Updates #2458.
* Makefile.am, configure.ac, preinstall.am, PCI_bus/PCI.c,
PCI_bus/PCI.h, PCI_bus/flash.c, PCI_bus/universe.c, console/85c30.c,
console/85c30.h, console/console.c, console/consolebsp.h,
console/tbl85c30.c, include/bsp.h, include/gen2.h,
include/irq-config.h, include/tm27.h, irq/FPGA.c, irq/irq.h,
irq/irq_init.c, start/start.S, startup/Hwr_init.c,
startup/bspstart.c, startup/linkcmds, timer/timer.c, tod/tod.c,
vme/VMEConfig.h: Updated and tested with latest interrupt source.
Modified with latest memory allocation, but this needs testing.
* irq/no_pic.c: New file.
* Makefile.am, preinstall.am, PCI_bus/PCI.c, PCI_bus/PCI.h,
PCI_bus/universe.c, console/85c30.c, console/85c30.h,
console/consolebsp.h, console/tbl85c30.c, include/gen2.h,
startup/Hwr_init.c, startup/bspstart.c, startup/genpvec.c,
startup/setvec.c, startup/vmeintr.c, timer/timer.c, tod/tod.c,
vme/VMEConfig.h: Some clean up.
* include/coverhd.h: Removed.
* Makefile.am, README, configure.ac, console/85c30.c,
console/console.c, console/consolebsp.h, include/bsp.h,
include/gen2.h, irq/FPGA.c, irq/irq.c, irq/irq.h, irq/irq_init.c,
start/start.S, startup/bspstart.c, startup/genpvec.c,
startup/linkcmds, timer/timer.c, tod/tod.c: Initiate update and
testing. Runs hello but does not run ticker yet.
PR 778/bsps
* include/bsp.h, include/gen2.h, startup/FPGA.c, startup/Hwr_init.c,
startup/bspstart.c, tod/tod.c:
modify SCORE_.. to BSP_.. for externally used define's.
* PCI_bus/PCI.c, PCI_bus/PCI.h, PCI_bus/flash.c, PCI_bus/universe.c,
clock/clock.c, console/85c30.c, console/console.c,
console/consolebsp.h, include/bsp.h, include/gen2.h, startup/FPGA.c,
startup/spurious.c, startup/vmeintr.c, timer/timer.c, tod/tod.c:
Convert to using c99 fixed size types.
* PCI_bus/PCI.h, clock/clock.c, console/85c30.c, console/85c30.h,
console/consolereserveresources.c, console/tbl85c30.c, include/bsp.h,
include/coverhd.h, include/gen2.h, include/tod.h, startup/FPGA.c,
startup/bspclean.c, startup/bspstart.c, startup/genpvec.c,
startup/setvec.c, startup/vmeintr.c, timer/timer.c, tod/tod.c: URL
for license changed.
