Update #3285.
* Makefile.am, motorola_powerpc/Makefile.am,
* shared/pci/detect_raven_bridge.c, Makefile.am,
* shared/pci/generic_clear_hberrs.c: separated the generic
version of _BSP_clear_hostbridge_errors() into its own
file.
