These modifications were required by hand after running the script.
In some cases, the file names did not match patterns. In others,
the format of the file did not match any common patterns.
* shared/bootloader/exception.S, shared/bootloader/misc.c,
shared/bootloader/mm.c, shared/console/polled_io.c,
shared/startup/probeMemEnd.c: Update due to API changes.
* shared/bootloader/qemu_fakerom.S: Added work-around for
qemu bug 811683.
* shared/bootloader/head.S: disable USE_PPCBUG under qemu.
* shared/bootloader/mm.c, shared/bootloader/pci.c,
shared/bootloader/qemu_fakeres.c, shared/bootloader/qemu_fakerom.S,
shared/irq/irq.h, shared/motorola/motorola.c, shared/residual/residual.h,
shared/startup/bspstart.c,
Added 'qemuprep' BSP variant.
* shared/bootloader/misc.c: Copy residual data
_before_ decompressing the kernel since the firmware
may have stored it in an area that is overwritten
by decompress_kernel().
* beatnik/include/bsp.h, beatnik/irq/irq.h, beatnik/pci/gt_pci_init.c,
ep1a/console/polled_io.c, ep1a/irq/openpic_xxx_irq.c,
gen5200/include/irq.h, gen5200/irq/irq.c, gen5200/startup/bspstart.c,
haleakala/irq/irq.c, mbx8xx/irq/irq.c, mbx8xx/irq/irq.h,
motorola_powerpc/include/bsp.h, mpc8260ads/irq/irq.c,
mpc8260ads/irq/irq.h, mvme3100/include/bsp.h, mvme3100/irq/irq.h,
mvme3100/start/start.S, mvme5500/include/bsp.h, mvme5500/irq/irq.h,
psim/include/bsp.h, psim/include/coverhd.h, psim/irq/irq.h,
psim/shmsupp/addrconv.c, psim/shmsupp/getcfg.c,
psim/startup/linkcmds, psim/tools/psim-gdb-top.in,
psim/tools/psim-top.in, psim/tools/runtest-top.in, qemuppc/irq/irq.h,
score603e/irq/irq.c, shared/bootloader/bootldr.h,
shared/bootloader/em86.c, shared/bootloader/em86real.S,
shared/bootloader/exception.S, shared/bootloader/head.S,
shared/bootloader/lib.c, shared/bootloader/misc.c,
shared/console/console.c, shared/console/consoleIo.h,
shared/console/inch.c, shared/console/keyboard.h,
shared/console/polled_io.c, shared/irq/i8259.c, shared/irq/irq.h,
shared/irq/openpic_i8259_irq.c, shared/motorola/motorola.c,
shared/motorola/motorola.h, shared/openpic/openpic.c,
shared/openpic/openpic.h, shared/pci/pci.c,
shared/residual/residual.c, shared/start/start.S, ss555/irq/irq.h:
Fix typo where license said found in found in.
* shared/bootloader/em86.c, shared/bootloader/mm.c,
shared/console/polled_io.c, shared/irq/irq_init.c,
shared/startup/bspstart.c: Remove warnings.
* shared/bootloader/bootldr.h: Change extern inline to static inline.
* shared/bootloader/misc.c, shared/console/polled_io.c,
shared/residual/residual.c: silenced compiler warnings (type cast &
renaming puts->my_puts)
* bootloader/bootldr.h, bootloader/em86.c, bootloader/misc.c,
bootloader/pci.c, bootloader/pci.h: Modified to depend upon
rtems/pci.h
Eliminate u32.
* bootloader/pci.c: Removed the r->size=0 and r->base=0
assignement which makes too-large regions conflict with onboard
hardware, replacing it with sfree which deletes the memory region
from the setup code, leaving it disabled.
* Makefile.am, bootloader/misc.c, bootloader/pci.c, bootloader/pci.h,
console/console.c, console/inch.c, console/reboot.c, console/uart.c,
console/uart.h, irq/irq.c, irq/irq.h, irq/irq_init.c,
motorola/motorola.c, motorola/motorola.h, openpic/openpic.c,
openpic/openpic.h, pci/detect_raven_bridge.c, pci/pci.c,
start/start.S, startup/bspstart.c, vectors/vectors_init.c,
vme/vmeconfig.c: Add MVME2100 BSP and MPC8240 support. There was also
a significant amount of spelling and whitespace cleanup.
