PCI_bus/Makefile.am, startup/Makefile.am, timer/Makefile.am,
tod/Makefile.am, vectors/Makefile.am. Use automake compilation rules.
* clock/Makefile.am, console/Makefile.am, PCI_bus/Makefile.am,
startup/Makefile.am, timer/Makefile.am, tod/Makefile.am,
vectors/Makefile.am: Remove.
* Makefile.am: Merge-in start/Makefile.am.
* start/Makefile.am: Remove.
* configure.ac: Add nostdinc to AUTOMAKE_OPTIONS.
Add RTEMS_PROG_CCAS.
Reflect changes to bsp.am.
This was tracked as PR87.
* README, configure.ac, include/Makefile.am, include/bsp.h,
start/start.S, startup/FPGA.c, startup/Makefile.am, tod/Makefile.am:
Eliminated conditional code for generation 1 boards as these are
no longer available.
* include/gen1.h, startup/82378zb.c, tod/tod_g1.c: Deleted.
* Makefile.am: Add @exceptions@ to SUBDIRS.
* configure.ac: Apply RTEMS_BSPOPTS_*(*) to merge-in settings from
make/custom/score603e.cfg;
Add automake conditional for SCORE_GENERATION_1;
Add RTEMS_PPC_EXCEPTIONS([old]).
* include/Makefile.am: include force-preinstall.am.
* start/start.S: include <bspopts.h> instead of targopts.h.
* tod/Makefile.am: Apply SCORE_GENERATION_1 conditional.
* vectors/vector.S: include <bsp.h>.
* wrapup/Makefile.am: Apply @exceptions@.
* configure.in: Remove.
* configure.ac: Add bspopts.h; Add CPU_CLOCK_RATE_HZ.
* startup/bspstart.c: Replace HZ with CPU_CLOCK_RATE_HZ.
* include/.cvsignore: Add stamp-h* bspopts.h*
* include/bsp.h: Add bspopts.h.
* clock/Makefile.am, clock/ckinit.c, clock/.cvsignore, Makefile.am,
README, bsp_specs, console/Makefile.am, console/console.c,
console/.cvsignore, include/Makefile.am, include/bsp.h,
include/coverhd.h, include/syscall.h, include/ramdisk.h,
include/.cvsignore, start/Makefile.am, start/start.S,
start/.cvsignore, startup/Makefile.am, startup/bspstart.c,
startup/hw_init.c, startup/linkcmds, startup/linkcmds-le,
startup/linkcmds-le.coff, startup/.cvsignore, timer/Makefile.am,
timer/timer.c, timer/.cvsignore, wrapup/Makefile.am, wrapup/.cvsignore,
configure.ac, .cvsignore, ChangeLog: New files.
Reviewed and updated to latest automake and autoconf standards
by Ralf Corsepius <corsepiu@faw.uni-ulm.de>.
* Makefile.am, README, bsp_specs, .cvsignore, include/Makefile.am,
include/bsp.h, include/coverhd.h, include/sdram.h, include/.cvsignore,
start/Makefile.am, start/start.S, start/.cvsignore, startup/Makefile.am,
startup/bspstart.c, startup/linkcmds, startup/linkcmds.rom,
startup/linkcmds.rom2ram, startup/.cvsignore, wrapup/Makefile.am,
wrapup/.cvsignore, hw_init/Makefile.am, hw_init/hw_init.c,
hw_init/.cvsignore, times, configure.ac: New files.
* include/Makefile.am: Use *_HEADERS instead of *H_FILES, add
bspopts.h.
* include/.cvsignore: Add bspopts.h.
* console/Makefile.am: Use *_HEADERS instead of H_FILES.
* Shared memory support removed since it was non-functional.
* shmsupp/.cvsignore, shmsupp/Makefile.am, shmsupp/addrconv.c,
shmsupp/getcfg.c, shmsupp/lock.c, shmsupp/mpisr.c: Removed.
* configure.in, Makefile.am, wrapup/Makefile.am: Modified to
reflect above.
cpuopts.h.
exec/configure.in, only.
quoting bugs in autoconf).
formating changes :)
that contains:
* Removes MKLIB
handling)
that converts the a29k directory to automake.
NOTE: This port is not based on the GNU tools so no one can test it.
that converts the i960 directory to automake.
The same kind of libbsp configuration as for the mips64orion, now for
the i960.
In addition to libbsp configuration this patch also contains two fixes
for cvme961.cfg and rxgen960.cfg, which contained non-functional
make-exes. (Now both bsps probably have the same issues with linking c++
applications as the gensh2 has, but this is a different open issue not
tried to be solved now).
The rxgen961 also seems to have problems with its start file, because
linking apps fails due to not finding start.o. (Note that
libbsp/i960/rxgen960 lacks a start subdirectory!). I leave solving this
issue to you :)
that converts the no_cpu directory to automake.
that converts the unix directory to automake.
Ralf's note: Please check c/src/lib/libbsp/unix/posix/startup/Makefile.am.
I am not sure if it is correct.
that converts the sparc directory to automake.
Ralf's note: The implementation of libbsp/sparc/* gives a nearly minimal
example of the new configuration scheme.
that converts nearly all of libbsp/sh to automake. Comments follow:
1. Almost full automake support for the libbsp/sh/ subdirectories
(exception libbsp/sh/gensh*/wrapup/*)
2. Fixes for libbsp/bare/*
3. Updates to libbsp/* configuration which supports old (autoconf/deep
configuration) and new (automake/flat/cascaded configuration) style
configuration of libbsp/<cpu>/*
which adds automake support to libbsp/bare.
