* | 2005-01-28 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-01-28 | 1 | -1/+1 |
| | | | | * startup/linkcmds: Add .gnu.linkonce.b.* section. | ||||
* | 2005-01-26 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-01-26 | 1 | -0/+2 |
| | | | | * startup/linkcmds: Now links. | ||||
* | 2005-01-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-01-04 | 1 | -2/+0 |
| | | | | * startup/linkcmds: Remove warnings. | ||||
* | mkChangeLogList [-n] | Joel Sherrill | 2003-01-20 | 1 | -0/+11 |
* | 2001-05-09 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-05-09 | 1 | -23/+24 |
| | | | | | | | | * startup/linkcmds: In support of gcc 3.1, added one of more of the sections .jcr, .rodata*, .data.*, .gnu.linkonce.s2.*, .gnu.linkonce.sb2.*, and .gnu.linkonce.s.*. Spacing corrections and direction of segments to memory regions may also have been addressed. This was a sweep across all BSPs. | ||||
* | 2001-04-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-04-08 | 1 | -5/+4 |
| | | | | * startup/linkcmds: Per PR170, PR171, and PR172 add .eh_frame | ||||
* | 2001-10-25 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2001-10-25 | 1 | -2/+2 |
| | | | | * startup/linkcmds: Added _init and _fini. | ||||
* | 2001-08-30 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2001-08-30 | 1 | -2/+2 |
| | | | | | * startup/linkcmds: Modified to work better with gcc 2.8.1 and gnat 3.13p. | ||||
* | Now allows override of base address via -Ttext command to linker. | Joel Sherrill | 1999-11-17 | 1 | -39/+47 |
* | Added sections as required by C++ and ELF. | Joel Sherrill | 1999-10-06 | 1 | -1/+3 |
* | BSP for Vista Score603e added. | Joel Sherrill | 1999-02-19 | 1 | -0/+181 |