* tod/todcfg.c: New file.
PR 606/bsps
* bootloader/pci.c: Fixed IO remapping so buses >= 1 are remapped.
Reduced PCI space to match bat2. Fixed incorrect region size
calculation in pci_read_bases. Set PCI latency timers to known
sane values. Changed bridge PCI settings to minimum sane instead
of whatever sounded neat in the PCI spec. Force pf regions to
memory mapped to preserve byte access.
* bootloader/exception.S: Include <rtems/asm.h> instead of <asm.h>.
* bootloader/head.S: Include <rtems/asm.h> instead of <asm.h>.
* irq/irq_asm.S: Include <rtems/asm.h> instead of <asm.h>.
* start/rtems_crti.S: Include <rtems/asm.h> instead of <asm.h>.
* start/start.S: Include <rtems/asm.h> instead of <asm.h>.
* vectors/vectors.S: Include <rtems/asm.h> instead of <asm.h>.
* bootloader/misc.c, bootloader/pci.c, console/inch.c,
include/bsp.h, pci/pci.c, startup/bspstart.c, startup/sbrk.c:
Convert to using c99 fixed size types.
* bootloader/pci.c: Remove warnings by adding include <string.h>.
* irq/irq.c: Clean up includes to remove warnings.
* pci/pci.c, pci/pci.h, startup/bspstart.c: Better use of const
on struct _int_map.
* Makefile.am: Merge-in bootloader/Makefile.am, clock/Makefile.am,
console/Makefile.am, include/Makefile.am, irq/Makefile.am,
motorola/Makefile.am, openpic/Makefile.am, pci/Makefile.am,
residual/Makefile.am, start/Makefile.am, startup/Makefile.am,
vectors/Makefile.am, vme/Makefile.am. Use automake compilation rules.
* bootloader/Makefile.am, clock/Makefile.am, console/Makefile.am,
include/Makefile.am, irq/Makefile.am, motorola/Makefile.am,
openpic/Makefile.am, pci/Makefile.am, residual/Makefile.am,
start/Makefile.am, startup/Makefile.am, vectors/Makefile.am,
vme/Makefile.am: Remove.
* bootloader/Makefile.am: Put all files into EXTRA_DIST.
* vme/Makefile.am: Ditto.
* console/Makefile.am: Move H_FILES to include_bsp_HEADERS.
Add preinstallation dirstamp support.
* irq/Makefile.am: Ditto.
* motorola/Makefile.am: Ditto.
* openpic/Makefile.am: Ditto.
* pci/Makefile.am: Ditto.
* residual/Makefile.am: Ditto.
* vectors/Makefile.am: Ditto.
* Makefile.am: Remove empty lines.
* clock/Makefile.am: Ditto.
* include/Makefile.am: Ditto.
* startup/Makefile.am: Ditto.
PR 497/bsps
* bootloader/head.S: Disable code that returned to the firmware when
the loader starts.
PR 497/bsps
* bootloader/head.S: Let the bootloader shut down the
network interface. NOTE: this involves a PPCBug system
call and will hence fail if other software is used
to boot. Need to #undef USE_PPCBUG in such cases!
* bootloader/bootldr.h, bootloader/em86.c, bootloader/em86real.S,
bootloader/exception.S, bootloader/head.S, bootloader/lib.c,
bootloader/misc.c, bootloader/mm.c, bootloader/pci.c,
clock/p_clock.c, console/console.c, console/consoleIo.h,
console/inch.c, console/keyboard.h, console/polled_io.c,
include/bsp.h, irq/i8259.c, irq/irq.c, irq/irq.h, irq/irq_asm.S,
irq/irq_init.c, motorola/motorola.c, motorola/motorola.h,
openpic/openpic.c, openpic/openpic.h, pci/pci.c, residual/residual.c,
start/start.S, startup/bspstart.c, vectors/vectors.h,
vectors/vectors_init.c: URL for license changed.
bootloader/Makefile.am: Reflect having moved automake.
irq/Makefile.am: Reflect having moved automake.
motorola/Makefile.am: Reflect having moved automake.
openpic/Makefile.am: Reflect having moved automake.
pci/Makefile.am: Reflect having moved automake.
residual/Makefile.am: Reflect having moved automake.
vme/Makefile.am: Reflect having moved automake.
