There must be an isync after the mtmsr to ensure that the AltiVec is
enabled for subsequent instructions.
Close #2760.
* shared/start/start.S, shared/start/preload.S:
Make sure stack is 16-byte aligned and the TOS
is tagged with a NULL pointer (used as a terminator
when printing stack traces).
* beatnik/include/bsp.h, beatnik/irq/irq.h, beatnik/pci/gt_pci_init.c,
ep1a/console/polled_io.c, ep1a/irq/openpic_xxx_irq.c,
gen5200/include/irq.h, gen5200/irq/irq.c, gen5200/startup/bspstart.c,
haleakala/irq/irq.c, mbx8xx/irq/irq.c, mbx8xx/irq/irq.h,
motorola_powerpc/include/bsp.h, mpc8260ads/irq/irq.c,
mpc8260ads/irq/irq.h, mvme3100/include/bsp.h, mvme3100/irq/irq.h,
mvme3100/start/start.S, mvme5500/include/bsp.h, mvme5500/irq/irq.h,
psim/include/bsp.h, psim/include/coverhd.h, psim/irq/irq.h,
psim/shmsupp/addrconv.c, psim/shmsupp/getcfg.c,
psim/startup/linkcmds, psim/tools/psim-gdb-top.in,
psim/tools/psim-top.in, psim/tools/runtest-top.in, qemuppc/irq/irq.h,
score603e/irq/irq.c, shared/bootloader/bootldr.h,
shared/bootloader/em86.c, shared/bootloader/em86real.S,
shared/bootloader/exception.S, shared/bootloader/head.S,
shared/bootloader/lib.c, shared/bootloader/misc.c,
shared/bootloader/mm.c, shared/bootloader/pci.c,
shared/console/console.c, shared/console/consoleIo.h,
shared/console/inch.c, shared/console/keyboard.h,
shared/console/polled_io.c, shared/irq/i8259.c, shared/irq/irq.h,
shared/irq/openpic_i8259_irq.c, shared/motorola/motorola.c,
shared/motorola/motorola.h, shared/openpic/openpic.c,
shared/openpic/openpic.h, shared/pci/pci.c,
shared/residual/residual.c, shared/start/start.S, ss555/irq/irq.h:
Fix typo where license said found in found in.
* shared/start/start.S: Remove conflict lines in comments.
* shared/start/start.S: Added AltiVec support (initializing
MSR[VE], VSCR and VRSAVE).
* shared/start/start.S: Align initial stack to
CPU_STACK_ALIGNMENT.
* shared/start/start.S: Update for boot_card command line change.
* shared/start/start.S, shared/startup/bspgetworkarea.c,
shared/startup/bspstart.c, shared/startup/linkcmds: Modifications
which reflect those tested on psim. Hopefully they work on all
boards. The initialization stack is explicitly declared in the
linkcmds memory layout rather than magic math.
* shared/console/reboot.c, shared/start/start.S: Fixed PR#845;
!!enable MMU!! on mvme2100 - this is very important.
Otherwise, all accesses are write-back cached [incl. memory-mapped devices].
(Prerequisite were the changes to shared/startup/bspstart.c just
below.) Implemented rtemsReboot() for mvme2100.
* mvme5500/start/start.S, shared/start/start.S,
shared/startup/bspstart.c: moved assembly code to C; setdbat now
supports high bats on 7450 CPUs; added argument checking to setdbat;
added getdbat; moved early initialization code (clear_bats) from BSP
to libcpu (CPU_clear_bats_early)
* start/start.S: include <rtems/powerpc/powerpc.h>.
Use PPC_MINIMUM_STACK_FRAME_SIZE instead of
CPU_MINIMUM_STACK_FRAME_SIZE.
* Makefile.am, bootloader/misc.c, bootloader/pci.c, bootloader/pci.h,
console/console.c, console/inch.c, console/reboot.c, console/uart.c,
console/uart.h, irq/irq.c, irq/irq.h, irq/irq_init.c,
motorola/motorola.c, motorola/motorola.h, openpic/openpic.c,
openpic/openpic.h, pci/detect_raven_bridge.c, pci/pci.c,
start/start.S, startup/bspstart.c, vectors/vectors_init.c,
vme/vmeconfig.c: Add MVME2100 BSP and MPC8240 support. There was also
a significant amount of spelling and whitespace cleanup.
* tod/todcfg.c: New file.
* bootloader/exception.S: Include <rtems/asm.h> instead of <asm.h>.
* bootloader/head.S: Include <rtems/asm.h> instead of <asm.h>.
* irq/irq_asm.S: Include <rtems/asm.h> instead of <asm.h>.
