Update #3285.
Due to a new rtems_panic() implementation, it is possible to replace the
PowerPC-specific BSP_panic() with rtems_panic(). Remove BSP_panic()
implementations.
Close #3245.
* shared/irq/openpic_i8259_irq.c: silenced compiler warnings.
* shared/irq/init_irq.c, shared/irq/openpic_i8259_irq.c,
shared/pci/detect_raven_bridge.c: conditionally compile
ISA and PCI-interrupt related stuff only if BSP defines
BSP_ISA_IRQ_NUMBER > 0 and/or BSP_PCI_IRQ_NUMBER > 0,
respectively.
* beatnik/include/bsp.h, beatnik/irq/irq.h, beatnik/pci/gt_pci_init.c,
ep1a/console/polled_io.c, ep1a/irq/openpic_xxx_irq.c,
gen5200/include/irq.h, gen5200/irq/irq.c, gen5200/startup/bspstart.c,
haleakala/irq/irq.c, mbx8xx/irq/irq.c, mbx8xx/irq/irq.h,
motorola_powerpc/include/bsp.h, mpc8260ads/irq/irq.c,
mpc8260ads/irq/irq.h, mvme3100/include/bsp.h, mvme3100/irq/irq.h,
mvme3100/start/start.S, mvme5500/include/bsp.h, mvme5500/irq/irq.h,
psim/include/bsp.h, psim/include/coverhd.h, psim/irq/irq.h,
psim/shmsupp/addrconv.c, psim/shmsupp/getcfg.c,
psim/startup/linkcmds, psim/tools/psim-gdb-top.in,
psim/tools/psim-top.in, psim/tools/runtest-top.in, qemuppc/irq/irq.h,
score603e/irq/irq.c, shared/bootloader/bootldr.h,
shared/bootloader/em86.c, shared/bootloader/em86real.S,
shared/bootloader/exception.S, shared/bootloader/head.S,
shared/bootloader/lib.c, shared/bootloader/misc.c,
shared/bootloader/mm.c, shared/bootloader/pci.c,
shared/console/console.c, shared/console/consoleIo.h,
shared/console/inch.c, shared/console/keyboard.h,
shared/console/polled_io.c, shared/irq/i8259.c, shared/irq/irq.h,
shared/irq/openpic_i8259_irq.c, shared/motorola/motorola.c,
shared/motorola/motorola.h, shared/openpic/openpic.c,
shared/openpic/openpic.h, shared/pci/pci.c,
shared/residual/residual.c, shared/start/start.S, ss555/irq/irq.h:
Fix typo where license said found in found in.
* irq/openpic_i8259_irq.c: Do not include <bsp/VMEConfig.h>
if the bsp.h defines HAVE_NO_VME so that BSPs w/o VME do not
have to create a dummy VMEConfig.h header.
* shared/irq/openpic_i8259_irq.c: Line wrap.
* ep1a/irq/irq.c, gen5200/irq/irq.c, gen83xx/irq/irq_init.c,
mbx8xx/irq/irq.c, mpc8260ads/irq/irq.c, mvme5500/irq/irq.c,
psim/irq/no_pic.c, score603e/irq/irq.c, shared/irq/irq_supp.h,
shared/irq/openpic_i8259_irq.c, virtex/irq/irq_init.c:
let C_dispatch_irq_handler() return zero to indicate to
low-level exception handling code that the exception
was handled (not used yet).
* shared/irq/i8259.c, shared/irq/irq.h, shared/irq/irq_supp.h,
shared/irq/openpic_i8259_irq.c: BSP_disable_irq_at_pic(),
openpic_disable_irq(), BSP_irq_disable_at_i8259s() now return
0/1 if irq was disabled/enabled prior to disabling.
irq_supp.h now exports a inline helper routine for scanning
a list of shared handlers; to be used by PIC drivers.
- conditionally define 'irq_mask_or_tbl' only if
BSP_PCI_ISA_BRIDGE_IRQ is defined.
- use _ISR_Get_level() / _ISR_Set_level() for re-enabling
interrupts rather than messing with MSR directly;
these macros:
o implement compiler memory barrier
o will handle multiple levels (e500 'critical' interrupts)
if they are ever supported.
- decrementer irqs are also shareable - added list traversal.
* shared/irq/irq.h, shared/irq/irq.c, shared/irq/irq_init.c,
shared/irq/irq_supp.h (added):
Removed 'is_processor_irq()' from irq.c; the BSP routines
BSP_enable_irq_at_pic()/BSP_disable_irq_at_pic() are required
to ignore processor irqs anyways. Removed
all BSP-defined constants from irq.c. This makes irq.c (almost)
binary-compatible among BSPs (ultimate goal is making 'shared'
a library).
Added a header (irq_supp.h) defining the interface between
the generic interrupt manager (irq.c) and the routines it
requires to be supplied by the BSP (eventually, these
should go into rtems/irq.h).
'frame' argument to C_dispatch_irq_handler(). It's
really a BSP_Exception_frame*, not a CPU_Interrupt_frame*.
* shared/irq/openpic_i8259_irq.c: New file.
* ChangeLog, Makefile.am, motorola_powerpc/ChangeLog,
motorola_powerpc/Makefile.am, shared/irq/irq.c, shared/irq/irq.h,
shared/irq/irq_asm.S, shared/irq/irq_init.c: Separated openpic/i8259
specifica from generic irq handling into openpic_i8259_irq.c; added
some compilation conditionals to help BSPs without ISA to omit ISA
interrupts and calling i8259 code.
