2018-04-20 | bsps: Move startup files to bsps | Sebastian Huber | 1 | -77/+0 | |
Adjust build support files to new directory layout. This patch is a part of the BSP source reorganization. Update #3285. | |||||
2014-10-13 | libbsp/powerpc/shared: Fix warnings | Joel Sherrill | 1 | -1/+3 | |
2012-05-11 | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 1 | -2/+0 | |
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed. | |||||
2009-11-30 | Whitespace removal. | Ralf Corsepius | 1 | -9/+9 | |
2007-01-17 | 2007-01-16 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 1 | -1/+44 | |
* ep1a/vme/vmeconfig.c, mvme5500/pci/pcifinddevice.c, * mvme5500/startup/pgtbl_activate.c, mvme5500/vectors/bspException.h, * mvme5500/vectors/exceptionhandler.c, mvme5500/vme/VME.h, * mvme5500/vme/vmeconfig.c, score603e/vme/vmeconfig.c, shared/pci/pcifinddevice.c, * shared/startup/pgtbl_activate.c, shared/startup/pgtbl_setup.c, * shared/startup/probeMemEnd.c, shared/startup/sbrk.c, shared/vme/VME.h, * shared/vme/VMEConfig.h, shared/vme/vme_universe.c, shared/vme/vmeconfig.c: Added SLAC/Stanford Authorship Note / Copyright + Liability Disclaimer. | |||||
2003-02-20 | 2003-02-20 Till Straumann <strauman@slac.stanford.edu> | Joel Sherrill | 1 | -0/+34 | |
PR 349/bsps * startup/pgtbl_setup.c, startup/pgtbl_activate.c: New files * startup/Makefile.am, startup/bspstart.c, startup/linkcmds: Let the powerpc/shared (+derived) BSPs use pagetable support from libcpu. |
