* shared/motorola/motorola.c: removed
PCI_FIXUP_OPT_OVERRIDE_NAME for qemu - qemu gets it
right and this option messes things rather up.
PR 1837/bsps
* shared/motorola/motorola.c, shared/motorola/motorola.h: Add MVME2400
board with 750 CPU to list of supported Motorola boards.
* shared/bootloader/mm.c, shared/bootloader/pci.c,
shared/bootloader/qemu_fakeres.c, shared/bootloader/qemu_fakerom.S,
shared/irq/irq.h, shared/motorola/motorola.c, shared/residual/residual.h,
shared/startup/bspstart.c,
Added 'qemuprep' BSP variant.
* beatnik/include/bsp.h, beatnik/irq/irq.h, beatnik/pci/gt_pci_init.c,
ep1a/console/polled_io.c, ep1a/irq/openpic_xxx_irq.c,
gen5200/include/irq.h, gen5200/irq/irq.c, gen5200/startup/bspstart.c,
haleakala/irq/irq.c, mbx8xx/irq/irq.c, mbx8xx/irq/irq.h,
motorola_powerpc/include/bsp.h, mpc8260ads/irq/irq.c,
mpc8260ads/irq/irq.h, mvme3100/include/bsp.h, mvme3100/irq/irq.h,
mvme3100/start/start.S, mvme5500/include/bsp.h, mvme5500/irq/irq.h,
psim/include/bsp.h, psim/include/coverhd.h, psim/irq/irq.h,
psim/shmsupp/addrconv.c, psim/shmsupp/getcfg.c,
psim/startup/linkcmds, psim/tools/psim-gdb-top.in,
psim/tools/psim-top.in, psim/tools/runtest-top.in, qemuppc/irq/irq.h,
score603e/irq/irq.c, shared/bootloader/bootldr.h,
shared/bootloader/em86.c, shared/bootloader/em86real.S,
shared/bootloader/exception.S, shared/bootloader/head.S,
shared/bootloader/lib.c, shared/bootloader/misc.c,
shared/console/console.c, shared/console/consoleIo.h,
shared/console/inch.c, shared/console/keyboard.h,
shared/console/polled_io.c, shared/irq/i8259.c, shared/irq/irq.h,
shared/irq/openpic_i8259_irq.c, shared/motorola/motorola.c,
shared/motorola/motorola.h, shared/openpic/openpic.c,
shared/openpic/openpic.h, shared/pci/pci.c,
shared/residual/residual.c, shared/start/start.S, ss555/irq/irq.h:
Fix typo where license said found in found in.
* shared/motorola/motorola.c, shared/vme/vme_universe.c:
Add missing prototypes.
PR 1352/bsps
* shared/motorola/motorola.c: Include support for mvme2600/mvme2700.
* shared/motorola/vpd.c, shared/motorola/vpd.h:
added code (originally developed for 'beatnik')
to read MotLoad VPD data from i2c eeprom.
* shared/motorola/motorola.c: removed excess initializer
elements.
* shared/motorola/motorola.c, shared/pci/detect_raven_bridge.c,
shared/pci/pci.c, shared/pci/pci.h, shared/pci/pcifinddevice.c:
Several PCI enhancements and fixes: all BSP flavors now use the
generic clear_hostbridge_errors() routine (this means that only
polling memory probing is possible [see detect_raven_bridge.c for
details]). Interrupt fixup routine now supports multi-function
devices. Interrupt fixup routine now honours a flag/option so that
wrong firmware values can be overridden. Fixed irq routing table for
mvme2100 [PMC]. Added irq routing table for mvme2300. Added a
BSP_pciScan() routine that executes a user callback on each non-empty
slot/fun. Added BSP_pciConfigDump() to display basic config headers.
* Makefile.am, bootloader/misc.c, bootloader/pci.c, bootloader/pci.h,
console/console.c, console/inch.c, console/reboot.c, console/uart.c,
console/uart.h, irq/irq.c, irq/irq.h, irq/irq_init.c,
motorola/motorola.c, motorola/motorola.h, openpic/openpic.c,
openpic/openpic.h, pci/detect_raven_bridge.c, pci/pci.c,
start/start.S, startup/bspstart.c, vectors/vectors_init.c,
vme/vmeconfig.c: Add MVME2100 BSP and MPC8240 support. There was also
a significant amount of spelling and whitespace cleanup.
* tod/todcfg.c: New file.