* start/rtems_crti.S: Include <rtems/asm.h> instead of <asm.h>.
* start/start.S: Include <rtems/asm.h> instead of <asm.h>.
* vectors/vectors.S: Include <rtems/asm.h> instead of <asm.h>.
* bootloader/bootldr.h, bootloader/em86.c, bootloader/em86real.S,
bootloader/exception.S, bootloader/head.S, bootloader/lib.c,
bootloader/misc.c, bootloader/mm.c, bootloader/pci.c,
clock/p_clock.c, console/console.c, console/consoleIo.h,
console/inch.c, console/keyboard.h, console/polled_io.c,
include/bsp.h, irq/i8259.c, irq/irq.c, irq/irq.h, irq/irq_asm.S,
irq/irq_init.c, motorola/motorola.c, motorola/motorola.h,
openpic/openpic.c, openpic/openpic.h, pci/pci.c, residual/residual.c,
start/start.S, startup/bspstart.c, vectors/vectors.h,
vectors/vectors_init.c: URL for license changed.
PR 356/bsps
This patch makes RTEMS/powerpc/shared EABI compliant.
* irq/irq_init.c, start/Makefile.am, start/start.S, startup/bspstart.c,
startup/pgtbl_setup.c, vectors/vectors.h, vectors/vectors_init.c:
zero_bss() should clear not only bss but sbss and sbss2
also (this is probably a bugfix, as sbss/sbss2 are
probably used even if -msdata=eabi is not specified).
* start/rtems_crti.S: New file which must
be linked immediately after ecrti.o. rtems_crti.o contains
a code snippet who lets __init() return immediately. Also,
a new entry point '_init' to the C++ Ctors is generated
for use by the RTEMS Thread_Handler.
* bootloader/misc.c, console/Makefile.am, console/console.c,
console/consoleIo.h, console/inch.c, console/polled_io.c,
console/uart.c, console/uart.h, include/bsp.h, irq/Makefile.am,
irq/irq.c, irq/irq.h, irq/irq_init.c, openpic/openpic.c,
openpic/openpic.h, pci/Makefile.am, pci/pci.c, pci/pci.h,
residual/Makefile.am, start/start.S, startup/bspstart.c,
vectors/vectors.S, vectors/vectors.h, vectors/vectors_init.c:
Per PR216, "libbsp/powerpc/shared" BSP has been modified considerably
with the goal to make it more flexible and reusable by other
BSPs. The main strategies were:
- eliminate hardcoded base addresses; devices use offsets
and a BSP defined base address.
- separate functionality into different files (e.g. reboot from
inch.c to reboot.c) which can be overridden by a 'derived' BSP.
- separate initialization code into separate files (e.g. PCI
bridge detection/initialization was separated from the more
generic PCI access routines), also to make it easier for
'derived' BSPs to substitute their own initialization code.
There are also a couple of enhancements and fixes:
- IRQ handling code now has a hook for attaching a VME bridge.
- OpenPIC is now explicitely initialized (polarities, senses).
Eliminated the implicit assumption on the presence of an ISA PIC.
- UART and console driver now supports more than 1 port. The current
maximum of 2 can easily be extended by enlarging a table (it
would even be easier if the ISR API was not broken by design).
- fixed polled_io.c so it correctly supports console on COM2
- fixed TLB invalidation code (start.S).
- exception handler prints a stack backtrace.
- added BSP_pciFindDevice() to scan the pci bus for a particular
vendor/device/instance.
* bootloader/exception.S: Reflect changes to <rtems/score/cpu.h>.
* bootloader/head.S: Ditto.
* bootloader/misc.c: Ditto.
* console/polled_io.c: Ditto.
* irq/irq.c: Ditto.
* irq/irq_asm.S: Ditto.
* irq/irq_init.c: Include <rtems/bspIo.h>.
* start/start.S: Reflect changes to <rtems/score/cpu.h>.
* vectors/vectors.S: Ditto.
* start/start.S: Increased BAT0 mapping of RAM from 64 meg to
256 meg to allow operation on boards with larger RAM sizes.
* vectors/vectors_init.c: Modified to call 'generic' powerpc
vector function (mpc60x_vector_is_valid) instead of MPC750
specific function to allow operation on boards with CPUs other
than the MPC750.
* start/start.S: Include proper files to compile.
by Till Straumann <strauman@SLAC.Stanford.EDU>. With this
patch, the motorola_shared BSP should also support the MVME2303.
<valette@crf.canon.fr> and Jay Kulpinski <jskulpin@eng01.gdds.com>.
As part of this effort, the mpc750 libcpu code is now shared with the
ppc6xx.
