* | bsps/powerpc: Fix shared console driver | Sebastian Huber | 2016-07-19 | 1 | -13/+9 |
| | | | | | | The Termios modes are now an emum. Do not use them in #if expressions. Update #2762. | ||||
* | bsps/powerpc: Fix AltiVec enable | Sebastian Huber | 2016-07-19 | 1 | -0/+1 |
| | | | | | | | There must be an isync after the mtmsr to ensure that the AltiVec is enabled for subsequent instructions. Close #2760. | ||||
* | bsps/powerpc: Fix small-data area issue | Sebastian Huber | 2015-07-09 | 1 | -2/+4 |
| | | | | Update #2369. | ||||
* | powerpc/shared/clock/clock.c: Remove unused variable warning | Joel Sherrill | 2015-05-21 | 1 | -1/+0 |
* | bsps: Convert clock drivers to use a timecounter | Alexander Krutwig | 2015-05-20 | 1 | -39/+17 |
| | | | | Update #2271. | ||||
* | powerpc/shared/flash/intelFlash.c: Eliminate use of deprecated method | Joel Sherrill | 2015-03-17 | 1 | -1/+1 |
* | powerpc/shared/flash/intelFlash.c: Do not use rtems_clock_get() | Joel Sherrill | 2015-03-17 | 1 | -1/+1 |
* | powerpc/shared/bootloader/pci.c: Remove warnings | Joel Sherrill | 2015-03-09 | 1 | -2/+2 |
* | bsps/powerpc: Fix conditional compilation | Sebastian Huber | 2015-01-14 | 1 | -3/+1 |
* | bsps/powerpc: Support for 64 byte cache lines | Sebastian Huber | 2015-01-09 | 1 | -6/+23 |
* | bsps/u-boot: Update due to API changes | Sebastian Huber | 2015-01-09 | 2 | -3/+140 |
* | Use fixed-width C99 types for PowerPC in_be16() and co. | Nick Withers | 2014-12-23 | 6 | -29/+31 |
| | | | | | | Also use the const qualifier on the address pointer's target in in_*() Closes #2128 | ||||
* | Move the flash size probe into bankValidate() | Nick Withers | 2014-12-03 | 1 | -4/+5 |
| | | | | Previously, bankValidate() could be called (e.g., BSP_flashWrite() -> regionCheckAndErase() -> argcheck() -> bankValidate()) without the probe having happened. When it then invoked BSP_flashCheckId(), unmapped memory could be read, possibly causing a fatal exception. | ||||
* | powerpc/shared/startup/bspstart.c: Fix warning for mvme2100 | Joel Sherrill | 2014-10-20 | 1 | -1/+1 |
* | powerpc/shared/irq/irq_init.c: Fix warnings | Joel Sherrill | 2014-10-19 | 1 | -1/+1 |
* | powerpc/shared/bootloader: Fix warnings | Joel Sherrill | 2014-10-19 | 3 | -1/+11 |
* | libbsp/powerpc/shared and motorola_powerpc: Fix warnings | Joel Sherrill | 2014-10-19 | 4 | -62/+66 |
* | gen68302/console: Fix warnings | Joel Sherrill | 2014-10-19 | 1 | -299/+0 |
* | powerpc/shared/startup/probeMemEnd.c: Fix warning | Joel Sherrill | 2014-10-19 | 1 | -6/+5 |
* | powerpc/shared/startup/panic.c: Fix set but not used warning | Joel Sherrill | 2014-10-19 | 1 | -0/+2 |
* | libbsp/powerpc/shared/uboot_getenv.c: Fix warnings | Joel Sherrill | 2014-10-16 | 1 | -2/+9 |
* | libbsp/powerpc/shared/startup/zerobss.c: Fix warnings | Joel Sherrill | 2014-10-16 | 1 | -5/+20 |
* | mpc8260 libcpu and mpc6260ads BSP: Fix warnings | Joel Sherrill | 2014-10-16 | 1 | -1/+3 |
* | shared/startup/bspstart.c: Remove myCpu variables and clean up | Joel Sherrill | 2014-10-16 | 1 | -4/+2 |
* | powerpc/shared/clock/clock.c: Remove clock major/minor and clean up | Joel Sherrill | 2014-10-13 | 1 | -153/+158 |
* | powerpc/shared/clock/p_clock.c: Fix warnings | Joel Sherrill | 2014-10-13 | 1 | -12/+17 |
* | powerpc/shared/console: Fix warnings | Joel Sherrill | 2014-10-13 | 2 | -24/+15 |
* | powerpc/shared/startup/pretaskinghook.c: Include <bsp/bootcard.h> | Joel Sherrill | 2014-10-13 | 1 | -2/+5 |
* | powerpc bootloader: Remove warnings | Joel Sherrill | 2014-10-13 | 7 | -29/+57 |
