Conflicts:
for details.
* configure.ac, startup/bspstart.c: Use standard cache BSP options.
PR1797/bsps: Applied cleaned-up version of Kate's patch.
CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK is now a 'bspopts.h'
setting and as such configurable.
* PCI_bus/PCI.c, console/console.c, include/bsp.h, include/tm27.h,
startup/Hwr_init.c, startup/bspstart.c:
* timer/timer.c: Include <rtems/btimer.h>.
* beatnik/include/bsp.h, beatnik/irq/irq.h, beatnik/pci/gt_pci_init.c,
ep1a/console/polled_io.c, ep1a/irq/openpic_xxx_irq.c,
gen5200/include/irq.h, gen5200/irq/irq.c, gen5200/startup/bspstart.c,
haleakala/irq/irq.c, mbx8xx/irq/irq.c, mbx8xx/irq/irq.h,
motorola_powerpc/include/bsp.h, mpc8260ads/irq/irq.c,
mpc8260ads/irq/irq.h, mvme3100/include/bsp.h, mvme3100/irq/irq.h,
mvme3100/start/start.S, mvme5500/include/bsp.h, mvme5500/irq/irq.h,
psim/include/bsp.h, psim/include/coverhd.h, psim/irq/irq.h,
psim/shmsupp/addrconv.c, psim/shmsupp/getcfg.c,
psim/startup/linkcmds, psim/tools/psim-gdb-top.in,
psim/tools/psim-top.in, psim/tools/runtest-top.in, qemuppc/irq/irq.h,
score603e/irq/irq.c, shared/bootloader/bootldr.h,
shared/bootloader/em86.c, shared/bootloader/em86real.S,
shared/bootloader/exception.S, shared/bootloader/head.S,
shared/bootloader/lib.c, shared/bootloader/misc.c,
shared/bootloader/mm.c, shared/bootloader/pci.c,
shared/console/console.c, shared/console/consoleIo.h,
shared/console/inch.c, shared/console/keyboard.h,
shared/console/polled_io.c, shared/irq/i8259.c, shared/irq/irq.h,
shared/irq/openpic_i8259_irq.c, shared/motorola/motorola.c,
shared/motorola/motorola.h, shared/openpic/openpic.c,
shared/openpic/openpic.h, shared/pci/pci.c,
shared/residual/residual.c, shared/start/start.S, ss555/irq/irq.h:
Fix typo where license said found in found in.
* console/console.c: Add BSP_poll_char.
* configure.ac: Remove AC_CHECK_SIZEOF([void *]).
* configure.ac: Added AC_CHECK_SIZEOF macro.
PR 1573/cpukit
* irq/irq.c: Add a per cpu data structure which contains the
information required by RTEMS for each CPU core. This encapsulates
information such as thread executing, heir, idle and dispatch needed.
* include/irq-config.h: Removed file.
* irq/irq.h, startup/bspstart.c: Remove warnings.
* console/consolebsp.h: Remove extraneous #warning.
* make/custom/score603e.cfg: Remove RTEMS_BSP_FAMILY.
* configure.ac: Default to having PSC8 mezzanine so code builds
all the time.
* startup/bspstart.c: Calibrated clock using an VMEBus controlled
discrete pulsed at a 20ms rate.
* make/custom/score603e.cfg: New (relocated from /make/custom).
* configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
* ep1a/startup/linkcmds, mbx8xx/startup/linkcmds,
score603e/startup/linkcmds, shared/startup/linkcmds,
ss555/startup/linkcmds: Fix typos in .eh_frame sections.
* include/bsp.h: Eliminate BSPs defining NUMBER_OF_TERMIOS_PORTS.
Should be automatically handled by confdefs.h or the application.
* console/console.c, startup/genpvec.c, startup/setvec.c: Disable call
to rtems_interrupt_catch until it is fixed. Need to disabled
set_vector.
* configure.ac: Rename BSP_BOOTCARD_OPTIONS to
RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs
have the same options.
* configure.ac: Add BSP_BOOTCARD_OPTIONS.
* Makefile.am: Fix breakage having been introduced in previous patch.
* Makefile.am, configure.ac, preinstall.am, PCI_bus/PCI.c,
PCI_bus/PCI.h, PCI_bus/flash.c, PCI_bus/universe.c, console/85c30.c,
console/85c30.h, console/console.c, console/consolebsp.h,
console/tbl85c30.c, include/bsp.h, include/gen2.h,
include/irq-config.h, include/tm27.h, irq/FPGA.c, irq/irq.h,
irq/irq_init.c, start/start.S, startup/Hwr_init.c,
startup/bspstart.c, startup/linkcmds, timer/timer.c, tod/tod.c,
vme/VMEConfig.h: Updated and tested with latest interrupt source.
Modified with latest memory allocation, but this needs testing.
* irq/no_pic.c: New file.
* start/start.S: Update for boot_card command line change.
* irq/irq.c: Add bsp_interrupt_handler_default() so this BSP will link.
* bsp_specs: Remove -Qy from *link.
* bsp_specs: Move -e start from *link to *startfile to avoid warning
for undefined entry symbol when linking relocatables with binutils
2.19.
* Makefile.am: Remove unused file.
* pci/no_host_bridge.c: Removed.
* preinstall.am: Regenerated.
* Makefile.am: bsp_cleanup() was wrong. Use stub. openpic.h not needed.
* startup/bspclean.c: Removed.
* PCI_bus/PCI.c, PCI_bus/PCI.h, PCI_bus/flash.c, console/85c30.h,
console/console.c, console/consolebsp.h, console/tbl85c30.c,
include/gen2.h, irq/FPGA.c, irq/irq.c, irq/irq.h, irq/irq_init.c,
pci/no_host_bridge.c, startup/bspclean.c, startup/bspstart.c,
startup/genpvec.c, startup/vmeintr.c: File head clean up.
* Makefile.am, PCI_bus/PCI.c, PCI_bus/universe.c, startup/genpvec.c:
Fix warnings.
