Update #3285.
Due to a new rtems_panic() implementation, it is possible to replace the
PowerPC-specific BSP_panic() with rtems_panic(). Remove BSP_panic()
implementations.
Close #3245.
* shared/irq/init_irq.c, shared/irq/openpic_i8259_irq.c,
shared/pci/detect_raven_bridge.c: conditionally compile
ISA and PCI-interrupt related stuff only if BSP defines
BSP_ISA_IRQ_NUMBER > 0 and/or BSP_PCI_IRQ_NUMBER > 0,
respectively.
* shared/bootloader/em86.c, shared/bootloader/mm.c,
shared/console/polled_io.c, shared/irq/irq_init.c,
shared/startup/bspstart.c: Remove warnings.
* shared/irq/irq_init.c: Add missing initializer.
* shared/openpic/openpic.c shared/openpic/openpic.h,
shared/irq/irq_init.c: added more parameters to
openpic_init() so that more details of the configuration
can be overridden/set from the BSP. Moved setup of
the EPIC-specific EOI delay from BSP code into openpic_init()
using the new 'epic_freq' parameter.
* shared/irq/irq.h, shared/irq/irq.c, shared/irq/irq_init.c,
shared/irq/irq_supp.h (added):
Removed 'is_processor_irq()' from irq.c; the BSP routines
BSP_enable_irq_at_pic()/BSP_disable_irq_at_pic() are required
to ignore processor irqs anyways. Removed
all BSP-defined constants from irq.c. This makes irq.c (almost)
binary-compatible among BSPs (ultimate goal is making 'shared'
a library).
Added a header (irq_supp.h) defining the interface between
the generic interrupt manager (irq.c) and the routines it
requires to be supplied by the BSP (eventually, these
should go into rtems/irq.h).
* irq/irq.h, irq/irq_init.c: Removed the definition
of ASM_IRQ_VECTOR_BASE; this symbol was only use to
initialize the irqBase member of the rtems_irq_global_settings
struct. However, irqBase is an rtems_irq_symbolic_name,
so using BSP_LOWEST_OFFSET is more appropriate.
* shared/irq/irq_init.c, shared/openpic/openpic.h
shared/openpic/openpic.c: The 8240's EPIC has a 'serial'
mode of operation for multiplexing 16 interrupt lines.
This introduces a pipeline delay which can cause
spurious interrupts unless ending the interrupt cycle
(EOI) is delayed accordingly.
* shared/irq/openpic_i8259_irq.c: New file.
* ChangeLog, Makefile.am, motorola_powerpc/ChangeLog,
motorola_powerpc/Makefile.am, shared/irq/irq.c, shared/irq/irq.h,
shared/irq/irq_asm.S, shared/irq/irq_init.c: Separated openpic/i8259
specifica from generic irq handling into openpic_i8259_irq.c; added
some compilation conditionals to help BSPs without ISA to omit ISA
interrupts and calling i8259 code.
* irq/irq_init.c, pci/pci.c, pci/pcifinddevice.c, startup/bspstart.c:
Name change to support common PCI interface
PR 779/bsp
* clock/p_clock.c, console/console.c, console/uart.c, console/uart.h,
irq/irq.c, irq/irq.h, irq/irq_init.c:
powerpc: add parameter to new exception interrupt handlers
* Makefile.am, bootloader/misc.c, bootloader/pci.c, bootloader/pci.h,
console/console.c, console/inch.c, console/reboot.c, console/uart.c,
console/uart.h, irq/irq.c, irq/irq.h, irq/irq_init.c,
motorola/motorola.c, motorola/motorola.h, openpic/openpic.c,
openpic/openpic.h, pci/detect_raven_bridge.c, pci/pci.c,
start/start.S, startup/bspstart.c, vectors/vectors_init.c,
vme/vmeconfig.c: Add MVME2100 BSP and MPC8240 support. There was also
a significant amount of spelling and whitespace cleanup.
* tod/todcfg.c: New file.
* bootloader/bootldr.h, bootloader/em86.c, bootloader/em86real.S,
bootloader/exception.S, bootloader/head.S, bootloader/lib.c,
bootloader/misc.c, bootloader/mm.c, bootloader/pci.c,
clock/p_clock.c, console/console.c, console/consoleIo.h,
console/inch.c, console/keyboard.h, console/polled_io.c,
include/bsp.h, irq/i8259.c, irq/irq.c, irq/irq.h, irq/irq_asm.S,
irq/irq_init.c, motorola/motorola.c, motorola/motorola.h,
openpic/openpic.c, openpic/openpic.h, pci/pci.c, residual/residual.c,
start/start.S, startup/bspstart.c, vectors/vectors.h,
vectors/vectors_init.c: URL for license changed.
PR 379/bsps
* console/polled_io.c: libcpu provides 'printk' already.