* Makefile.am: Merge-in bootloader/Makefile.am, clock/Makefile.am,
console/Makefile.am, include/Makefile.am, irq/Makefile.am,
motorola/Makefile.am, openpic/Makefile.am, pci/Makefile.am,
residual/Makefile.am, start/Makefile.am, startup/Makefile.am,
vectors/Makefile.am, vme/Makefile.am. Use automake compilation rules.
* bootloader/Makefile.am, clock/Makefile.am, console/Makefile.am,
include/Makefile.am, irq/Makefile.am, motorola/Makefile.am,
openpic/Makefile.am, pci/Makefile.am, residual/Makefile.am,
start/Makefile.am, startup/Makefile.am, vectors/Makefile.am,
vme/Makefile.am: Remove.
* console/Makefile.am: Add PREINSTALL_DIRS.
* irq/Makefile.am: Add PREINSTALL_DIRS.
* motorola/Makefile.am: Add PREINSTALL_DIRS.
* openpic/Makefile.am: Add PREINSTALL_DIRS.
* pci/Makefile.am: Add PREINSTALL_DIRS.
* residual/Makefile.am: Add PREINSTALL_DIRS.
* vectors/Makefile.am: Add PREINSTALL_DIRS.
* console/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES.
* irq/Makefile.am: Ditto.
* motorola/Makefile.am: Ditto.
* openpic/Makefile.am: Ditto.
* pci/Makefile.am: Ditto.
* residual/Makefile.am: Ditto.
* vectors/Makefile.am: Ditto.
* console/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* irq/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* motorola/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* openpic/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* pci/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* residual/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* vectors/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* bootloader/Makefile.am: Put all files into EXTRA_DIST.
* vme/Makefile.am: Ditto.
* console/Makefile.am: Move H_FILES to include_bsp_HEADERS.
Add preinstallation dirstamp support.
* Makefile.am: Remove empty lines.
* clock/Makefile.am: Ditto.
* include/Makefile.am: Ditto.
* startup/Makefile.am: Ditto.
* bootloader/bootldr.h, bootloader/em86.c, bootloader/em86real.S,
bootloader/exception.S, bootloader/head.S, bootloader/lib.c,
bootloader/misc.c, bootloader/mm.c, bootloader/pci.c,
clock/p_clock.c, console/console.c, console/consoleIo.h,
console/inch.c, console/keyboard.h, console/polled_io.c,
include/bsp.h, irq/i8259.c, irq/irq.c, irq/irq.h, irq/irq_asm.S,
irq/irq_init.c, motorola/motorola.c, motorola/motorola.h,
openpic/openpic.c, openpic/openpic.h, pci/pci.c, residual/residual.c,
start/start.S, startup/bspstart.c, vectors/vectors.h,
vectors/vectors_init.c: URL for license changed.
bootloader/Makefile.am: Reflect having moved automake.
irq/Makefile.am: Reflect having moved automake.
motorola/Makefile.am: Reflect having moved automake.
openpic/Makefile.am: Reflect having moved automake.
pci/Makefile.am: Reflect having moved automake.
residual/Makefile.am: Reflect having moved automake.
vme/Makefile.am: Reflect having moved automake.
PR 405/bsps
* bootloader/pci.c: Added support for configuring devices for pci
busses > 0
* pci/pci.c, pci/pci.h: Added FixupPCI() to store vectors in the
INTERRUPT_LINE register of pci devices any # of hops away
from the host processor.
* motorola/motorola.c, motorola/motorola.h: Added interrupt
routing tables in support of FixupPCI. This is board-specific,
each board will have to supply information for FixupPCI() to do
anything for it.
* startup/bspstart.c: Extended bat2 to cover entire PCI address space.
* irq/irq.c, irq/irq.h: Added support for shared interrupts.
Existing single hander vectors are undisturbed, a new function
added to allow adding/removing handlers from a vector.
* irq/irq_init.c, motorola/motorola.c: Support for MTX603e.
* bootloader/em86.c, console/inch.c, console/polled_io.c, irq/irq.c,
motorola/motorola.c, pci/detect_raven_bridge.c,
vectors/vectors_init.c: Removed warnings.
* console/Makefile.am: Use 'PREINSTALL_FILES ='.
* residual/Makefile.am: Use 'PREINSTALL_FILES ='.
* irq/Makefile.am: Use 'PREINSTALL_FILES ='.
* motorola/Makefile.am: Use 'PREINSTALL_FILES ='.
* vectors/Makefile.am: Use 'PREINSTALL_FILES ='.
* pci/Makefile.am: Use 'PREINSTALL_FILES ='.
* openpic/Makefile.am: Use 'PREINSTALL_FILES ='.
converted to automake.
As part of this effort, the mpc750 libcpu code is now shared with the
ppc6xx.