PR 428/bsps
PR 432/bsps
* bootloader/pci.c: Re-instated code that prevents remapping small
IO regions, which if remapped would cause i8259 registers to move
out from under the #define'd base addresses.
* startup/bspstart.c: Reduced BAT2 PCI memory allocation to 256
megs, I incorrectly had extended it which would cause problems with
PCI devices that defined prefetchable memory.
PR 405/bsps
* bootloader/pci.c: Added support for configuring devices for pci
busses > 0
* pci/pci.c, pci/pci.h: Added FixupPCI() to store vectors in the
INTERRUPT_LINE register of pci devices any # of hops away
from the host processor.
* motorola/motorola.c, motorola/motorola.h: Added interrupt
routing tables in support of FixupPCI. This is board-specific,
each board will have to supply information for FixupPCI() to do
anything for it.
* startup/bspstart.c: Extended bat2 to cover entire PCI address space.
* irq/irq.c, irq/irq.h: Added support for shared interrupts.
Existing single hander vectors are undisturbed, a new function
added to allow adding/removing handlers from a vector.
* bootloader/head.S: Added support for optional debug via PPCbug.
Also turn off mmu/caches for the bootstrap phase, which seems to
cause trouble with the 603. The cpu init functions in the bsp
get all that stuff going properly.
* bootloader/em86.c, console/inch.c, console/polled_io.c, irq/irq.c,
motorola/motorola.c, pci/detect_raven_bridge.c,
vectors/vectors_init.c: Removed warnings.
* bootloader/em86real.S: Fix syntax error in comment near line 1185.
* bootloader/misc.c, console/Makefile.am, console/console.c,
console/consoleIo.h, console/inch.c, console/polled_io.c,
console/uart.c, console/uart.h, include/bsp.h, irq/Makefile.am,
irq/irq.c, irq/irq.h, irq/irq_init.c, openpic/openpic.c,
openpic/openpic.h, pci/Makefile.am, pci/pci.c, pci/pci.h,
residual/Makefile.am, start/start.S, startup/bspstart.c,
vectors/vectors.S, vectors/vectors.h, vectors/vectors_init.c:
Per PR216, "libbsp/powerpc/shared" BSP has been modified considerably
with the goal to make it more flexible and reusable by other
BSPs. The main strategies were:
- eliminate hardcoded base addresses; devices use offsets
and a BSP defined base address.
- separate functionality into different files (e.g. reboot from
inch.c to reboot.c) which can be overridden by a 'derived' BSP.
- separate initialization code into separate files (e.g. PCI
bridge detection/initialization was separated from the more
generic PCI access routines), also to make it easier for
'derived' BSPs to substitute their own initialization code.
There are also a couple of enhancements and fixes:
- IRQ handling code now has a hook for attaching a VME bridge.
- OpenPIC is now explicitely initialized (polarities, senses).
Eliminated the implicit assumption on the presence of an ISA PIC.
- UART and console driver now supports more than 1 port. The current
maximum of 2 can easily be extended by enlarging a table (it
would even be easier if the ISR API was not broken by design).
- fixed polled_io.c so it correctly supports console on COM2
- fixed TLB invalidation code (start.S).
- exception handler prints a stack backtrace.
- added BSP_pciFindDevice() to scan the pci bus for a particular
vendor/device/instance.
* bootloader/exception.S: Reflect changes to <rtems/score/cpu.h>.
* bootloader/head.S: Ditto.
* bootloader/misc.c: Ditto.
* console/polled_io.c: Ditto.
* irq/irq.c: Ditto.
* irq/irq_asm.S: Ditto.
* irq/irq_init.c: Include <rtems/bspIo.h>.
* start/start.S: Reflect changes to <rtems/score/cpu.h>.
* vectors/vectors.S: Ditto.
* residual/residual.c: Include <string.h>.
* vectors/vectors_init.c: Include <rtems/bspIo.h> for printk.
* bootloader/mm.c: Ditto.
* bootloader/pci.c: Ditto.
* console/console.c: Ditto.
* openpic/openpic.c: Ditto.
converted to automake.
which fixes a couple of bugs in RTEMS's old style Makefile.ins, which
apparently were introduced by moving the start directories and not
having adapted the Makefile.ins.
patch -p1 < rtems-rc-19991203-10.diff
As part of this effort, the mpc750 libcpu code is now shared with the
ppc6xx.
