* | Use $(EXEEXT) [defaults to "exe"] to generate binaries | Nick Withers | 2013-08-09 | 1 | -1/+1 |
* | 2009-10-21 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-21 | 1 | -3/+0 |
| | | | | * make/custom/score603e.cfg: Remove RTEMS_BSP_FAMILY. | ||||
* | 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-15 | 1 | -0/+34 |
* make/custom/score603e.cfg: New (relocated from /make/custom). |
