Updates #2458.
warning and clean up
Instead of SPRG0 (= special purpose register 272) use the new global
symbol _PPC_INTERRUPT_DISABLE_MASK to store the interrupt disable mask.
The benefit is that it is now possible to disable interrupts without
further run-time initialization in boot_card().
At least on Freescale e500 cores this leads also to a faster execution
since the mfmsr and mfspr instruction require four cycles to complete.
The instructions to load the mask value can execute while the mfmsr is
in progress.
* configure.ac, startup/bspstart.c: Use standard cache BSP options.
* PCI_bus/PCI.c, console/console.c, include/bsp.h, include/tm27.h,
startup/Hwr_init.c, startup/bspstart.c:
* irq/irq.h, startup/bspstart.c: Remove warnings.
* configure.ac: Default to having PSC8 mezzanine so code builds
all the time.
* startup/bspstart.c: Calibrated clock using an VMEBus controlled
discrete pulsed at a 20ms rate.
* Makefile.am, configure.ac, preinstall.am, PCI_bus/PCI.c,
PCI_bus/PCI.h, PCI_bus/flash.c, PCI_bus/universe.c, console/85c30.c,
console/85c30.h, console/console.c, console/consolebsp.h,
console/tbl85c30.c, include/bsp.h, include/gen2.h,
include/irq-config.h, include/tm27.h, irq/FPGA.c, irq/irq.h,
irq/irq_init.c, start/start.S, startup/Hwr_init.c,
startup/bspstart.c, startup/linkcmds, timer/timer.c, tod/tod.c,
vme/VMEConfig.h: Updated and tested with latest interrupt source.
Modified with latest memory allocation, but this needs testing.
* irq/no_pic.c: New file.
* PCI_bus/PCI.c, PCI_bus/PCI.h, PCI_bus/flash.c, console/85c30.h,
console/console.c, console/consolebsp.h, console/tbl85c30.c,
include/gen2.h, irq/FPGA.c, irq/irq.c, irq/irq.h, irq/irq_init.c,
pci/no_host_bridge.c, startup/bspclean.c, startup/bspstart.c,
startup/genpvec.c, startup/vmeintr.c: File head clean up.
* Makefile.am, preinstall.am, PCI_bus/PCI.c, PCI_bus/PCI.h,
PCI_bus/universe.c, console/85c30.c, console/85c30.h,
console/consolebsp.h, console/tbl85c30.c, include/gen2.h,
startup/Hwr_init.c, startup/bspstart.c, startup/genpvec.c,
startup/setvec.c, startup/vmeintr.c, timer/timer.c, tod/tod.c,
vme/VMEConfig.h: Some clean up.
* include/coverhd.h: Removed.
* Makefile.am, preinstall.am, PCI_bus/universe.c, console/console.c,
include/bsp.h, irq/FPGA.c, irq/irq.c, startup/Hwr_init.c,
startup/bspstart.c, startup/vmeintr.c: Modifications required to run
on hardware. Some cleanup.
* include/bsp.h, startup/bspstart.c: Remove unused BSP_INIT_STACK_SIZE
now that the linkcmds accounts for the starting stack.
* Makefile.am, include/bsp.h, startup/bspstart.c, startup/linkcmds: Use
PowerPC level shared bsp_get_work_area() implementation.
* startup/bspgetworkarea.c: Removed.
* startup/bspstart.c: Remove unused variable.
* startup/bspstart.c: Add include of rtems/libio.h.
* startup/bspstart.c: Merge GSOC project code to add simple device only
filesystem (devfs), optionally completely drop out filesystem, and to
clean up disabling newlib reentrancy support. This dropped 17K from
the minimum.exe for sparc/sis and arm/rtl22xx_t now has a 15K code
space.
* Makefile.am, configure.ac, include/bsp.h, startup/bspstart.c: Add use
of bsp_get_work_area() in its own file and rely on BSP Framework to
perform more initialization.
* startup/bspgetworkarea.c: New file.
