* configure.ac: Add BSP_BOOTCARD_OPTIONS.
* Makefile.am: Fix breakage having been introduced in previous patch.
* Makefile.am, configure.ac, preinstall.am, PCI_bus/PCI.c,
PCI_bus/PCI.h, PCI_bus/flash.c, PCI_bus/universe.c, console/85c30.c,
console/85c30.h, console/console.c, console/consolebsp.h,
console/tbl85c30.c, include/bsp.h, include/gen2.h,
include/irq-config.h, include/tm27.h, irq/FPGA.c, irq/irq.h,
irq/irq_init.c, start/start.S, startup/Hwr_init.c,
startup/bspstart.c, startup/linkcmds, timer/timer.c, tod/tod.c,
vme/VMEConfig.h: Updated and tested with latest interrupt source.
Modified with latest memory allocation, but this needs testing.
* irq/no_pic.c: New file.
* start/start.S: Update for boot_card command line change.
* irq/irq.c: Add bsp_interrupt_handler_default() so this BSP will link.
* bsp_specs: Remove -Qy from *link.
* bsp_specs: Move -e start from *link to *startfile to avoid warning
for undefined entry symbol when linking relocatables with binutils
2.19.
* Makefile.am: Remove unused file.
* pci/no_host_bridge.c: Removed.
* preinstall.am: Regenerated.
* Makefile.am: bsp_cleanup() was wrong. Use stub. openpic.h not needed.
* startup/bspclean.c: Removed.
* PCI_bus/PCI.c, PCI_bus/PCI.h, PCI_bus/flash.c, console/85c30.h,
console/console.c, console/consolebsp.h, console/tbl85c30.c,
include/gen2.h, irq/FPGA.c, irq/irq.c, irq/irq.h, irq/irq_init.c,
pci/no_host_bridge.c, startup/bspclean.c, startup/bspstart.c,
startup/genpvec.c, startup/vmeintr.c: File head clean up.
* Makefile.am, PCI_bus/PCI.c, PCI_bus/universe.c, startup/genpvec.c:
Fix warnings.
* Makefile.am, preinstall.am, PCI_bus/PCI.c, PCI_bus/PCI.h,
PCI_bus/universe.c, console/85c30.c, console/85c30.h,
console/consolebsp.h, console/tbl85c30.c, include/gen2.h,
startup/Hwr_init.c, startup/bspstart.c, startup/genpvec.c,
startup/setvec.c, startup/vmeintr.c, timer/timer.c, tod/tod.c,
vme/VMEConfig.h: Some clean up.
* include/coverhd.h: Removed.
* include/irq-config.h: New file.
* startup/spurious.c: Removed.
* Makefile.am, preinstall.am, PCI_bus/universe.c, console/console.c,
include/bsp.h, irq/FPGA.c, irq/irq.c, startup/Hwr_init.c,
startup/bspstart.c, startup/vmeintr.c: Modifications required to run
on hardware. Some cleanup.
* Makefile.am: Eliminate bsp.am. Build startup files as side-effect
of building libbspstart.a, using automake-rules.
* Makefile.am: Eliminate *_SOURCES.
* Makefile.am: Move noinst_LIBRARIES = libbsp.a before its
components.
* Makefile.am: Remove noinst_PROGRAMS (Unused).
* Makefile.am: Cleanup ../../shared/include/bootcard.h handling.
* configure.ac: Make letting boot_card() handle work area allocation
mandatory. Rename RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION to
* include/bsp.h, startup/bspstart.c: Remove unused BSP_INIT_STACK_SIZE
now that the linkcmds accounts for the starting stack.
* Makefile.am, include/bsp.h, startup/bspstart.c, startup/linkcmds: Use
PowerPC level shared bsp_get_work_area() implementation.
* startup/bspgetworkarea.c: Removed.
* startup/bspstart.c: Remove unused variable.
* include/bsp.h: Remove unnecessary boilerplate comments.
* startup/bspstart.c: Add include of rtems/libio.h.
* include/bsp.h: Eliminate definitions of BSP_LIBIO_MAX_FDS since this
is NOT used anywhere.
* startup/bspstart.c: Merge GSOC project code to add simple device only
filesystem (devfs), optionally completely drop out filesystem, and to
clean up disabling newlib reentrancy support. This dropped 17K from
the minimum.exe for sparc/sis and arm/rtl22xx_t now has a 15K code
space.
* irq/FPGA.c: Remove unnecessary includes of rtems/libcsupport.h and
rtems/libio.h.
* Makefile.am, configure.ac, include/bsp.h, startup/bspstart.c: Add use
of bsp_get_work_area() in its own file and rely on BSP Framework to
perform more initialization.
* startup/bspgetworkarea.c: New file.
* include/bsp.h: Review of all bsp_cleanup() implementations. In this
phase, all prototypes were removed from bsp.h and empty
implementations were removed and made to use the shared stub.
* irq/irq.c: Convert to "bool".
* console/85c30.c, console/console.c, irq/FPGA.c, timer/timer.c,
tod/tod.c: Convert to "bool".
* Makefile.am, README, configure.ac, console/85c30.c,
console/console.c, console/consolebsp.h, include/bsp.h,
start/start.S, startup/bspstart.c, startup/genpvec.c,
startup/linkcmds, timer/timer.c, tod/tod.c: Initiate update and
testing. Runs hello but does not run ticker yet.
* timer/timer.c: Eliminate empty function from every benchmark timer
driver. Fix spelling.
* timer/timer.c: Rename timer driver methods to follow RTEMS
programming conventions.
* irq/FPGA.c, irq/irq_init.c, pci/no_host_bridge.c,
startup/Hwr_init.c, startup/genpvec.c:
Add missing prototypes.
* c/src/lib/libbsp/powerpc/score603e/startup/genpvec.c: Change to
the Chains API.
* startup/bspstart.c: Add capability for bootcard.c BSP Initialization
Framework to ask the BSP where it has memory for the RTEMS Workspace
and C Program Heap. These collectively are referred to as work area.
If the BSP supports this, then it does not have to include code to
split the available memory between the two areas. This reduces the
amount of code in the BSP specific bspstart.c file. Additionally, the
shared framework can initialize the C Library, call
rtems_debug_enable(), and dirty the work area memory. Until most/all
BSPs support this new capability, if the BSP supports this, it should
call RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION from its configure.ac.
When the transition is complete, this autoconf macro can be removed.
* Makefile.am: Rework to avoid .rel files.
* Makefile.am: Remove all references to console_reserve_resources and
termios_reserve_resources.
* console/consolereserveresources.c: Removed.
* startup/linkcmds: Add wildcard to gcc_except_table section so
programs compiled with gcc 4.3.x can link.
* include/bsp.h, startup/bspstart.c: Eliminate copies of the
Configuration Table. Use the RTEMS provided accessor macros to obtain
configuration fields.
