise gdb complains that the offsets
for the debug info are incorrect and doesn't load the files.
* start/start.S: Include proper files to compile.
by Till Straumann <strauman@SLAC.Stanford.EDU>. With this
patch, the motorola_shared BSP should also support the MVME2303.
converted to automake.
Kulpinski <jskulpin@eng01.gdds.com>, the bsp_specs now defines
USE_ENHANCED_INTR_API and powerpc/shared/include/bsp.h uses that
to enable its tm27 support.
interrupt code works on "old buggy MCP750 boards". The symptom was
that there was no ethernet PCI IRQ at all.
<valette@crf.canon.fr> and Jay Kulpinski <jskulpin@eng01.gdds.com>.
which fixes a couple of bugs in RTEMS's old style Makefile.ins, which
apparently were introduced by moving the start directories and not
having adapted the Makefile.ins.
patch -p1 < rtems-rc-19991203-10.diff
As part of this effort, the mpc750 libcpu code is now shared with the
ppc6xx.
