This header file is only used by motorola_powerpc, so not shared.
Update #3254.
Update #3268.
* shared/bootloader/mm.c, shared/bootloader/pci.c,
shared/bootloader/qemu_fakeres.c, shared/bootloader/qemu_fakerom.S,
shared/irq/irq.h, shared/motorola/motorola.c, shared/residual/residual.h,
shared/startup/bspstart.c,
Added 'qemuprep' BSP variant.
* beatnik/include/bsp.h, beatnik/irq/irq.h, beatnik/pci/gt_pci_init.c,
ep1a/console/polled_io.c, ep1a/irq/openpic_xxx_irq.c,
gen5200/include/irq.h, gen5200/irq/irq.c, gen5200/startup/bspstart.c,
haleakala/irq/irq.c, mbx8xx/irq/irq.c, mbx8xx/irq/irq.h,
motorola_powerpc/include/bsp.h, mpc8260ads/irq/irq.c,
mpc8260ads/irq/irq.h, mvme3100/include/bsp.h, mvme3100/irq/irq.h,
mvme3100/start/start.S, mvme5500/include/bsp.h, mvme5500/irq/irq.h,
psim/include/bsp.h, psim/include/coverhd.h, psim/irq/irq.h,
psim/shmsupp/addrconv.c, psim/shmsupp/getcfg.c,
psim/startup/linkcmds, psim/tools/psim-gdb-top.in,
psim/tools/psim-top.in, psim/tools/runtest-top.in, qemuppc/irq/irq.h,
score603e/irq/irq.c, shared/bootloader/bootldr.h,
shared/bootloader/em86.c, shared/bootloader/em86real.S,
shared/bootloader/exception.S, shared/bootloader/head.S,
shared/bootloader/lib.c, shared/bootloader/misc.c,
shared/console/console.c, shared/console/consoleIo.h,
shared/console/inch.c, shared/console/keyboard.h,
shared/console/polled_io.c, shared/irq/i8259.c, shared/irq/irq.h,
shared/irq/openpic_i8259_irq.c, shared/motorola/motorola.c,
shared/motorola/motorola.h, shared/openpic/openpic.c,
shared/openpic/openpic.h, shared/pci/pci.c,
shared/residual/residual.c, shared/start/start.S, ss555/irq/irq.h:
Fix typo where license said found in found in.
* shared/irq/i8259.c, shared/irq/irq.h, shared/irq/irq_supp.h,
shared/irq/openpic_i8259_irq.c: BSP_disable_irq_at_pic(),
openpic_disable_irq(), BSP_irq_disable_at_i8259s() now return
0/1 if irq was disabled/enabled prior to disabling.
irq_supp.h now exports a inline helper routine for scanning
a list of shared handlers; to be used by PIC drivers.
* shared/irq/irq.h, shared/irq/irq.c, shared/irq/irq_init.c,
shared/irq/irq_supp.h (added):
Removed 'is_processor_irq()' from irq.c; the BSP routines
BSP_enable_irq_at_pic()/BSP_disable_irq_at_pic() are required
to ignore processor irqs anyways. Removed
all BSP-defined constants from irq.c. This makes irq.c (almost)
binary-compatible among BSPs (ultimate goal is making 'shared'
a library).
Added a header (irq_supp.h) defining the interface between
the generic interrupt manager (irq.c) and the routines it
requires to be supplied by the BSP (eventually, these
should go into rtems/irq.h).
* irq/irq.h, irq/irq_init.c: Removed the definition
of ASM_IRQ_VECTOR_BASE; this symbol was only use to
initialize the irqBase member of the rtems_irq_global_settings
struct. However, irqBase is an rtems_irq_symbolic_name,
so using BSP_LOWEST_OFFSET is more appropriate.
* shared/irq/openpic_i8259_irq.c: New file.
* ChangeLog, Makefile.am, motorola_powerpc/ChangeLog,
motorola_powerpc/Makefile.am, shared/irq/irq.c, shared/irq/irq.h,
shared/irq/irq_asm.S, shared/irq/irq_init.c: Separated openpic/i8259
specifica from generic irq handling into openpic_i8259_irq.c; added
some compilation conditionals to help BSPs without ISA to omit ISA
interrupts and calling i8259 code.
* mvme5500/irq/irq.h, psim/irq/irq.h, shared/console/uart.c,
shared/irq/irq.h: Renamed BSP_ISA_UART_COMx_IRQ -> BSP_UART_COMx_IRQ
(uart driver is ISA independent).
Removed ugly #ifdef mvme2100. Added test for
BSP_UART_USE_SHARED_IRQS symbol which a BSP can define to request
that the serial interrupt be shared.
* clock/p_clock.c, irq/i8259.c, irq/irq.c, irq/irq.h: Modified to use
rtems/irq.h.
