* configure.in: Remove.
* console/85c30.c, startup/bspstart.c: Fix references to delay() and
delay_in_bus_cycles() to add rtems_bsp_ prefix.
* startup/linkcmds: Modified to work better with gcc 2.8.1 and
gnat 3.13p.
* startup/genpvec.c: #include <chain.h> instead of "chain.h", fix
CVS-Id.
* include/chain.h: Remove.
* include/Makefile.am: Remove chain.h.
* startup/82378zb.c, startup/FPGA.c: assoc.h, error.h, libio_.h,
libio.h, and libcsupport.h moved from libc to lib/include/rtems and
* PCI_bus/Makefile.am, clock/Makefile.am, console/Makefile.am,
tod/Makefile.am, vectors/Makefile.am, wrapup/Makefile.am: Include
compile.am
from score/cpu to libcpu because the determination of which to use is
based on RTEMS_CPU_MODEL. Thus it can not be determined based solely on
multilib information.
that contains:
* Removes MKLIB
handling)
converted to automake.
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
BSP needs to be eliminated.
Still need to move debug io routines out.
CHANGES
autoconf check
autoconf check
$(prefix)/<bsp>/make/bsp.cfg
compatible.
Makefile.ins
dependencies of "Makefile".
--enable-maintainer-mode.
ncurses, and zlib for RTEMS.
link even if they do not actually support Ada interrupts.
Ian Lance Taylor <ian@airs.com>.
future.
cd <rtems-source-tree>
all bsp_specs.
In your various bsp_specs files, even when ecrti.o is defined as a
startfile, ecrtn.o is not defined as an endfile. Instead it seems to
be in the library list - untidy.
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
and automake.
reorg-bsp_specs.sh script.
significantly.
