Update #3254.
* shared/vme/VMEConfig.h, shared/vme/vme_universe.c:
added support for Tsi148 bridge; BSP can define which
bridge driver to use from VMEConfig.h.
Added 'err' macro parameter to BSP_VME_INSTALL_IRQ_MGR(err)
macro so that an error status can be passed back.
* shared/vme/VMEConfig.h:
Added more comments about the semantics of the various
symbols BSPs should define in this file.
Removed declarations of BSP_VMEInit(), BSP_VMEIrqMgrInstall().
* shared/vme/vmeconfig.c: declare BSP_VMEInit(),
BSP_VMEIrqMgrInstall() here.
* Makefile.am, shared/vme/README,
* shared/vme/vme_universe_dma.c (added): Added glue code
implementing the VMEDMA.h API using the vmeUniverse driver.
* ep1a/vme/vmeconfig.c, mvme5500/pci/pcifinddevice.c,
* mvme5500/startup/pgtbl_activate.c, mvme5500/vectors/bspException.h,
* mvme5500/vectors/exceptionhandler.c, mvme5500/vme/VME.h,
* mvme5500/vme/vmeconfig.c, score603e/vme/vmeconfig.c, shared/pci/pcifinddevice.c,
* shared/startup/pgtbl_activate.c, shared/startup/pgtbl_setup.c,
* shared/startup/probeMemEnd.c, shared/startup/sbrk.c, shared/vme/VME.h,
* shared/vme/VMEConfig.h, shared/vme/vme_universe.c, shared/vme/vmeconfig.c:
Added SLAC/Stanford Authorship Note / Copyright + Liability Disclaimer.
* shared/vme/vmeconfig.c, shared/vme/vme_universe.c:
use symbolic flag instead of numerical value
(vmeUniverseInstallIrqMgrAlt()). Define __INSIDE_RTEMS_BSP__
before including <bsp/vmeUniverse.h>
* shared/vme/README, shared/vme/vme_universe.c: New files.
* Makefile.am, motorola_powerpc/Makefile.am, mvme5500/vme/vmeconfig.c,
shared/vme/VME.h, shared/vme/VMEConfig.h, shared/vme/vmeconfig.c:
Several VME related upgrades and fixes, hopefully addressing PR#835:
Separated API, API-implementation by a specific VME bridge driver and
BSP-specific configuration of the driver into different files,
describing their purpose in a README. All of these changes use the
upgraded vmeUniverse.c driver.
PR 349/bsps
* vme/.cvsignore, vme/Makefile.am, vme/VME.h, vme/VMEConfig.h,
vme/vmeconfig.c: Add glue to the powerpc/shared BSP to use
the vmeUniverse VME-PCI bridge driver.
