* | 2000-09-05 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2000-09-05 | 2 | -3/+6 |
| | | | | * start/start.S: Include proper files to compile. | ||||
* | Adding ChangeLogs. | Joel Sherrill | 2000-08-10 | 1 | -0/+13 |
* | Properly pass argc, argc, and environp to boot_card. | Joel Sherrill | 2000-08-02 | 1 | -0/+6 |
* | Corrected spelling mistake. | Joel Sherrill | 2000-07-24 | 1 | -1/+1 |
* | Patch from Eric Valette <valette@crf.canon.fr> with debugging | Joel Sherrill | 2000-07-24 | 1 | -7/+15 |
| | | | | | by Till Straumann <strauman@SLAC.Stanford.EDU>. With this patch, the motorola_shared BSP should also support the MVME2303. | ||||
* | Added comment. | Joel Sherrill | 2000-07-12 | 2 | -2/+2 |
* | Patch from Eric Valette to do some cleanup. | Joel Sherrill | 2000-06-29 | 3 | -9/+16 |
* | Merged from 4.5.0-beta3a | Joel Sherrill | 2000-06-12 | 19 | -51/+57 |
* | Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 2000-04-13 | 5 | -0/+10 |
| | | | | adds .cvsignore. | ||||
* | Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 2000-04-13 | 8 | -0/+16 |
* | Fixed typo. | Joel Sherrill | 2000-02-08 | 1 | -1/+1 |
* | Patches rtems-rc-20000118-3.diff and rtems-rc-20000118-4.diff from | Joel Sherrill | 2000-01-31 | 12 | -31/+36 |
| | | | | | | | | | | Ralf Corsepius <corsepiu@faw.uni-ulm.de> that contain: * Modifications, (minor) corrections, cleanups to most existing Makefile.ams * Adds automake support to all remaining BSPs which have not yet been converted to automake. * Makefile.am for all remaining wrapup/Makefile.ams | ||||
* | Added include of <bsp/irq.h> per Jay Kulpinski <jskulpin@eng01.gdds.com>. | Joel Sherrill | 2000-01-10 | 1 | -0/+2 |
* | Patch rtems-rc-20000104-12.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-01-10 | 26 | -533/+243 |
| | | | | | | | | which converts the PowerPC BSPs to configuration and more automake. * Besides adding partial automake support, rsp converting all powerpc BSPs to make them compliant to the new configuration scheme, this patch attempts to fix several configuration bugs in powerpc related Makefiles. | ||||
* | Per suggestions of Eric Valette <valette@crf.canon.fr> and Jay | Joel Sherrill | 2000-01-10 | 1 | -3/+3 |
| | | | | | | Kulpinski <jskulpin@eng01.gdds.com>, the bsp_specs now defines USE_ENHANCED_INTR_API and powerpc/shared/include/bsp.h uses that to enable its tm27 support. | ||||
* | Patch from Eric Valette <valette@crf.canon.fr> that makes sure the | Joel Sherrill | 2000-01-10 | 1 | -24/+5 |
| | | | | | interrupt code works on "old buggy MCP750 boards". The symptom was that there was no ethernet PCI IRQ at all. | ||||
* | Added tm27 stuff. | Joel Sherrill | 2000-01-03 | 1 | -0/+48 |
* | Combination of coverhd.h cleanup and MVME23xx/MCP750 patch from Eric Valette | Joel Sherrill | 2000-01-03 | 4 | -7/+68 |
| | | | | <valette@crf.canon.fr> and Jay Kulpinski <jskulpin@eng01.gdds.com>. | ||||
* | Removed as part of moving this driver to libchip. | Joel Sherrill | 1999-12-21 | 2 | -937/+0 |
* | Patch rtems-rc-19991203-10.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1999-12-21 | 3 | -6/+6 |
| | | | | | | | | | | which fixes a couple of bugs in RTEMS's old style Makefile.ins, which apparently were introduced by moving the start directories and not having adapted the Makefile.ins. To apply: patch -p1 < rtems-rc-19991203-10.diff | ||||
* | Merged of mcp750 and mvme2307 BSP by Eric Valette <valette@crf.canon.fr>. | Joel Sherrill | 1999-12-02 | 59 | -0/+23777 |
As part of this effort, the mpc750 libcpu code is now shared with the ppc6xx. |
