* beatnik/include/bsp.h, beatnik/irq/irq.h, beatnik/pci/gt_pci_init.c,
ep1a/console/polled_io.c, ep1a/irq/openpic_xxx_irq.c,
gen5200/include/irq.h, gen5200/irq/irq.c, gen5200/startup/bspstart.c,
haleakala/irq/irq.c, mbx8xx/irq/irq.c, mbx8xx/irq/irq.h,
motorola_powerpc/include/bsp.h, mpc8260ads/irq/irq.c,
mpc8260ads/irq/irq.h, mvme3100/include/bsp.h, mvme3100/irq/irq.h,
mvme3100/start/start.S, mvme5500/include/bsp.h, mvme5500/irq/irq.h,
psim/include/bsp.h, psim/include/coverhd.h, psim/irq/irq.h,
psim/shmsupp/addrconv.c, psim/shmsupp/getcfg.c,
psim/startup/linkcmds, psim/tools/psim-gdb-top.in,
psim/tools/psim-top.in, psim/tools/runtest-top.in, qemuppc/irq/irq.h,
score603e/irq/irq.c, shared/bootloader/bootldr.h,
shared/bootloader/em86.c, shared/bootloader/em86real.S,
shared/bootloader/exception.S, shared/bootloader/head.S,
shared/bootloader/lib.c, shared/bootloader/misc.c,
shared/bootloader/mm.c, shared/bootloader/pci.c,
shared/console/console.c, shared/console/consoleIo.h,
shared/console/inch.c, shared/console/keyboard.h,
shared/console/polled_io.c, shared/irq/i8259.c, shared/irq/irq.h,
shared/irq/openpic_i8259_irq.c, shared/motorola/motorola.c,
shared/motorola/motorola.h, shared/openpic/openpic.c,
shared/openpic/openpic.h, shared/pci/pci.c,
shared/residual/residual.c, shared/start/start.S, ss555/irq/irq.h:
Fix typo where license said found in found in.
* shared/pci/detect_raven_bridge.c: Fix spelling.
* shared/start/start.S: Remove conflict lines in comments.
* shared/uboot_dump_bdinfo.c: Include <bsp/u-boot.h> if necessary.
* shared/include/u-boot-board-info.h: New file.
* shared/include/u-boot.h: Removed file.
* shared/include/start.h, shared/src/bsp-start-zero.S: New files.
PR 1689/bsps
* shared/flash/intelFlash.c: Scale erase timeout by actual
system clock rate rather than assuming a fixed value.
* shared/console/polled_io.c: Add BSP_poll_char.
* shared/startup/sbrk.c: Make bsp's sbrk a weak reference so that the
test of having sbrk() support in malloc can link.
PR 1606/cpukit
* shared/startup/panic.c: Remove
INTERNAL_ERROR_INVALID_WORKSPACE_ADDRESS since it is not generated.
PR 1583/bsps
* shared/startup/panic.c: Remove reference to ITRON.
* shared/bootloader/em86.c, shared/bootloader/mm.c,
shared/console/polled_io.c, shared/irq/irq_init.c,
shared/startup/bspstart.c: Remove warnings.
* shared/flash/flash.c: Include <unistd.h>.
PR 1483/cpukit
* shared/pci/pci.c: Rename pci_config into rtems_pci_config_t.
* shared/irq/irq_init.c: Add missing initializer.
* shared/start/start.S: Added AltiVec support (initializing
MSR[VE], VSCR and VRSAVE).
* shared/vme/vme_universe.c: moved extern declaration
out of local scope.
* shared/startup/panic.c: Fixed compiler warning.
* shared/startup/probeMemEnd.c: removed __here_s_the_real_end
check. __rtems_end should be good enough.
* shared/start/start.S: Align initial stack to
CPU_STACK_ALIGNMENT.
* shared/startup/probeMemEnd.c: Add missing prototypes.
* shared/startup/pgtbl_setup.c: Fixed compiler warnings
(added prototypes to function declarations etc.)
* shared/start/start.S, shared/startup/bspstart.c:
let 'save_boot_params()' return a pointer to the commandline
saved by the BSP and pass this pointer on to 'boot_card()'.
* shared/startup/linkcmds: Add __SBSS_END__ and __SBSS2_END__.
* shared/startup/zerobss.c: Remove nested externs.
* shared/motorola/motorola.c, shared/vme/vme_universe.c:
* shared/openpic/openpic.c: Make openpic_writefield
static inline (Get rid of GCC warning).
* shared/console/console.c: Reflect termios_baud_to_number having been
renamed to rtems_termios_baud_to_number.
* shared/bootloader/bootldr.h: Change extern inline to static inline.
* shared/openpic/openpic.c: include the more generic <rtems/pci.h>
rather than <bsp/pci.h>.
* irq/openpic_i8259_irq.c: Do not include <bsp/VMEConfig.h>
if the bsp.h defines HAVE_NO_VME so that BSPs w/o VME do not
have to create a dummy VMEConfig.h header.
PR 1435/bsps
* shared/startup/bspidle.c: New file.
* ep1a/startup/linkcmds, mbx8xx/startup/linkcmds,
score603e/startup/linkcmds, shared/startup/linkcmds,
ss555/startup/linkcmds: Fix typos in .eh_frame sections.
* shared/flash/spansionFlash.c: Convert calls to legacy routine
rtems_clock_get( RTEMS_CLOCK_GET_xxx, ..) to rtems_clock_get_xxx().
* shared/startup/bspgetworkarea.c: Switch from ssize_t to uintptr_t for
bsp_get_work_area() since the work area is larger than a single
allocatable object.
* shared/pci/pci.c: Removed warnings.
* shared/start/start.S: Update for boot_card command line change.
PR 1385/cpukit
* shared/irq/irq_asm.S: When the type rtems_boolean was switched to the
C99 bool, the size changed from 4 bytes to 1 byte. The interrupt
dispatching code accesses two boolean variables for scheduling
purposes and the assembly implementations of this code did not get
updated.
robust against erroneous external exception disable times.
* shared/startup/bspgetworkarea.c: Add check to determine if current
stack pointer is in work area.
