Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
This bootloader is only used by the motorola_powerpc BSP.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #2408.
This shared powerpc file was only used by this BSP.
Update #3285.
This file was used by this BSP only. Avoid RTEMS_RELLDFLAGS.
Update #3285.
The VME support is only used by powerpc BSPs.
Update #3285.
Started to eliminate warnings and then realized that only one one-line
macro in the file was used by a few files. The rest of the file was
was not needed. Eliminate the file.
Closes #3354.
Close #3322.
Update #3339.
Closes #3307.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Update #3254.
Update #3254.
This header file is only used by motorola_powerpc, so not shared.
Update #3254.
Update #3268.
This collection of BSPs shared the linker script shared/startup/linkcmds.
I renamed that ot shared/startup/linkcmds.share and made a BSP family
specific startup/linkcmds. This was needed because each BSP family had
a different combination of start file name, undefined symbols, etc.
Updates #3520.
Simplify bsp_specs
These BSPs all use shared/startup/linkcmds.base and thus needed to be
modified at the same time. Variations in the arguments were reflected
into the BSP specific portions of the linkcmds.
Updates #3520.
BSPs can use the bsp_fatal_extension() to provide BSP-specific fatal
error handling. There is no need for a _BSP_Fatal_error().
Close #3246.
Due to a new rtems_panic() implementation, it is possible to replace the
PowerPC-specific BSP_panic() with rtems_panic(). Remove BSP_panic()
implementations.
Close #3245.
Fix link-time error on BSPs not using PPC_EXC_CONFIG_USE_FIXED_HANDLER.
Update #3085.
The BSP_output_char should output a char and not mingle with high level
processing, e.g. '\n' to '\r\n' translation. Move this translation to
rtems_putc(). Remove it from all the BSP_output_char implementations.
Close #3122.
Update #3082.
Update #3082.
There is no need to explicitly set the output format and architecture in
the linker script. This enables the usage of this linker script with
the ELFv2 ABI (64-bit).
Update #3082.
Close #3051.
Set the proper output format in the linker script for the bootloader.
Otherwise the generic linker is used since Binutils 2.28 which does not
understand the PowerPC-specific relocations.