* Makefile.am, README, configure.ac, console/85c30.c,
console/console.c, console/consolebsp.h, include/bsp.h,
start/start.S, startup/bspstart.c, startup/genpvec.c,
startup/linkcmds, timer/timer.c, tod/tod.c: Initiate update and
testing. Runs hello but does not run ticker yet.
* startup/bspstart.c: Add capability for bootcard.c BSP Initialization
Framework to ask the BSP where it has memory for the RTEMS Workspace
and C Program Heap. These collectively are referred to as work area.
If the BSP supports this, then it does not have to include code to
split the available memory between the two areas. This reduces the
amount of code in the BSP specific bspstart.c file. Additionally, the
shared framework can initialize the C Library, call
rtems_debug_enable(), and dirty the work area memory. Until most/all
BSPs support this new capability, if the BSP supports this, it should
call RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION from its configure.ac.
When the transition is complete, this autoconf macro can be removed.
* include/bsp.h, startup/bspstart.c: Eliminate copies of the
Configuration Table. Use the RTEMS provided accessor macros to obtain
configuration fields.
* include/bsp.h, startup/bspstart.c: Move interrupt_stack_size field
from CPU Table to Configuration Table. Eliminate CPU Table from all
ports. Delete references to CPU Table in all forms.
* Makefile.am, startup/bspstart.c: Moved most of the remaining CPU
Table fields to the Configuration Table. This included
pretasking_hook, predriver_hook, postdriver_hook, idle_task,
do_zero_of_workspace, extra_mpci_receive_server_stack,
stack_allocate_hook, and stack_free_hook. As a side-effect of this
effort some multiprocessing code was made conditional and some style
clean up occurred.
* startup/bspstart: removed _Cpu_table.exceptions_in_RAM.
* startup/bspstart.c: Eliminate PowerPC specific elements from the CPU
Table. They have been replaced with variables named bsp_XXX as
needed.
* PCI_bus/universe.c, console/console.c, include/bsp.h, irq/FPGA.c,
startup/bspstart.c, startup/genpvec.c, startup/spurious.c: Eliminate
DEBUG_puts.
* startup/bspstart.c: Remove assignments of
Cpu_table.do_zero_of_workspace to TRUE since TRUE is the default
value in boot_card.c
* score603e/Makefile.am, score603e/configure.ac,
score603e/console/console.c, score603e/include/bsp.h,
score603e/include/gen2.h, score603e/include/tm27.h,
score603e/startup/bspstart.c: Update score603e to new exception model
NOTE: These modifications have not been tested on hardware.
PR 778/bsps
* include/bsp.h, include/gen2.h, startup/FPGA.c, startup/Hwr_init.c,
startup/bspstart.c, tod/tod.c:
modify SCORE_.. to BSP_.. for externally used define's.
* PCI_bus/PCI.c, PCI_bus/PCI.h, PCI_bus/flash.c, PCI_bus/universe.c,
clock/clock.c, console/85c30.c, console/console.c,
console/consolebsp.h, include/bsp.h, include/gen2.h, startup/FPGA.c,
startup/spurious.c, startup/vmeintr.c, timer/timer.c, tod/tod.c:
Convert to using c99 fixed size types.
* PCI_bus/PCI.h, clock/clock.c, console/85c30.c, console/85c30.h,
console/consolereserveresources.c, console/tbl85c30.c, include/bsp.h,
include/coverhd.h, include/gen2.h, include/tod.h, startup/FPGA.c,
startup/bspclean.c, startup/bspstart.c, startup/genpvec.c,
startup/setvec.c, startup/vmeintr.c, timer/timer.c, tod/tod.c: URL
for license changed.
* PCI_bus/PCI.h, clock/clock.c, console/85c30.c, console/console.c,
console/consolebsp.h, console/consolereserveresources.c,
console/tbl85c30.c, include/bsp.h, include/coverhd.h, include/gen1.h,
include/gen2.h, startup/82378zb.c, startup/FPGA.c,
startup/bspstart.c, startup/genpvec.c, startup/setvec.c,
startup/vmeintr.c, timer/timer.c: Fixed typo.
* console/85c30.c, startup/bspstart.c: Fix references to delay() and
delay_in_bus_cycles() to add rtems_bsp_ prefix.