Therefore, the implementation in this file was removed (still
used for the bootloader, though). It now provides BSP_output_char()
for libcpu's printk().
* console/uart.c, console/uart.h: BSP_output_char_via_serial()
prototype changed to match the BSP_output_char_function_type. Note
that the motorola BSPs use polled-io for the output_char routine, not
the uart.c version. The latter can be used be other BSPs however
(e.g. SVGM).
* console/console.c, console/consoleIo.h, console/polled_io.c,
irq/irq_init.c, openpic/openpic.c, pci/detect_raven_bridge.c:
Unfortunately, the supported 'printk' format string subset of the
polled-io and libcpu implementations are different - hence, a few
format strings in the ppc/shared BSP were changed.
PR 360/bsps
* irq/irq.c, irq/irq_init.c, openpic/openpic.c, openpic/openpic.h:
BSP code had set the task priority register multiple times of
the OpenPIC instead of setting the individual source priorities.
This patch adds openpic_get_source_priority() and
openpic_set_source_priority() calls and lets IRQ management code
use them.
PR 356/bsps
This patch makes RTEMS/powerpc/shared EABI compliant.
* irq/irq_init.c, start/Makefile.am, start/start.S, startup/bspstart.c,
startup/pgtbl_setup.c, vectors/vectors.h, vectors/vectors_init.c:
zero_bss() should clear not only bss but sbss and sbss2
also (this is probably a bugfix, as sbss/sbss2 are
probably used even if -msdata=eabi is not specified).
* start/rtems_crti.S: New file which must
be linked immediately after ecrti.o. rtems_crti.o contains
a code snippet who lets __init() return immediately. Also,
a new entry point '_init' to the C++ Ctors is generated
for use by the RTEMS Thread_Handler.
PR 349/bsps
* console/console.c, console/uart.c, console/uart.h: implement
IOCTLs for the serial (UART) console to install/retrieve a BREAK-IRQ
callback. The callback routine (if installed) is invoked from the
UART ISR when a BREAK interrupt is detected. This can be used
e.g. to enforce a "hotkey" reboot a la vxWorks Ctrl-X (although we
use the serial line break condition) NOTE: The callback runs in
ISR context.
* irq/irq_init.c, motorola/motorola.c: Support for MTX603e.
* bootloader/misc.c, console/Makefile.am, console/console.c,
console/consoleIo.h, console/inch.c, console/polled_io.c,
console/uart.c, console/uart.h, include/bsp.h, irq/Makefile.am,
irq/irq.c, irq/irq.h, irq/irq_init.c, openpic/openpic.c,
openpic/openpic.h, pci/Makefile.am, pci/pci.c, pci/pci.h,
residual/Makefile.am, start/start.S, startup/bspstart.c,
vectors/vectors.S, vectors/vectors.h, vectors/vectors_init.c:
Per PR216, "libbsp/powerpc/shared" BSP has been modified considerably
with the goal to make it more flexible and reusable by other
BSPs. The main strategies were:
- eliminate hardcoded base addresses; devices use offsets
and a BSP defined base address.
- separate functionality into different files (e.g. reboot from
inch.c to reboot.c) which can be overridden by a 'derived' BSP.
- separate initialization code into separate files (e.g. PCI
bridge detection/initialization was separated from the more
generic PCI access routines), also to make it easier for
'derived' BSPs to substitute their own initialization code.
There are also a couple of enhancements and fixes:
- IRQ handling code now has a hook for attaching a VME bridge.
- OpenPIC is now explicitely initialized (polarities, senses).
Eliminated the implicit assumption on the presence of an ISA PIC.
- UART and console driver now supports more than 1 port. The current
maximum of 2 can easily be extended by enlarging a table (it
would even be easier if the ISR API was not broken by design).
- fixed polled_io.c so it correctly supports console on COM2
- fixed TLB invalidation code (start.S).
- exception handler prints a stack backtrace.
- added BSP_pciFindDevice() to scan the pci bus for a particular
vendor/device/instance.
* bootloader/exception.S: Reflect changes to <rtems/score/cpu.h>.
* bootloader/head.S: Ditto.
* bootloader/misc.c: Ditto.
* console/polled_io.c: Ditto.
* irq/irq.c: Ditto.
* irq/irq_asm.S: Ditto.
* irq/irq_init.c: Include <rtems/bspIo.h>.
* start/start.S: Reflect changes to <rtems/score/cpu.h>.
* vectors/vectors.S: Ditto.
interrupt code works on "old buggy MCP750 boards". The symptom was
that there was no ethernet PCI IRQ at all.
<valette@crf.canon.fr> and Jay Kulpinski <jskulpin@eng01.gdds.com>.
As part of this effort, the mpc750 libcpu code is now shared with the
ppc6xx.