PR 779/bsp
* clock/p_clock.c, console/console.c, console/uart.c, console/uart.h,
irq/irq.c, irq/irq.h, irq/irq_init.c:
powerpc: add parameter to new exception interrupt handlers
* Makefile.am, bootloader/misc.c, bootloader/pci.c, bootloader/pci.h,
console/console.c, console/inch.c, console/reboot.c, console/uart.c,
console/uart.h, irq/irq.c, irq/irq.h, irq/irq_init.c,
motorola/motorola.c, motorola/motorola.h, openpic/openpic.c,
openpic/openpic.h, pci/detect_raven_bridge.c, pci/pci.c,
start/start.S, startup/bspstart.c, vectors/vectors_init.c,
vme/vmeconfig.c: Add MVME2100 BSP and MPC8240 support. There was also
a significant amount of spelling and whitespace cleanup.
* tod/todcfg.c: New file.
PR 510/bsps
* irq/irq.h: Add extern C wrapper.
* bootloader/bootldr.h, bootloader/em86.c, bootloader/em86real.S,
bootloader/exception.S, bootloader/head.S, bootloader/lib.c,
bootloader/misc.c, bootloader/mm.c, bootloader/pci.c,
clock/p_clock.c, console/console.c, console/consoleIo.h,
console/inch.c, console/keyboard.h, console/polled_io.c,
include/bsp.h, irq/i8259.c, irq/irq.c, irq/irq.h, irq/irq_asm.S,
irq/irq_init.c, motorola/motorola.c, motorola/motorola.h,
openpic/openpic.c, openpic/openpic.h, pci/pci.c, residual/residual.c,
start/start.S, startup/bspstart.c, vectors/vectors.h,
vectors/vectors_init.c: URL for license changed.
PR 405/bsps
* bootloader/pci.c: Added support for configuring devices for pci
busses > 0
* pci/pci.c, pci/pci.h: Added FixupPCI() to store vectors in the
INTERRUPT_LINE register of pci devices any # of hops away
from the host processor.
* motorola/motorola.c, motorola/motorola.h: Added interrupt
routing tables in support of FixupPCI. This is board-specific,
each board will have to supply information for FixupPCI() to do
anything for it.
* startup/bspstart.c: Extended bat2 to cover entire PCI address space.
* irq/irq.c, irq/irq.h: Added support for shared interrupts.
Existing single hander vectors are undisturbed, a new function
added to allow adding/removing handlers from a vector.
* bootloader/misc.c, console/Makefile.am, console/console.c,
console/consoleIo.h, console/inch.c, console/polled_io.c,
console/uart.c, console/uart.h, include/bsp.h, irq/Makefile.am,
irq/irq.c, irq/irq.h, irq/irq_init.c, openpic/openpic.c,
openpic/openpic.h, pci/Makefile.am, pci/pci.c, pci/pci.h,
residual/Makefile.am, start/start.S, startup/bspstart.c,
vectors/vectors.S, vectors/vectors.h, vectors/vectors_init.c:
Per PR216, "libbsp/powerpc/shared" BSP has been modified considerably
with the goal to make it more flexible and reusable by other
BSPs. The main strategies were:
- eliminate hardcoded base addresses; devices use offsets
and a BSP defined base address.
- separate functionality into different files (e.g. reboot from
inch.c to reboot.c) which can be overridden by a 'derived' BSP.
- separate initialization code into separate files (e.g. PCI
bridge detection/initialization was separated from the more
generic PCI access routines), also to make it easier for
'derived' BSPs to substitute their own initialization code.
There are also a couple of enhancements and fixes:
- IRQ handling code now has a hook for attaching a VME bridge.
- OpenPIC is now explicitely initialized (polarities, senses).
Eliminated the implicit assumption on the presence of an ISA PIC.
- UART and console driver now supports more than 1 port. The current
maximum of 2 can easily be extended by enlarging a table (it
would even be easier if the ISR API was not broken by design).
- fixed polled_io.c so it correctly supports console on COM2
- fixed TLB invalidation code (start.S).
- exception handler prints a stack backtrace.
- added BSP_pciFindDevice() to scan the pci bus for a particular
vendor/device/instance.
As part of this effort, the mpc750 libcpu code is now shared with the
ppc6xx.
moves pieces of the pc386 bsp up to a shared level for all i386 BSPs
and modifies the i386ex BSP to use those shared pieces. Serial remote
debugging is included for both targets. Erik's notes:
There are several workarounds in it:
1) #define NEXT_GAS is hardcoded in pc386/start/start.s
2) #define NEXT_GAS is hardcoded in i386ex/start/start.s
3) #define NEW_GAS is hardcoded in pc386/start16.s
4) #undef __assert and redeclare _assert hardcoded in console.c for
both pc386 and i386ex due to my egcs1.1b ~ newlib problem. Should have
modified t-rtems.cfg ( no time )
I've tested pc386 with both video and serial consoles and GDB remote.
All work fine, except that GDB acts weird. ( re: other posting)
I hope this will work for you. It took quite some time to locate the
autoconf error. The remainder was just grunt work.
Unfortunately, I think I've unwound the removal of the IBMPCInitVideo
stuff. Sorry. I REALLY can't spend more time... I've been at this
conversion to 4.0 locally and updating the release since Sept. 8th, and
have yet to compile my network driver.... This is as much as I can do
right now.
I look forward to the next patch to really test i368ex. I did make sure
that the sample tests worked for pc386.
inline with the new IRQ structure.
of theses targets...