| | | | | | This code is shared by multiple PowerPC BSPs including all motorola_powerpc variants. | ||||
* | libbsp/powerpc/shared: Fix warnings | Joel Sherrill | 2014-10-13 | 4 | -18/+33 |
* | bsp/gen5200: Fix warnings | Sebastian Huber | 2014-10-10 | 2 | -0/+2 |
* | libbsp/powerpc/shared/tod/todcfg.c: Fix method prototype to eliminate warning | Joel Sherrill | 2014-10-09 | 1 | -7/+7 |
* | powerpc/shared/startup/bspstart.c: Add include of <bsp/bootcard.h> to fix ↵ | Joel Sherrill | 2014-10-09 | 1 | -5/+5 |
| | | | | warning and clean up | ||||
* | bsps: Fix TLS support in linker command files | Sebastian Huber | 2014-04-22 | 2 | -2/+6 |
| | | | | | The TLS section symbols had wrong values in case of an empty TLS data section and a nonempty TLS BSS section. | ||||
* | bsps/powerpc: Fix linker command files | Sebastian Huber | 2014-04-01 | 1 | -4/+2 |
* | Change all references of rtems.com to rtems.org. | Chris Johns | 2014-03-21 | 44 | -44/+44 |
* | powerpc: Change interrupt disable implemetation | Sebastian Huber | 2014-02-19 | 1 | -5/+1 |
| | | | | | | | | | | | | Instead of SPRG0 (= special purpose register 272) use the new global symbol _PPC_INTERRUPT_DISABLE_MASK to store the interrupt disable mask. The benefit is that it is now possible to disable interrupts without further run-time initialization in boot_card(). At least on Freescale e500 cores this leads also to a faster execution since the mfmsr and mfspr instruction require four cycles to complete. The instructions to load the mask value can execute while the mfmsr is in progress. | ||||
* | score: Add CPU counter support | Sebastian Huber | 2014-02-14 | 1 | -0/+4 |
| | | | | | | | | | Add a CPU counter interface to allow access to a free-running counter. It is useful to measure short time intervals. This can be used for example to enable profiling of critical low-level functions. Add two busy wait functions rtems_counter_delay_ticks() and rtems_counter_delay_nanoseconds() implemented via the CPU counter. | ||||
* | score: Change debug helper functions | Sebastian Huber | 2014-02-12 | 1 | -1/+1 |
| | | | | | | | | Rename rtems_internal_error_description() to rtems_internal_error_text(). Rename rtems_fatal_source_description() to rtems_fatal_source_text(). Rename rtems_status_code_description() to rtems_status_text(). Remove previous implementation of rtems_status_text(). | ||||
* | bsps: Thread-local storage (TLS) for linkcmds | Sebastian Huber | 2014-02-04 | 2 | -0/+25 |
* | bsps: Fix barrier section definitions | Sebastian Huber | 2014-01-30 | 1 | -3/+3 |
* | powerpc/flash: give string variables const attribute | Nick Withers | 2014-01-23 | 5 | -22/+22 |
* | bsps: Simplify FreeBSD linker sets | Sebastian Huber | 2013-12-16 | 1 | -12/+4 |
* | bsps/powerpc: Use ALIGN_WITH_INPUT | Sebastian Huber | 2013-12-16 | 2 | -140/+101 |
| | | | | This requires at least Binutils 2.24. | ||||
* | doxygen: refactored doxygen in libbsp to illustrate new rule set | Daniel Ramirez | 2013-12-09 | 3 | -7/+22 |
* | powerpc: motorola: Move bspreset.c to startup/ | Chirayu Desai | 2013-12-02 | 1 | -27/+0 |
| | | | | * Move shared/console/bspreset.c to motorola_powerpc/startup/bspreset.c | ||||
* | Include missing <rtems/score/threaddispatch.h> | Sebastian Huber | 2013-07-26 | 1 | -2/+2 |
* | score: Merge sysstate API into one file | Sebastian Huber | 2013-07-24 | 1 | -0/+1 |
* | bsps/powerpc: Avoid placement in small-data area | Ralf Kirchner | 2013-07-05 | 1 | -2/+2 |
* | bsps/powerpc: Update debug sections | Sebastian Huber | 2013-06-28 | 1 | -18/+18 |
